How to suspend a glider?
Old October 7th 08, 02:49 PM posted to rec.aviation.soaring
Frank Whiteley
Default How to suspend a glider?
On Oct 7, 5:49*am, "Paul Remde" wrote:
Hi Don,
Great idea! *I can't wait to see it! *I'd be glad to help.
Take a look at how the ASK-21 is hung at Stanton Airport. *My guess is that
the system used is over-designed by a factor of 10.
Without doing any calculations, I would recommend seat belt material rather
than canvas. *2 to 4 straps should do the job easily - I think. *They could
meet at the top of the glider where a cable could attach. *You should be
able to get strength ratings for it the material. You'd want to use a safety
factor of 4 or so (only use 1/4 the of the weight they can handle). *I'm not
giving you engineering advice, just my quick thoughts. *I imagine that
putting knots into the seat belts would reduce their strength dramatically.
Paul Remde
"Pete Smith" wrote in message
It is very common in continental Europe to suspend gliders from the hangar
roof to make full use of the space available. I'm sure someone who does
that will be along soon.
I have seen a Nimbus 3/4 strung up at a Swiss club.
At 06:28 07 October 2008, wrote:
Hi all,
Has anyone out there ever suspended a glider in the air without
resorting to the conventional method of airflow over the wings? I have
an opportunity to hang both of my Grob 103's in two malls over the
holiday season. I am pushing for having a Santa in the back and a
Rudolf leaning forward in the front, scarf trailing. Both canopies
will be off. I will have a Glider Ride Gift Certificate booth [not
quite directly] underneath. Some of you may have seen my Mall
Experiment article in the June 2008 issue of Soaring. Well, I'm
experimenting some more!
My first thought, unencumbered by either engineering training or good
advice, is to fabricate a heavy duty, white canvas sling, maybe 2 feet
wide, that would go where the fuselage dolly goes, in front of the
wings and as far aft as possible. The CG hook mechanism could be used
to attach to it also to protect against slippage. The sling would be
sewn proffessionally, providing a pair of rip-free, foolproof,
attachment points on each side. The remaining 50 lbs on the tail could
be handled with a wire running from this central sling support cable
45 degrees down to the horizontal stab attachment bolt at the top of
the verticle stab. The wings could have wires running from the wing
tip skid/tie downs to this central sling support cable at about 45
degrees also.
Thoughts?
Clearly the mall engineers and their insurance underwriters are going
to have the last word, but if any of you have advice/experience/
thoughts, I'd sure appreciate hearing from you. Oh yeah, the 103
weighs in at 850 lbs.
Thanks in advance,
Don Ingraham
http://www.crosscountrysoaring.com
Working load is normally 1/6 of breaking strength (except for winch
ropes);^).
Frank Whiteley
How to suspend a glider? [email protected] Soaring 26 October 15th 08 01:13 AM
Exporting a glider to/import a glider into Germany Pete Smith[_2_] Soaring 1 August 8th 08 09:33 AM
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider [email protected] Soaring 5 November 19th 06 11:08 PM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
Can I suspend an A-65 by the prop. flange? Michael Horowitz Home Built 6 March 13th 05 01:36 PM
