#111
USAF F-16 Instructor Discusses Flying Into MOAs
"Steven P. McNicoll" wrote in message m... "Larry Dighera" wrote in message ... I understand what § 91.119(c) says. An attorney will understand it too. You only think that you understand it. § 91.119 Minimum safe altitudes: General. Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes: (c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. It says that over open water or sparsely populated areas an aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. Implicit in that statement is the lack of any lower altitude limit, with the exception of being in the proximity of a person, vessel, vehicle, or structure. But there is some ambiguity. The only ambiguity is in what constitutes a sparsely populated area. The fact that the first sentence states that an aircraft may not be operated below the following altitudes can not possibly apply to operation laterally distant from a person, vessel, vehicle, or structure, because a lateral distance is not an altitude. If the wording had included 'person, vessel, vehicle, or structure LOCATED ON THE GROUND', perhaps it's intent would have been clearer, but the language as written fails to restrict the implied 500' lateral limit from being applied at altitude, IMO. "Fails to restrict the implied 500' lateral limit from being applied at altitude" from what? A person that is not in an aircraft? An airborne vessel? An airborne vehicle other than an aircraft? An airborne structure? What type of vessels are operated on the GROUND? In the subject case (presumably over a sparsely populated area) the F-16 was alleged to have been operated in less than 500' lateral proximity to a vehicle, another aircraft in this case. Ehhh? A lateral distance is not an altitude but an altitude is a lateral distance? I would say you are naïve if you believe, that the attorney pilot will fail to read § 91.119(c) the way I have? Most judges are attorneys. ... No intelligent person will read § 91.119(c) the way you have. That is not an opinion. Larry, are you unable to address the issues raised? |
#112
On Sat, 10 May 2008 07:30:42 -0500, "Steven P. McNicoll"
wrote in : "Steven P. McNicoll" wrote in message om... "Larry Dighera" wrote in message ... I understand what § 91.119(c) says. An attorney will understand it too. You only think that you understand it. § 91.119 Minimum safe altitudes: General. Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes: (c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. It says that over open water or sparsely populated areas an aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. Implicit in that statement is the lack of any lower altitude limit, with the exception of being in the proximity of a person, vessel, vehicle, or structure. But there is some ambiguity. The only ambiguity is in what constitutes a sparsely populated area. The fact that the first sentence states that an aircraft may not be operated below the following altitudes can not possibly apply to operation laterally distant from a person, vessel, vehicle, or structure, because a lateral distance is not an altitude. If the wording had included 'person, vessel, vehicle, or structure LOCATED ON THE GROUND', perhaps it's intent would have been clearer, but the language as written fails to restrict the implied 500' lateral limit from being applied at altitude, IMO. "Fails to restrict the implied 500' lateral limit from being applied at altitude" from what? A person that is not in an aircraft? An airborne vessel? An airborne vehicle other than an aircraft? An airborne structure? What type of vessels are operated on the GROUND? In the subject case (presumably over a sparsely populated area) the F-16 was alleged to have been operated in less than 500' lateral proximity to a vehicle, another aircraft in this case. Ehhh? A lateral distance is not an altitude but an altitude is a lateral distance? I would say you are naïve if you believe, that the attorney pilot will fail to read § 91.119(c) the way I have? Most judges are attorneys. ... No intelligent person will read § 91.119(c) the way you have. That is not an opinion. Larry, are you unable to address the issues raised? To what issue do you refer? Your interpretation of the FAR is not incorrect. Mine could be reasonably expected to be employed by an attorney. Surely, you must agree that there is room for differing interpretations among the FARS. We've both expressed our views on this subject. I see no reason for further discussion; nothing will change. |
#113
