Mechanical Vario
Old September 23rd 07, 06:25 PM posted to rec.aviation.soaring
Jeff Runciman
Default Mechanical Vario
This question was posted earlier but I was hoping for
a few more responses.
Do I put a mechanical vario or do I save space on the
panel.
Would love to hear what people have in their panel.
Jeff
Old September 23rd 07, 07:19 PM posted to rec.aviation.soaring
Bob Whelan[_2_]
panel.
Apparently I feel a need to start a religious war...
Electron movement can cease (open circuit, low battery, component
failure), become too energetic (short), pneumatics can fail (blockage,
leak). Everything has a life.
Which failure modes have you encountered most often? Which have you
heard people complain about most frequently? Have you ever heard of a
mechanical vario *suddenly* dying from an internal (i.e. non-pneumatic)
cause? Do you feel comfortable with all your panel eggs in an
electronic basket? How much thought to true redundancy have you given?
Your answers to questions as these may clarify your views.
Any approach is a double-edged sword, and there will be some who
(rightly) point out that frequency of failure is somewhat related to
frequency of use...and these days (both discrete-component based and
IC-basd) electrics are ubiquitous in sailplanes, and thus a
frequency-of-failure based assessment is to some extent invalid. That
noted, when I got into soaring, electric varios were still a newfangled
item, yet despite the relatively low frequency of them in panels, there
seemed to me to be an inordinate frequency of complaints about electric
(radio, cario) failures. IMHO, that's still true today, probably
because electric systems a a) ubiquitous, b) seemingly simple and
relatively foolproof for any basically-educated-hack to implement, but
c) are in fact complex (chemically, physically, electronically,
conceptually).
Each of my personally-owned sailplanes when purchased had real
electrical systems in them, including the one I've flown since 1981.
Eventually its radio died, then its (uncompensated, used only for audio)
Ball electric vario. Today I use a handheld radio, and one day I hope
to remember to borrow my wife's Malletec for its audio. Only one person
ever has criticized my thermal etiquette (his experienced passenger
later privately told me he disagreed with the criticism), and my fun
meter has never felt seriously handicapped by the absence of electronic
input. My Sage continues to work perfectly, accompanied by the usual
A/S, (sticky) altimeter, and (little-used) whiskey compass. There are
at least three naked instrument holes in the panel.
Sometimes I feel like a dinosaur.
Regards,
Bob - a K.I.S.S. fan - Whelan
Old September 24th 07, 07:34 AM posted to rec.aviation.soaring
Roger Worden
Just recently I experienced a low battery situation which affected the
electronic vario in my club ship. The vario did not just fail, it started
giving me unreasonable readings. Eventually I figured it out when the needle
started swinging wildly - I knew the battery was getting low but it took a
few minutes to recognize the wierd behavior. The ship did not have a backup
vario installed, but I had an electronic micro-vario clipped to my hat.
DEFINITELY have a backup of some sort if you're going cross-country... as
others said, the choice of type is up to you.
Roger
"Bob Whelan" wrote in message
panel.
Which failure modes have you encountered most often? Which have you heard
cause? Do you feel comfortable with all your panel eggs in an electronic
Any approach is a double-edged sword, and there will be some who (rightly)
point out that frequency of failure is somewhat related to frequency of
use...and these days (both discrete-component based and IC-basd) electrics
are ubiquitous in sailplanes, and thus a frequency-of-failure based
assessment is to some extent invalid. That noted, when I got into
soaring, electric varios were still a newfangled item, yet despite the
relatively low frequency of them in panels, there seemed to me to be an
inordinate frequency of complaints about electric (radio, cario) failures.
IMHO, that's still true today, probably because electric systems a a)
ubiquitous, b) seemingly simple and relatively foolproof for any
basically-educated-hack to implement, but c) are in fact complex
(chemically, physically, electronically, conceptually).
Each of my personally-owned sailplanes when purchased had real electrical
systems in them, including the one I've flown since 1981. Eventually its
radio died, then its (uncompensated, used only for audio) Ball electric
vario. Today I use a handheld radio, and one day I hope to remember to
borrow my wife's Malletec for its audio. Only one person ever has
criticized my thermal etiquette (his experienced passenger later privately
told me he disagreed with the criticism), and my fun meter has never felt
seriously handicapped by the absence of electronic input. My Sage
continues to work perfectly, accompanied by the usual A/S, (sticky)
altimeter, and (little-used) whiskey compass. There are at least three
Regards,
Old September 24th 07, 07:04 AM posted to rec.aviation.soaring
ContestID67
I agree that having two varios is a must. 1) Electronic/electric/
audio as audio is invaluable. 2) Mechanical because it just won't
fail.
