I want to have a tailtank in my ASW20 and I have heard there is one.
Where would I get the paperwork and plans for the mod. gary |
![]() Where would I get the paperwork and plans for the mod. gary John Murray at Eastern Sailplanes had a kit at one time. Finding the solenoid switch may be a problem, but I think it is the same as a 12 volt lawn sprinkler set-up. 6 quart for about 12 lbs. is about right. I would do a proper W&B after installation and remember to dump it along with the wing water. JJ Sinclair |
Oops, John can be found at
JJ Sinclair |
With my weight !
![]() will not empty. One of our guys with a Discus fills the tailtank even without water in the wings,he has done a W&B and he is ok with this amount of weight in the tail. Saves his partners having to put lead in the cockpit. gary "JJ Sinclair" wrote in message ... Where would I get the paperwork and plans for the mod. gary John Murray at Eastern Sailplanes had a kit at one time. Finding the solenoid switch may be a problem, but I think it is the same as a 12 volt lawn sprinkler set-up. 6 quart for about 12 lbs. is about right. I would do a proper W&B after installation and remember to dump it along with the wing water. JJ Sinclair |
I think it is a better idea to add lead to the tail to put the c.g. where
you want it without water ballast in the wings. Then use your tail tank to counteract the water in the wings only. In this way you can drain the wings and the tail and still have the c.g. where you want it. Draining partial water in the tail and trying to guess at how much remains is inaccurate and unsafe, especially when trying to keep the c.g. near the aft limit. -Bob Korves "goneill" wrote in message ... With my weight ! ![]() will not empty. One of our guys with a Discus fills the tailtank even without water in the wings,he has done a W&B and he is ok with this amount of weight in the tail. Saves his partners having to put lead in the cockpit. gary "JJ Sinclair" wrote in message ... Where would I get the paperwork and plans for the mod. gary John Murray at Eastern Sailplanes had a kit at one time. Finding the solenoid switch may be a problem, but I think it is the same as a 12 volt lawn sprinkler set-up. 6 quart for about 12 lbs. is about right. I would do a proper W&B after installation and remember to dump it along with the wing water. JJ Sinclair |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
AH64 tail rotor | CivetOne | Rotorcraft | 3 | October 23rd 03 07:18 PM |
Long-range Spitfires and daylight Bomber Command raids (was: #1 Jet of World War II) | The Revolution Will Not Be Televised | Military Aviation | 20 | August 27th 03 09:14 AM |
Oshkosh Get together Roster - Sign in, please! | Bruce E. Butts | Piloting | 1 | July 26th 03 11:34 AM |
The prone postion for tail gunners versus turrets. | The Enlightenment | Military Aviation | 8 | July 22nd 03 11:01 PM |