"Larry Dighera" wrote in message ... On Sat, 10 May 2008 07:30:42 -0500, "Steven P. McNicoll" wrote in : "Steven P. McNicoll" wrote in message news:GcWdnW_sPKM6X4TVnZ2dnUVZ_tWtnZ2d@earthlink. com... "Larry Dighera" wrote in message ... I understand what § 91.119(c) says. An attorney will understand it too. You only think that you understand it. § 91.119 Minimum safe altitudes: General. Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes: (c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. It says that over open water or sparsely populated areas an aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. Implicit in that statement is the lack of any lower altitude limit, with the exception of being in the proximity of a person, vessel, vehicle, or structure. But there is some ambiguity. The only ambiguity is in what constitutes a sparsely populated area. The fact that the first sentence states that an aircraft may not be operated below the following altitudes can not possibly apply to operation laterally distant from a person, vessel, vehicle, or structure, because a lateral distance is not an altitude. If the wording had included 'person, vessel, vehicle, or structure LOCATED ON THE GROUND', perhaps it's intent would have been clearer, but the language as written fails to restrict the implied 500' lateral limit from being applied at altitude, IMO. "Fails to restrict the implied 500' lateral limit from being applied at altitude" from what? A person that is not in an aircraft? An airborne vessel? An airborne vehicle other than an aircraft? An airborne structure? What type of vessels are operated on the GROUND? In the subject case (presumably over a sparsely populated area) the F-16 was alleged to have been operated in less than 500' lateral proximity to a vehicle, another aircraft in this case. Ehhh? A lateral distance is not an altitude but an altitude is a lateral distance? I would say you are naïve if you believe, that the attorney pilot will fail to read § 91.119(c) the way I have? Most judges are attorneys. ... No intelligent person will read § 91.119(c) the way you have. That is not an opinion. Larry, are you unable to address the issues raised? To what issue do you refer? The sentences above that end with a question mark. Your interpretation of the FAR is not incorrect. Mine could be reasonably expected to be employed by an attorney. Your misinterpretation of the FAR could not reasonably be expected to be employed by anyone regardless of profession. Surely, you must agree that there is room for differing interpretations among the FARS. Among those discussed here there is room for interpretation only on what constitutes a sparsely populated area. If you find another person that shares your interpretation of altitude you have found a fellow idiot. We've both expressed our views on this subject. I see no reason for further discussion; nothing will change. It's not a matter of opinion. |
#114
On Sat, 10 May 2008 09:04:10 -0500, "Steven P. McNicoll"
wrote in : "Larry Dighera" wrote in message .. . On Sat, 10 May 2008 07:30:42 -0500, "Steven P. McNicoll" wrote in : "Steven P. McNicoll" wrote in message news:GcWdnW_sPKM6X4TVnZ2dnUVZ_tWtnZ2d@earthlink .com... "Larry Dighera" wrote in message ... I understand what § 91.119(c) says. An attorney will understand it too. You only think that you understand it. § 91.119 Minimum safe altitudes: General. Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes: (c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. It says that over open water or sparsely populated areas an aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. Implicit in that statement is the lack of any lower altitude limit, with the exception of being in the proximity of a person, vessel, vehicle, or structure. But there is some ambiguity. The only ambiguity is in what constitutes a sparsely populated area. The fact that the first sentence states that an aircraft may not be operated below the following altitudes can not possibly apply to operation laterally distant from a person, vessel, vehicle, or structure, because a lateral distance is not an altitude. If the wording had included 'person, vessel, vehicle, or structure LOCATED ON THE GROUND', perhaps it's intent would have been clearer, but the language as written fails to restrict the implied 500' lateral limit from being applied at altitude, IMO. "Fails to restrict the implied 500' lateral limit from being applied at altitude" from what? A person that is not in an aircraft? An airborne vessel? An airborne vehicle other than an aircraft? An airborne structure? What type of vessels are operated on the GROUND? In the subject case (presumably over a sparsely populated area) the F-16 was alleged to have been operated in less than 500' lateral proximity to a vehicle, another aircraft in this case. Ehhh? A lateral distance is not an altitude but an altitude is a lateral distance? I would say you are naïve if you believe, that the attorney pilot will fail to read § 91.119(c) the way I have? Most judges are attorneys. ... No intelligent person will read § 91.119(c) the way you have. That is not an opinion. Larry, are you unable to address the issues raised? To what issue do you refer? The sentences above that end with a question mark. Your interpretation of the FAR is not incorrect. Mine could be reasonably expected to be employed by an attorney. Your misinterpretation of the FAR could not reasonably be expected to be employed by anyone regardless of profession. Surely, you must agree that there is room for differing interpretations among the FARS. Among those discussed here there is room for interpretation only on what constitutes a sparsely populated area. If you find another person that shares your interpretation of altitude you have found a fellow idiot. We've both expressed our views on this subject. I see no reason for further discussion; nothing will change. It's not a matter of opinion. How much experience have you had arguing cases in court? |
