#41
DIY Two-Stroke Engine
"bod43" wrote www.deltahawk.com Too big for ultralight I would guess but seems like a very fine plan for a light aircraft engine. Expected to be accepted as a FAA certified aero engine this year. I'll believe it when I see that the first 25 are sold and flying. It has been ready for production for the past 10 or more years, yet, it always a year away from being released for production. Hint: I'll win this bet. -- Jim in NC |
#42
wrote in message ... On Tue, 9 Mar 2010 04:36:58 -0800 (PST), Jim Wilkins wrote: On Mar 8, 11:55 pm, Tim Wescott wrote: ... www.deltahawk.com That link redirects to a poster site. Tim Wescott http://www.deltahawkengines.com/ Any day now..... jsw For the last 10 years. Surprise, Surprise. There is a two seat experimental Helicopter in Australia that is undergoing flight tests as I write this. It is using the Deltahawk two stroke diesel engine. see www.deltahelicopters.com.au Unfortunately the Deltahawk engines are priced right up there with the long time proven Lycomings. It will take some time to really see if this engine will demonstrate all the potential advantages inherent in the diesel concept. |
#43
"Morgans" wrote in message ... Most have the gearbox made as one with the lower crankcase. You can't get the weight off of the engine, and the gears in the bike tranny are not tough enough to run a prop, so you have to live with the weight and figure out a way to get the power out of the case without using the gearbox. Big problem. Of course, that is not so with Harley & clone V-twins and at least some BMW engines (Yes, I know. They are 4-stroke and this thread is about 2-stroke engines) Vaughn |
#44
Thanks for the responses. I meant for ultralight or light aircraft
with 20-40hp from 1 or 2 cylinders. I definitely want to copy as much as I can since I'm not engineer. I planned to have the RPM at about 4000 in order to get enough power out of the engine but I may reduce the rpm if I can get enough power. Also I may have to weld the crank together to handle the propeller loads. Brock |
#45
durabol wrote:
Thanks for the responses. I meant for ultralight or light aircraft with 20-40hp from 1 or 2 cylinders. I definitely want to copy as much as I can since I'm not engineer. I planned to have the RPM at about 4000 in order to get enough power out of the engine but I may reduce the rpm if I can get enough power. Also I may have to weld the crank together to handle the propeller loads. Brock That RPM isn't going to give you much prop efficiency. A more spindly engine with higher displacement may be lighter overall -- and certainly mechanically simpler -- than a little fast engine and a speed reducer. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com |
#46
On Mar 14, 11:30*pm, durabol wrote:
Thanks for the responses. I meant for ultralight or light aircraft with 20-40hp from 1 or 2 cylinders. I definitely want to copy as much as I can since I'm not engineer. I planned to have the RPM at about 4000 in order to get enough power out of the engine but I may reduce the rpm if I can get enough power. Also I may have to weld the crank together to handle the propeller loads. Brock 'Restrictive' exhaust isn't a good way to avoid venting unburnt fuel, and it will really clobber performance. If you're really trying to get good performance, especially over a narrow band, then you really need to consider using tuned pipes (AKA "Expansion Chambers"). Gordon Jennings "Two Stroke Tuners Handbook" covers most everything you need to design a two-stroke. 4000 RPM is pretty low for a two-stroke. The tuned length for the pipe(s) would be around 6 FEET. |
#47
Grider Pirate wrote:
On Mar 14, 11:30 pm, durabol wrote: Thanks for the responses. I meant for ultralight or light aircraft with 20-40hp from 1 or 2 cylinders. I definitely want to copy as much as I can since I'm not engineer. I planned to have the RPM at about 4000 in order to get enough power out of the engine but I may reduce the rpm if I can get enough power. Also I may have to weld the crank together to handle the propeller loads. Brock 'Restrictive' exhaust isn't a good way to avoid venting unburnt fuel, and it will really clobber performance. If you're really trying to get good performance, especially over a narrow band, then you really need to consider using tuned pipes (AKA "Expansion Chambers"). Gordon Jennings "Two Stroke Tuners Handbook" covers most everything you need to design a two-stroke. 4000 RPM is pretty low for a two-stroke. The tuned length for the pipe(s) would be around 6 FEET. Ship's two-stroke diesel engines top out at less than 200RPM. I don't think they use tuned pipes, but if they did I suppose they'd have room. -- Tim Wescott Control system and signal processing consulting www.wescottdesign.com |
