AvGas vs. Regular gas for Pawnee?
Old November 29th 05, 02:06 AM posted to rec.aviation.soaring
Default AvGas vs. Regular gas for Pawnee?
That's what we are running also Frank.. but we changed from the 1A200
propeller to the 1P235 propeller, both listed on the TCDS for the PA-25 with
the O-540 engine. The 1P235 is lighter in weight and also provides an
additional 60fpm climb rate at max GW. We are running about 1250 lbs below
Max GW in our tow configuration. The old propeller was totaled in the prop
strike which drove us to a rebuild on the engine. BT
"Frank Whiteley" wrote in message
Synopsis from our chief tow pilot
"Per Howard Kron's current STC (which I bought and is our basis):
Higher compression pistons (but not actually THAT high; 90/96 or
100LL required); RPM max still 2575, same as 235; prop replaced due to
hub damage ..... which was not previously
picked up, and Factory New prop pitched to the original factory 84-52
(had been whacked back to ~49 pitch).
Net effect, much stronger, climbs like a raped ape. The AirCare
twicepipes (i.e., dual exhaust, NO!! mufflers) STC probably helps
significantly, too. In our operation, 65-68kts TAS is right at redline.
If anyone wants faster, they'll climb slower, owing to
too-flat AOT, and probably have to throttle back to stay legal."
I recall some discussion that the 250 STC is probably a better option
than the 260 (we couldn't find a core), as the 260 has a jump in fuel
burn for the extra 10hp. Apparently a lot of the 260hp cores are on
those air boats we all saw in Louisiana and Mississippi after Katrina,
with no maintenance records and a lot of swamp water exposure.
Frank Whiteley
Old November 30th 05, 05:31 PM posted to rec.aviation.soaring
We burned auto gas in 235 Pawnees 150 Super cub and 230 hp C-182e for
20 years and an estimated 15,000+ hours .
Up side:
We never had an engine that did not make it to TBO. ( At least 8
engines that I can recall)
We had 4 mid life cylinder changes do to cylinder head cracks. (4
cylinders total!)
We saw no difference in performance over 100ll.
No- lead fouling and build up in spark plugs.
As a conservative estimate, we burned over 240,000 gallons with an
average savings of 1.50 per gallon ( when I figure the off road gas tax
refund) is roughly $360,000.00 over
20 years. This is about what my fleet of 8 aircraft is worth today.
Down side:
Mo gas stinks.
Burns dirty. Leaves black soot on belly instead of gray.
Some times it is difficult to get a fuel company to agree to sell it
for the use in aircraft.
I had to switch back to AV gas last year because in California MTBE
fuels are outlawed
and Alcohol based fuels are not approved for airplanes ( alcohol
suspends water).
It was a nice run while it lasted.
I should mention that we operate from a near sea level, 2000 ft runway
and find that 235 HP is quite adequate.
Rex Mayes
Williams Soaring Center, Williams Ca
(formerly Lagoon Valley Soaring, Vacaville Ca)
Old December 1st 05, 02:39 AM posted to rec.aviation.soaring
Nevada still has real auto gas, at least in Douglas County (Minden).
Has anyone tried using water to remove the alcohol in California gas? To do
that, you'd need to agitate the fuel water mixture, the alcohol has a higher
affinity to water than to gasoline, so comes out of suspension in the gas
and joins the water.
Drain water/alcohol from bottom of tank and what remains should be usable
gasoline.
bumper
"Rex" wrote in message
Up side:
cylinders total!)
Down side:
Mo gas stinks.
fuels are outlawed
suspends water).
Rex Mayes
Old December 1st 05, 04:26 AM posted to rec.aviation.soaring
I think we may be on the wrong track here. If water is suspected in a cars
fuel system, you add ethanol to get rid of it. The alcohol combines with
the water and then with the gasoline. With enough ethanol present, the
water/ethanol mixes with gasoline and is burned away.
It used to be when there was no ethanol in gasoline, water would condense in
the tanks and freeze in cold weather blocking the fuel system. You could
buy cans of "fuel anti-freeze" (ethanol) at auto parts stores to get rid of
the water. Now all auto fuel contains some ethanol anyway so no need to use
the stuff.
As I understand it, the reason ethanol in airplane fuel is bad is that it
dissolves aluminum and makes elastomer seals in the fuel system swell until
leaks appear. A couple of tries to burn straight ethanol back in the 1970's
resulted in badly damaged airplanes.
Bill Daniels
"bumper" wrote in message ...
do
higher
gasoline.
bumper
Up side:
cylinders total!)
Down side:
Mo gas stinks.
fuels are outlawed
suspends water).
Rex Mayes
Old December 1st 05, 05:12 AM posted to rec.aviation.soaring
"Bill Daniels" wrote in message
A common method to test gasoline for presence of alcohol is to put a small
amount of water, about 10% by volume, in a test tube or similar container.
Add suspect gasoline and shake. If the water level appears to rise, it's due
to alcohol coming out of solution with the gasoline and joining with the
water. If there's no alcohol, the water level remains the same.
bumper
Old December 1st 05, 08:41 PM posted to rec.aviation.soaring
Bumper and Bill,
I am not a chemical engineer but I think that you are
both on the right track. The ethanol aborsbs the water
and thus makes it 'burnable' but I think it still is
in the bottom of the tank. Corrections welcome. I
do remember that we used to pour straight water into
the carburetor to 'clean' the exhaust valves! Made
it run rough for a second or two but really did a good
job of steam cleaning the carbon off of them!)
At 05:18 01 December 2005, Bumper wrote:
'Bill Daniels' wrote in message
is to put a small
the same.
bumper
Avgas STC Mike Granby Owning 12 September 6th 05 07:18 PM
Your free AvGas fillup at Dodge Center MN (TOB) July Sunday 31, AM abripl Piloting 121 August 10th 05 01:08 PM
Avgas price and the light plane ownership M Owning 56 July 10th 05 04:55 AM
Avgas Prices aluckyguess Piloting 14 May 6th 05 07:23 AM
Regular Passenger Service From San Jose to Sacramento? CHANGE USERNAME TO westes Piloting 23 November 28th 04 04:10 AM
