Bumper Miracle Slide
Old August 23rd 19, 01:34 AM posted to rec.aviation.soaring
Tango Eight
Default Bumper Miracle Slide
Installed this evening. Very nice. Pro-tip: a deburring tool is way faster than a file for taking the sharp edges off the tracks (but you'll still need a file for especially rough spots).
George, you're missing out!
T8
Old August 23rd 19, 02:28 AM posted to rec.aviation.soaring
Tom Watson
On Thursday, August 22, 2019 at 4:49:33 AM UTC-4, James Hogue wrote:
Yes, I have an unused kit. Contact me at julietsix at gmail dot com.
Cheers,
Thanks for responding Jim. I bought one from Cumulus.
Regards,
Tom
Old August 23rd 19, 02:41 AM posted to rec.aviation.soaring
but a squirt of Tri Flow Superior (bicycle chain lube also specified for certain rotor heads) does a pretty good job.
Also attracts and holds dirt. If you live in a gritty environment (i.e. Moriarty, NM) you learn to minimize the sticky stuff. Bumper's nylon rail guides do not gum up with abrasive residue.
Old August 23rd 19, 09:01 AM posted to rec.aviation.soaring
bumper[_4_]
Thanks for the reports on the SRS (Smooth Ramp Slider). In my quest to find more free time, I sold rights to the SRS, along with the MKIV yaw string and Quiet Vent, to Wings & Wheels.
BTW the SRS plastic slider is made of UHMW-PE, a long chain polymer has some unique properties, being almost as slippery as Teflon, yet is about the toughest most abrasion resistant plastic available. A one inch thick piece is said to stop a 45 ACP bullet. Should outlast the trailer - unless you spend your weekends sliding the ramp in and out. It is a "smile" after years of the Cobra ramp grind. :c)
Old August 23rd 19, 05:43 PM posted to rec.aviation.soaring
Dan Marotta
Hollow point or ball? :-D
Dan, 5J
Old August 24th 19, 02:16 AM posted to rec.aviation.soaring
bumper[_4_]
Dan, 5J
Armor piercing depleted uranium ball with tungsten penetrator. This stuff is able to pierce 43 pages of wet newspaper, no problem.
Old August 24th 19, 04:44 AM posted to rec.aviation.soaring
Jonathan St. Cloud
Dan, 5J
Define "depleted"
Old August 24th 19, 07:08 AM posted to rec.aviation.soaring
bumper[_4_]
On Friday, August 23, 2019 at 8:44:52 PM UTC-7, Jonathan St. Cloud wrote:
Define "depleted"
Depleted - Not all that once was. E.g. what happens to wind noise when you install a Quiet Vent, to altitude immediately prior to a land out, and to the grind after installing a Smooth Ramp Slider. :c) Mid 70's, not quite depleted, headed inexorably that-a-way.
https://en.wikipedia.org/wiki/Depleted_uranium
Sully Sullenberger - Miracle on the Hudson Stormin' Norman[_2_] Aviation Photos 0 November 4th 18 01:12 PM
Bumper stickers Ramy[_2_] Soaring 19 July 15th 18 04:03 AM
Bumper yaw string [email protected] Soaring 25 December 3rd 15 09:42 PM
Miracle Flight Phone Spam David Lesher General Aviation 1 July 16th 08 06:39 PM
Miracle before D-Day ArtKramr Military Aviation 0 February 6th 04 02:17 PM
