Mosquito question
I just bought mosquito 303 and there is an 6x8 inch Inspection hole behind main gear is that factory.
Mosquito question
On Sunday, July 24, 2016 at 11:24:11 PM UTC-4, wrote:
I just bought mosquito 303 and there is an 6x8 inch Inspection hole behind main gear is that factory. yes. That is how you inspect/service the control connections. please consider joining the mosquito group https://groups.yahoo.com/neo/groups/Mosquitos/ Chris |
Mosquito question
On Monday, July 25, 2016 at 11:24:11 AM UTC+8, wrote:
I just bought mosquito 303 and there is an 6x8 inch Inspection hole behind main gear is that factory. Yes that is Glasflugel standard, all the Mozzy's and Hornet's have the hatch, it is access to the rudder circuit bellcrank and stops, amongst other things Chris Runeckles |
Mosquito question
Mine has an air exit vent built in to the hatch - unsure if it's factory or not.
Nick. On Monday, July 25, 2016 at 1:29:15 PM UTC+9:30, wrote: On Monday, July 25, 2016 at 11:24:11 AM UTC+8, wrote: I just bought mosquito 303 and there is an 6x8 inch Inspection hole behind main gear is that factory. Yes that is Glasflugel standard, all the Mozzy's and Hornet's have the hatch, it is access to the rudder circuit bellcrank and stops, amongst other things Chris Runeckles |
Mosquito question
On Tuesday, July 26, 2016 at 4:46:08 AM UTC+8, wrote:
Mine has an air exit vent built in to the hatch - unsure if it's factory or not. Nick. On Monday, July 25, 2016 at 1:29:15 PM UTC+9:30, wrote: On Monday, July 25, 2016 at 11:24:11 AM UTC+8, wrote: I just bought mosquito 303 and there is an 6x8 inch Inspection hole behind main gear is that factory. Yes that is Glasflugel standard, all the Mozzy's and Hornet's have the hatch, it is access to the rudder circuit bellcrank and stops, amongst other things Chris Runeckles Hi Nick that air vent is not standard its a job I did for a customer and the hatch got swapped when the glider was pranged |
Similar Threads | ||||
R-22 vs Mosquito | Stuart & Kathryn Fields | Rotorcraft | 15 | May 12th 08 04:25 PM |
Ok then, how about the Mosquito? | Bob Upp | Home Built | 5 | January 10th 07 02:36 PM |
I Want a Mosquito..... | Shiver | Rotorcraft | 5 | January 30th 06 05:27 AM |
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good | Excelsior | Home Built | 0 | April 22nd 05 01:11 AM |
Mosquito fighter-bomber tactics question | Kari Korpi | Military Aviation | 6 | April 5th 04 09:09 AM |