A side benefit is that my Cambridge 302 electronic vario is small
2-1/2" while my Mechanical is large 3-1/4". Thus I find myself
glancing at my large mechanical as it is easier to read but listen to
my electronic vario as it is easier to listen to ;-)
Best of both worlds.
- John "67R" DeRosa
Old September 23rd 07, 07:50 PM posted to rec.aviation.soaring
Bill Daniels
"Jeff Runciman" wrote in message
panel.
Jeff
I think most people would agree that a backup vario is needed. They would
disagree whether the backup should be mechanical or electronic. I chose a
Borgelt B40 electronic vario as a backup since it has an internal backup
battery, audio and averager.
As to whether electronic or mechanical varios are more reliable, I have 4
varios in my "Cabinet of Ancient Instruments". Three are mechanical and one
is electronic. All still work except that the mechanical instruments all
indicate +1 Kt. due to the radium paint on the needles becoming lighter with
age.
Any technology can fail but happily, failures are very rare in today's
instruments.
Bill Daniels
Old September 23rd 07, 09:41 PM posted to rec.aviation.soaring
Brian[_1_]
After flying most of an afternoon on just the Mechanical, after my
electric failed, I purchased a B40. I really like having the Audio on
my Backup Vario.
Brian
CFIIG/ASEL
HP16T N16VP
Old September 23rd 07, 08:06 PM posted to rec.aviation.soaring
Martin Gregorie[_1_]
panel.
What's already on your panel?
I have an SDI C4 with a Borgelt B.40 as backup (it has a 9v battery as
emergency power). I initially had a PZL mechanical as backup, but Mike
Borgelt recommends that you don't mix capacity (flow rate) instruments
with pressure sensing instruments on the same TE probe. The full story
is he
http://www.borgeltinstruments.com/in...stallation.pdf
on page 3 under "Pneumatic". Consequently I's just decided to swap the
PZL for a pressure sensing instrument when a used B.40 became available.
I'm very pleased with it. Its easy to read, has a fast response, and
complements the C4 very nicely. The B.40 is excellent for finding lift
while the C4 is very good for centering up thermals and for
inter-thermal cruise.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old September 23rd 07, 11:26 PM posted to rec.aviation.soaring
Dan G
On Sep 23, 6:25 pm, Jeff Runciman
panel?
Another way of asking the question could be "who has ever had their
primary vario fail?"
If my primary (electric audio) vario failed it most likely be because
of a general power failure, which would have also have left me without
radio, GPS and logger. If I did want to use a mechanical vario, I'd
have to go "heads down", which is something I just won't do. I'd fly
home via the seat of my pants.
So, no mechanical vario here.
I did once have a battery go flat on me as the previous pilots of this
club aircraft had not put the battery on charge and I'd not checked
the voltage during the DI - I learnt a lesson there. On another
occasion with another club aircraft the electric vario had broken but
it took a long time for it to be fixed and people were still getting
it out - I turned down flying it. Not interested in thermalling while
looking at a dial.
Dan
Old September 24th 07, 11:34 PM posted to rec.aviation.soaring
Brian[_1_]
snip
snip
I have had the general Power failure version.
I have also had the Bubble Bee impaled on the pitot failure. Since my
primary vario is internally compensated this gave it some very strange
readings. Fortunatly my B40 is compensated by a TE Probe.
Brian
CFIIG/ASEL
HP16T N16VP
Old September 24th 07, 01:04 AM posted to rec.aviation.soaring
Tony Verhulst
panel.
Just today, The vario indicator of my Cambridge 302 started pointinng
every which way except what was really happening (just after I told some
one how reliable it's been for the last 5 years :-) ), the audio worked
just fine. It sure was nice to have my Winter mechanical - although a
good electronic vario would have sufficed as well.
Tony V
WTB: CAI L-NAV readout meter and Sage or PZL mechanical vario. [email protected] Soaring 2 August 28th 07 03:18 AM
Placement of Mechanical Vario in Panel? V1 Soaring 3 July 29th 07 08:55 PM
Mechanical Vario or not? Fish Soaring 15 July 2nd 06 02:28 PM
Winter mechanical vario reading high Alan Meyer Soaring 13 April 13th 06 02:38 AM
Wanted: Used Mechanical Vario Tim Hanke Soaring 0 May 16th 05 05:35 PM