#48
Tim Wescott wrote:
Grider Pirate wrote: On Mar 14, 11:30 pm, durabol wrote: Thanks for the responses. I meant for ultralight or light aircraft with 20-40hp from 1 or 2 cylinders. I definitely want to copy as much as I can since I'm not engineer. I planned to have the RPM at about 4000 in order to get enough power out of the engine but I may reduce the rpm if I can get enough power. Also I may have to weld the crank together to handle the propeller loads. Brock 'Restrictive' exhaust isn't a good way to avoid venting unburnt fuel, and it will really clobber performance. If you're really trying to get good performance, especially over a narrow band, then you really need to consider using tuned pipes (AKA "Expansion Chambers"). Gordon Jennings "Two Stroke Tuners Handbook" covers most everything you need to design a two-stroke. 4000 RPM is pretty low for a two-stroke. The tuned length for the pipe(s) would be around 6 FEET. Ship's two-stroke diesel engines top out at less than 200RPM. I don't think they use tuned pipes, but if they did I suppose they'd have room. Don't need them. They all have massive blowers for scavenging. I believe EMD built locomotive 2-strokes that had a set of exhaust valves in the head and a blower port that was opened at the bottom of the stroke. No tuning, the blower was plenty to force out the exhaust and fill the cylinder with fresh air. |
#49
On Thu, 18 Mar 2010 13:39:45 -0700, Tim Wescott
wrote: Grider Pirate wrote: On Mar 14, 11:30 pm, durabol wrote: Thanks for the responses. I meant for ultralight or light aircraft with 20-40hp from 1 or 2 cylinders. I definitely want to copy as much as I can since I'm not engineer. I planned to have the RPM at about 4000 in order to get enough power out of the engine but I may reduce the rpm if I can get enough power. Also I may have to weld the crank together to handle the propeller loads. Brock 'Restrictive' exhaust isn't a good way to avoid venting unburnt fuel, and it will really clobber performance. If you're really trying to get good performance, especially over a narrow band, then you really need to consider using tuned pipes (AKA "Expansion Chambers"). Gordon Jennings "Two Stroke Tuners Handbook" covers most everything you need to design a two-stroke. 4000 RPM is pretty low for a two-stroke. The tuned length for the pipe(s) would be around 6 FEET. Ship's two-stroke diesel engines top out at less than 200RPM. I don't think they use tuned pipes, but if they did I suppose they'd have room. They are also supercharged. (forced induction) |
#50
On Thu, 18 Mar 2010 14:17:50 -0700, Jim Stewart
wrote: Tim Wescott wrote: Grider Pirate wrote: On Mar 14, 11:30 pm, durabol wrote: Thanks for the responses. I meant for ultralight or light aircraft with 20-40hp from 1 or 2 cylinders. I definitely want to copy as much as I can since I'm not engineer. I planned to have the RPM at about 4000 in order to get enough power out of the engine but I may reduce the rpm if I can get enough power. Also I may have to weld the crank together to handle the propeller loads. Brock 'Restrictive' exhaust isn't a good way to avoid venting unburnt fuel, and it will really clobber performance. If you're really trying to get good performance, especially over a narrow band, then you really need to consider using tuned pipes (AKA "Expansion Chambers"). Gordon Jennings "Two Stroke Tuners Handbook" covers most everything you need to design a two-stroke. 4000 RPM is pretty low for a two-stroke. The tuned length for the pipe(s) would be around 6 FEET. Ship's two-stroke diesel engines top out at less than 200RPM. I don't think they use tuned pipes, but if they did I suppose they'd have room. Don't need them. They all have massive blowers for scavenging. I believe EMD built locomotive 2-strokes that had a set of exhaust valves in the head and a blower port that was opened at the bottom of the stroke. No tuning, the blower was plenty to force out the exhaust and fill the cylinder with fresh air. And at 200 RPM there is LOTS of time to purge and fill. Volumetric efficiencies are pretty good. |
Similar Threads | ||||
2-stroke diesel is the (near) future? | Max Kallio | Home Built | 134 | July 18th 05 12:39 AM |
Small 4 stroke engine? | Ron Wanttaja | Home Built | 35 | July 2nd 05 07:25 PM |
How about 2-stroke diesel for helicopters | Max Kallio | Rotorcraft | 3 | March 31st 05 04:46 PM |
BSFC vs gas mileage, 2 stroke vs 4 stroke | Jay | Home Built | 10 | August 24th 04 02:26 PM |
McCullough Two-Stroke Relaibility | Gordon Arnaut | Home Built | 0 | June 15th 04 10:26 PM |