#115
"Larry Dighera" wrote in message ... How much experience have you had arguing cases in court? None. Please explain your conclusion that altitude is a lateral distance by disclosing your analysis. |
#116
On Sat, 10 May 2008 09:28:03 -0500, "Steven P. McNicoll"
wrote in : "Larry Dighera" wrote in message .. . How much experience have you had arguing cases in court? None. That's why you don't understand my position. Please explain your conclusion that altitude is a lateral distance by disclosing your analysis. Of course, that is your inference, not my conclusion. If one regulation prohibits an aircraft from approaching closer than 500' to a person or structure located on the ground (that distance includes laterally as well as vertically), why do you believe that that distance would not be applicable to aircraft in flight? If the FAA had grounds for the former, why wouldn't they be applicable in the latter? Do the reasons for the prohibition against "getting too close" to people or structures located on the ground not apply in flight? If not, why not? Just as an aside to provide an example of how the court and the NTSB's interpretations may differ, I offer the court's recent decision (see my article on that subject) in the Torrance helo crashes. The NTSB found the pilot to be the cause of the mishap, but the court found the controllers culpable. Who's right? Who's likely to collect damages from whom? Courts can be capricious. A successful attorney knows that, and uses it to his advantage. |
#117
... On Sat, 10 May 2008 09:28:03 -0500, "Steven P. McNicoll" wrote in : "Larry Dighera" wrote in message . .. How much experience have you had arguing cases in court? None. That's why you don't understand my position. How much experience have you had arguing cases in court? Please explain your conclusion that altitude is a lateral distance by disclosing your analysis. Of course, that is your inference, not my conclusion. If one regulation prohibits an aircraft from approaching closer than 500' to a person or structure located on the ground (that distance includes laterally as well as vertically), why do you believe that that distance would not be applicable to aircraft in flight? Because the lateral distance between aircraft in flight is not an altitude and is covered by another regulation. Didn't you recently criticize someone for answering your question with another question? Why don't you practice what you preach? If the FAA had grounds for the former, why wouldn't they be applicable in the latter? Because the former applies to the surface and the latter applies in flight. If you don't believe that the "person, vessel, vehicle, or structure" of FAR 91.119 is limited to persons, vessels, vehicles, and structures on the surface, then please explain what persons that are not aboard aircraft, airborne vessels, airborne vehicles other than aircraft, and airborne structures that are covered by it. Do the reasons for the prohibition against "getting too close" to people or structures located on the ground not apply in flight? No. Just as an aside to provide an example of how the court and the NTSB's interpretations may differ, I offer the court's recent decision (see my article on that subject) in the Torrance helo crashes. The NTSB found the pilot to be the cause of the mishap, but the court found the controllers culpable. Who's right? Who's likely to collect damages from whom? Courts can be capricious. A successful attorney knows that, and uses it to his advantage. I didn't read it. If the aircraft were operating where ATC has responsibility for separation the controllers were probably at fault. If they were operating where the pilots were responsible for separation then at least one of the pilots was probably at fault. Given that the NTSB tends to have a better understanding of aviation than judges it's likely the NTSB's finding is correct and the judge's is wrong. |
#118
