New SB (SB-G09) on elevator pushrods for most all Grobs
Old May 22nd 20, 09:00 AM posted to rec.aviation.soaring
Dave Harrison
Default New SB (SB-G09) on elevator pushrods for most all Grobs
At 14:17 05 May 2020, soaringjac wrote:
See the link below
http://www.ltb-lindner.com/g-102-ad-sb.html?
file=tl_files/ltb_lindner/pdf/G%20102%20LTA%20%26%20TM%2
0Englisch/SB-G09_elevator%20pushrod_200408.pdf
So did anybody find any evidence of corrosion in the pushrods ?
Old May 22nd 20, 01:27 PM posted to rec.aviation.soaring
Tony[_5_]
I checked our Twin Astir. No water or rust flakes came out of the drilled hole. Just to be sure I found a 5.5mm diameter wifi borescope on Amazon and had a look inside. Looked clean to me.
Old May 28th 20, 10:17 AM posted to rec.aviation.soaring
Eric Munk
AD published by EASA:
https://ad.easa.europa.eu/ad/2020-0121
  #24
Old May 29th 20, 02:51 AM posted to rec.aviation.soaring
Scott Williams[_2_]
Interesting, The original lindner documents exclude aluminum control rods, the EASA documents only has "steel" but is not as clear as Lindners exclusion.
Scott
  #25
Old May 29th 20, 02:58 AM posted to rec.aviation.soaring
Scott Williams[_2_]
Scott
That is the 103 twin II at least,
  #26
Old May 29th 20, 04:54 AM posted to rec.aviation.soaring
AS
Scott
Best to look at the serial number of your Grob. For the G103 there is a serial number range, that is excluded. The TN issued by Lindner spells out which serial numbers are affected or excluded.
Uli
'AS'
  #27
Old May 29th 20, 05:32 AM posted to rec.aviation.soaring
Charles Longley
Well it’s not a FAA AD yet. Anyone know if there’s a NPRM for it yet?
  #28
Old May 29th 20, 12:59 PM posted to rec.aviation.soaring
Out of 10 G102 and 103 in the clubs nearby, 2 needed their elevator rods to be replaced.
Christoph
  #29
Old May 29th 20, 02:47 PM posted to rec.aviation.soaring
soaringjac
Christoph
Where are the clubs located, what state?
  #30
Old May 29th 20, 09:57 PM posted to rec.aviation.soaring
Berlin area, Germany.
Elevator for Schweizer 2-22 Steve Soaring 7 December 8th 11 12:55 AM
(USA) WTB: ASW-27 elevator Tuno Soaring 1 May 12th 10 02:48 AM
Jammed Elevator Dale Piloting 43 September 14th 04 05:43 AM
Astir Elevator JD Soaring 0 May 10th 04 06:44 AM
K-13 TO k-7 elevator Vassilios Mazis Soaring 1 August 31st 03 07:25 PM
