Help... 337 process/Musketeer Sport
Old March 18th 05, 06:41 PM
dlevy
Default Help... 337 process/Musketeer Sport
Just a shot in the dark.....
I'm in the process of overhauling the O-320-E2C (150 hp) in my '68 Musketeer
Sport, model 19A, s/n MB-318. There is an STC available from Lycon to
install pistons in the O-32-E2C to increase output to 160 hp. This has been
done many times in the past on these airframes however the FAA has changed
the rules.
I need a 337 to install the upgraded engine on the airframe. I have two
examples of similar 337 however I now need copies of the "regional
engineering concurrence that the inspector had at his disposal in order for
him to approve the alteration".
Can anyone decipher that and point me in the direction of getting my grubby
little hands on this document?
Thanks.
Old March 18th 05, 09:13 PM
Musketeer
to
has been
changed
the rules.
two
order for
grubby
It sounds like your trying to gather info required for a field
approval. If you bought the STC from Lycon, it should have all the
data necessary for your mechanic to fill out the 337. The whole point
of the STC is that they are pre-approved if you install it according to
the STC documentation.
I may be wrong here, but every STC I've had installed in a plane did
not require any other documentation (for the 337) other than what was
provided with the STC.
Old March 18th 05, 09:27 PM
Steve Foley
You need 2 STCs. One for the engine, and one to install the higher power
When I did the same thing to my Cherokee, I got the engine STC from
Mattituck and the Airframe STC from AMR&D.
If you don't have an STC, you need to get a field approval.
Old March 18th 05, 09:57 PM
dlevy
Yep.
"Steve Foley" wrote in message
news:vJH_d.8906$Ue6.6713@trndny04...
Old March 18th 05, 11:14 PM
dlevy wrote:
Yep.
OK, I get it now. I was assuming that you had the airframe STC as
well as the engine STC. Is there no STC available for your airframe?
Old March 18th 05, 11:49 PM
dlevy
There is no STC for the installation of the modified engine in the airframe.
Old March 21st 05, 02:36 PM
dlevy
Done all that.
"Ronald Limbaugh" wrote in message
hlink.net...
Check out www.beechaeroclub.org or ask the group at
I believe they have the 337
insurance for Sport Pilots! Cub Driver Piloting 4 September 11th 04 01:14 AM
Will US Sport Pilot be insurable? Mark James Boyd Soaring 12 November 29th 03 03:57 AM
Motorgliders (long) JJ Sinclair Soaring 98 October 9th 03 10:11 PM
Sport Pilot (was SoCal CFIGs needed. M B Soaring 1 September 30th 03 04:21 AM
Latest Newsletter Pipistrel Motorgliders Michael Coates Soaring 20 September 19th 03 01:25 AM