"Larry Dighera" wrote in message ... How much experience have you had arguing cases in court? Over the years, I've argued more than a couple of dozen I'd reckon. I win about half of them. You must have had a slam dunk case each time. Why do you have so much trouble with the law? Because the lateral distance between aircraft in flight is not an altitude But that FAR is not strictly limited to regulating altitude, as it specifies a hemispherical distance. After 45 degrees the 500' limitation is more lateral than vertical. Altitude is a vertical distance, not a lateral distance, but 91.119(c) also contains a lateral restriction by implication, so it is obviously not limited exclusively to governing altitude. FAR 91.119 IS strictly limited to regulating altitude. FAR 91.119(c) simply states that a pilot may not descend below 500 AGL if doing so would be within 500 feet of a person, vessel, vehicle, or structure. and is covered by another regulation. To which particular regulation(s) that addresses lateral distance between aircraft are you referring? FAR 91.111. Didn't you recently criticize someone for answering your question with another question? Why don't you practice what you preach? My question was more socratic than literal. Further, in the above instance you requested my explanation; you did not ask a question; notice the lack of a question mark at the end of your sentence. So a sentence in an interrogative form, addressed to someone in order to get information in reply, is not a question unless it ends with a question mark? You've ignored many interrogatives that DID end with question marks in this thread. If you truly desire to debate the issue, I will continue to indulge you. But if your desire is to attack me personally, or attempt to feign a sincere interest in the subject as a thinly masked veil to conceal your attempt to establish your superiority, or some other nonsense, you will not find my future responses forthcoming. Indulge me, I have no desire to attack anyone personally. I don't have time for such nonsense. Because the former applies to the surface and the latter applies in flight. So you believe the grounds for the hemispherical distance restriction imposed by FAA regulation are not valid nor applicable to lateral distance restriction? The hemispherical distance restriction of FAR 91.119(c) applies between an aircraft and a person, vessel, vehicle, or structure on the surface. It does not apply between aircraft and persons, vessels, vehicles, or structures at altitude. If not, why not? Because the anti-gravity technology necessary to support these things at altitude has yet to be invented. Clearly, 91.229(c) implies a lateral distance, does it not? There is no FAR 91.229. If you don't believe that the "person, vessel, vehicle, or structure" of FAR 91.119 is limited to persons, vessels, vehicles, and structures on the surface, then please explain what persons that are not aboard aircraft, airborne vessels, airborne vehicles other than aircraft, and airborne structures that are covered by it. Huh? Amnesia? On 4/23/2008 you posted: I understand what § 91.119(c) says. An attorney will understand it too. § 91.119 Minimum safe altitudes: General. Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes: (c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. It says that over open water or sparsely populated areas an aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. Implicit in that statement is the lack of any lower altitude limit, with the exception of being in the proximity of a person, vessel, vehicle, or structure. But there is some ambiguity. The fact that the first sentence states that an aircraft may not be operated below the following altitudes can not possibly apply to operation laterally distant from a person, vessel, vehicle, or structure, because a lateral distance is not an altitude. If the wording had included 'person, vessel, vehicle, or structure LOCATED ON THE GROUND', perhaps it's intent would have been clearer, but the language as written fails to restrict the implied 500' lateral limit from being applied at altitude, IMO. In the subject case (presumably over a sparsely populated area) the F-16 was alleged to have been operated in less than 500' lateral proximity to a vehicle, another aircraft in this case. I would say you are naïve if you believe, that the attorney pilot will fail to read § 91.119(c) the way I have? Most judges are attorneys. ... And I responded with: I understand what § 91.119(c) says. An attorney will understand it too. You only think that you understand it. § 91.119 Minimum safe altitudes: General. Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes: (c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. It says that over open water or sparsely populated areas an aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. Implicit in that statement is the lack of any lower altitude limit, with the exception of being in the proximity of a person, vessel, vehicle, or structure. But there is some ambiguity. The only ambiguity is in what constitutes a sparsely populated area. The fact that the first sentence states that an aircraft may not be operated below the following altitudes can not possibly apply to operation laterally distant from a person, vessel, vehicle, or structure, because a lateral distance is not an altitude. If the wording had included 'person, vessel, vehicle, or structure LOCATED ON THE GROUND', perhaps it's intent would have been clearer, but the language as written fails to restrict the implied 500' lateral limit from being applied at altitude, IMO. "Fails to restrict the implied 500' lateral limit from being applied