Roger Halstead wrote: When you get this many they nest anywhere they can find. They like the crawfish holes along the ditch, but they will build above ground as well. The things are terrible around here. I know a guy who had so much trouble with them that he set up a long row of traps along the edge of his property. I guess they're pheremone based with some kind of opening that yellowjackets can't get out of. His problem then was that the traps filled up so fast and then you have to dispose of thousands of yellowjackets... -- Ben Jackson http://www.ben.com/ |
Roger Halstead wrote: I used a whole case of "Wasp and Hornet Killer" two years ago. The stuff that is advertised to shoot 25 feet. (You do need the distance). The last two years the Local Lowe's outlet has been bringing the stuff in by the semi load. It sells fast too:-)) Lowes. Wasp&Hornet Killer. Got it - thanks a bunch. George Patterson If you don't tell lies, you never have to remember what you said. |
On Tue, 11 May 2004 02:59:21 GMT, "G.R. Patterson III"
wrote: Roger Halstead wrote: I used a whole case of "Wasp and Hornet Killer" two years ago. The stuff that is advertised to shoot 25 feet. (You do need the distance). The last two years the Local Lowe's outlet has been bringing the stuff in by the semi load. It sells fast too:-)) Lowes. Wasp&Hornet Killer. Got it - thanks a bunch. There are several brands (and kinds) of Wasp and Hornet Killer sold widely. Make sure you get the one(s) that shoot a stream about 25 feet. They also have some that is a foam you can use on nests (after dark). Doesn't work worth a darn when they are chasing you. The brand I purchased was "Spectracide" and I'm pretty sure "Black Flag" makes something similar. Net wt is 15 oz. There's no sticker on the can, but I believe it was $4. something. Stuff works, but it can be like shooting skeet. I had a bunch of them take exception to my desire to eliminate them. They were coming out of a hole in the roof about head high (I was on a step ladder) and headed straight for me. None made it, but I'd guess there were over 400 laying on the roof between me and the hole. It's called a strong incentive to shoot straight. Good Luck, Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com George Patterson If you don't tell lies, you never have to remember what you said. |
Similar Threads | ||||
Cub aileron hinges | minot piper e | Aviation Marketplace | 0 | October 23rd 04 03:51 AM |
FA: M18B Dromader Flap & Aileron | BFC | Aviation Marketplace | 0 | September 24th 04 04:29 PM |
Zenith 601XL aileron | VideoFlyer | Home Built | 0 | June 1st 04 12:35 AM |
Need aileron | OSKI 3 | Owning | 0 | September 15th 03 07:46 PM |
Need Aileron | OSKI 3 | Aviation Marketplace | 0 | September 15th 03 07:45 PM |