at altitude" from what? A person that is not in an aircraft? An airborne vessel? An airborne vehicle other than an aircraft? An airborne structure? What type of vessels are operated on the GROUND? In the subject case (presumably over a sparsely populated area) the F-16 was alleged to have been operated in less than 500' lateral proximity to a vehicle, another aircraft in this case. Ehhh? A lateral distance is not an altitude but an altitude is a lateral distance? I would say you are naïve if you believe, that the attorney pilot will fail to read § 91.119(c) the way I have? Most judges are attorneys. ... No intelligent person will read § 91.119(c) the way you have. That is not an opinion. Do the reasons for the prohibition against "getting too close" to people or structures located on the ground not apply in flight? No. For reference, here is 91.119(c): (c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. Clearly, the last sentence of (c) implies a lateral component, as there is no altitude restriction over open water and sparsely populated areas, and a pilot may fly as low as he pleases there. As long as he is not within 500' of any person, vessel, vehicle, or structure, yes. Presumably there was a reason the FAA chose to implement a 500' proximity limit in 91.119(c). But you believe that that reason or justification for that restriction is inapplicable to two aircraft in flight? I don't believe I said anything about any reason or justification for anything. I'm not referring to the jurisdiction of FAR 91,119(c); I'm referring to the _justification_ for the distance limitation contained in it. What of it? |
#119
m... "Larry Dighera" wrote in message ... How much experience have you had arguing cases in court? Over the years, I've argued more than a couple of dozen I'd reckon. I win about half of them. You must have had a slam dunk case each time. Why do you have so much trouble with the law? Because the lateral distance between aircraft in flight is not an altitude But that FAR is not strictly limited to regulating altitude, as it specifies a hemispherical distance. After 45 degrees the 500' limitation is more lateral than vertical. Altitude is a vertical distance, not a lateral distance, but 91.119(c) also contains a lateral restriction by implication, so it is obviously not limited exclusively to governing altitude. FAR 91.119 IS strictly limited to regulating altitude. FAR 91.119(c) simply states that a pilot may not descend below 500 AGL if doing so would be within 500 feet of a person, vessel, vehicle, or structure. and is covered by another regulation. To which particular regulation(s) that addresses lateral distance between aircraft are you referring? FAR 91.111. Didn't you recently criticize someone for answering your question with another question? Why don't you practice what you preach? My question was more socratic than literal. Further, in the above instance you requested my explanation; you did not ask a question; notice the lack of a question mark at the end of your sentence. So a sentence in an interrogative form, addressed to someone in order to get information in reply, is not a question unless it ends with a question mark? You've ignored many interrogatives that DID end with question marks in this thread. If you truly desire to debate the issue, I will continue to indulge you. But if your desire is to attack me personally, or attempt to feign a sincere interest in the subject as a thinly masked veil to conceal your attempt to establish your superiority, or some other nonsense, you will not find my future responses forthcoming. Indulge me, I have no desire to attack anyone personally. I don't have time for such nonsense. Because the former applies to the surface and the latter applies in flight. So you believe the grounds for the hemispherical distance restriction imposed by FAA regulation are not valid nor applicable to lateral distance restriction? The hemispherical distance restriction of FAR 91.119(c) applies between an aircraft and a person, vessel, vehicle, or structure on the surface. It does not apply between aircraft and persons, vessels, vehicles, or structures at altitude. If not, why not? Because the anti-gravity technology necessary to support these things at altitude has yet to be invented. Clearly, 91.229(c) implies a lateral distance, does it not? There is no FAR 91.229. If you don't believe that the "person, vessel, vehicle, or structure" of FAR 91.119 is limited to persons, vessels, vehicles, and structures on the surface, then please explain what persons that are not aboard aircraft, airborne vessels, airborne vehicles other than aircraft, and airborne structures that are covered by it. Huh? Amnesia? On 4/23/2008 you posted: I understand what § 91.119(c) says. An attorney will understand it too. § 91.119 Minimum safe altitudes: General. Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes: (c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. It says that over open water or sparsely populated areas an aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. Implicit in that statement is the lack of any lower altitude limit, with the exception of being in the proximity of a person, vessel, vehicle, or structure. But there is some ambiguity. The fact that the first sentence states that an aircraft may not be operated below the following altitudes can not possibly apply to operation laterally distant from a person, vessel, vehicle, or structure, because a lateral distance is not an altitude. If the wording had included 'person, vessel, vehicle, or structure LOCATED ON THE GROUND', perhaps it's intent would have been clearer, but the language as written fails to restrict the implied 500' lateral limit from being applied at altitude, IMO. In the subject case (presumably over a sparsely populated area) the F-16 was alleged to have been operated in less than 500' lateral proximity to a vehicle, another aircraft in this case. I would say you are naïve if you believe, that the attorney pilot will fail to read § 91.119(c) the way I have? Most judges are attorneys. ... And I responded with: I understand what § 91.119(c) says. An attorney will understand it too. You only think that you understand it. § 91.119 Minimum safe altitudes: General. Except when necessary for takeoff or landing, no person may operate an aircraft below the following altitudes: (c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. It says that over open water or sparsely populated areas an aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. Implicit in that statement is the lack of any lower altitude limit, with the exception of being in the proximity of a person, vessel, vehicle, or structure. But there is some ambiguity. The only ambiguity is in what constitutes a sparsely populated area. The fact that the first sentence states that an aircraft may not be operated below the following altitudes can not possibly apply to operation laterally distant from a person, vessel, vehicle, or structure, because a lateral distance is not an altitude. If the wording had included 'person, vessel, vehicle, or structure LOCATED ON THE GROUND', perhaps it's intent would have been clearer, but the language as written fails to restrict the implied 500' lateral limit from being applied at altitude, IMO. "Fails to restrict the implied 500' lateral limit from being applied at altitude" from what? A person that is not in an aircraft? An airborne vessel? An airborne vehicle other than an aircraft? An airborne structure? What type of vessels are operated on the GROUND? In the subject case (presumably over a sparsely populated area) the F-16 was alleged to have been operated in less than 500' lateral proximity to a vehicle, another aircraft in this case. Ehhh? A lateral distance is not an altitude but an altitude is a lateral distance? I would say you are naïve if you believe, that the attorney pilot will fail to read § 91.119(c) the way I have? Most judges are attorneys. ... No intelligent person will read § 91.119(c) the way you have. That is not an opinion. Do the reasons for the prohibition against "getting too close" to people or structures located on the ground not apply in flight? No. For reference, here is 91.119(c): (c) Over other than congested areas. An altitude of 500 feet above the surface, except over open water or sparsely populated areas. In those cases, the aircraft may not be operated closer than 500 feet to any person, vessel, vehicle, or structure. Clearly, the last sentence of (c) implies a lateral component, as there is no altitude restriction over open water and sparsely populated areas, and a pilot may fly as low as he pleases there. As long as he is not within 500' of any person, vessel, vehicle, or structure, yes. Presumably there was a reason the FAA chose to implement a 500' proximity limit in 91.119(c). But you believe that that reason or justification for that restriction is inapplicable to two aircraft in flight? I don't believe I said anything about any reason or justification for anything. I'm not referring to the jurisdiction of FAR 91,119(c); I'm referring to the _justification_ for the distance limitation contained in it. What of it? Larry, if you find these questions are too difficult please say so. I'll try to rephrase them using smaller words. |
#120
Steven P. McNicoll wrote:
Larry, if you find these questions are too difficult please say so. I'll try to rephrase them using smaller words. I think something shiny must have caught his eye. |
Similar Threads | ||||
USAF F-16 Instructor Discusses Flying Into MOAs | Larry Dighera | Piloting | 39 | April 8th 08 07:03 PM |
US Military now wants more northern NY airspace to expand those MOAs | Peter R. | Piloting | 7 | June 14th 07 01:30 PM |
Gliders, transponders, and MOAs | Greg Arnold | Soaring | 2 | May 26th 06 05:13 PM |
There has _got_ to be a book that discusses 'practical welding' | Mike | Owning | 2 | April 16th 06 11:15 PM |
Mayor Daley discusses airport on Today Show 2/26 | Jenny Wrinkler | Piloting | 4 | February 28th 04 05:15 AM |
