#31
Perfect loop ping Viperdoc
"Maxwell" luv2^fly99@cox.^net wrote in news:kMQ1k.1482$js1.63
@newsfe24.lga: "Viperdoc" wrote in message ... Actually, if you read the posts, the quote is from gregvk, not me. No, actually it's from me, but he's just trolling anyway. Good grief, fjukktard. would you please go and look up the proper definition of a troll as defined by the only people who count, the trollz themselves? It's dificult enough trying to smack you over your pebble filled skull without you yelping that you're being kicked in the ass because you can't tell the difference. Bertie |
#32
"Bertie the Bunyip" wrote in message ... Good grief, fjukktard. would you please go and look up the proper definition of a troll as defined by the only people who count, the trollz themselves? Bertie No thanks. Just because you consider them to be the "gods" that define the Usenet, doesn't mean the rest of the world does. But it clearly defines your "wannabe" attitude, lamer. |
#33
"Bertie the Bunyip" wrote in message ... "Maxwell" luv2^fly99@cox.^net wrote in news:j1L1k.2527$yi.1807 @newsfe13.lga: What a pretentious bunch of nonsense. Haven't you old fools got anything better to do than run around posing on a message board? Well, we haven't got time enough to trail around after half a dozen old fools posing on a message board. Where is this message board, BTW? you mean the genital wart board you poast on? Berite Come on lips!!!! Can't you at least refrain from posting unless it's at least relevant to the conversation. You post more unrelated **** than anyone I have ever seen. Just because you can't shut up. |
#34
: "Bertie the Bunyip" wrote in message ... "Maxwell" luv2^fly99@cox.^net wrote in news:j1L1k.2527$yi.1807 @newsfe13.lga: What a pretentious bunch of nonsense. Haven't you old fools got anything better to do than run around posing on a message board? Well, we haven't got time enough to trail around after half a dozen old fools posing on a message board. Where is this message board, BTW? you mean the genital wart board you poast on? Berite Come on lips!!!! Can't you at least refrain from posting unless it's at least relevant to the conversation. Nope. You post more unrelated **** than anyone I have ever seen. Just because you can't shut up. Bwawhahwhahwhahwhahwhahhwhahwh! God I love usenet. Bertie Bertie |
#35
: "Bertie the Bunyip" wrote in message ... Good grief, fjukktard. would you please go and look up the proper definition of a troll as defined by the only people who count, the trollz themselves? Bertie No thanks. Just because you consider them to be the "gods" that define the Usenet, doesn't mean the rest of the world does. Nope, but they are the trollz who define trollz. But it clearly defines your "wannabe" attitude, lamer. Moi? I just poast. Tha's all. Bertie |
#36
Educating Maxwell, Part 2
On Jun 5, 5:49*am, "Viperdoc" wrote:
Actually, I'm not all that old, although I admit to a few grey hairs. When the high level acro pilots talk about shaving weight in their planes, I just say I'll go an a diet and lose 30 lbs. Regarding the blunt LE of the Extra, I thought the intent was to actually separate the air flow more quickly (or perhaps it is the squared off TE), in order to get a cleaner snap entry. When it does break it kind of shudders, especially at high speed, and just a slight release of the back (forward) pressure will get things going again. In fact, it's hard to accelerate a spin, especially to the right (at least in my plane), without it actually stopping the spin and starting to do a wallow-spiral. All I know is that it's a lot of fun to fly, a challenge to land, and I am very fortunate to be able to own one. Been tryin' to respond but having some trouble posting. I usually use 5.5/6 g for the initial/final pull in looping figures for contest flyings. I try to stay away from that burble you mention because it puts a very noticeable (to the judges) flat spot on the loop. I also float over the top a bit to make it round for the judges. I usually get decent scores on them but I've also noticed from working the judging line that there is an appalling lack of consistency in judging these things. Nik T. has been teaching an interesting method of spinning the Sukhoi. It also works ok in the Extra. The idea is to not wait for the airplane to drop into the spin but to fly it in. E.g., if you're spinning to the left, you fly to the point of spinning using 1/3 to 1/2 power, right above stalling speed. To begin the spin you gently push in left rudder in all the way, while simultaneously using a little forward and left stick to make the nose go down. You don't actually stall it! Leaving the throttle where it is at ~1/3, you then move the stick to the right, rear corner. You are now in a flat spin. You modulate the rate of rotation with rudder. To stop the spin on point, throttle to idle, full right rudder, stick towards right front corner. Draw your down line and recover. The power to idle is mainly for the judges - they get confused if they never hear you reduce power. ;-) Takes a lot of practice to get it right, but when you do, you find you have a lot more control of the position of the spin, rate of rotation and minimize altitude loss. All standard disclaimers apply. Please don't try this the first time from below 5k AGL. It's kinda fun to let it do several turns in the flat spin, but for competition, you don't need that. I love Extras. If I had known how nice they are, I might have skipped my detour into Yaks. I think they are easy to land compared to, say, the Pitts or the Yak-54. Yak-55 is the easiest of all tail wheel airplanes to land. Landing roll out tends to be a little long compared to the Sukhoi which stops very quickly even with no use of brakes. K l e i n |
#37
"Bertie the Bunyip" wrote in message ... "Maxwell" luv2^fly99@cox.^net wrote in : "Bertie the Bunyip" wrote in message ... Good grief, fjukktard. would you please go and look up the proper definition of a troll as defined by the only people who count, the trollz themselves? Bertie No thanks. Just because you consider them to be the "gods" that define the Usenet, doesn't mean the rest of the world does. Nope, but they are the trollz who define trollz. But it clearly defines your "wannabe" attitude, lamer. Moi? I just poast. Tha's all. Bertie Three! Three "make believes" in row. This is real progress. |
#38
"Maxwell" luv2^fly99@cox.^net wrote in news:vKU1k.3435$QI2.1108
@newsfe23.lga: "Bertie the Bunyip" wrote in message ... "Maxwell" luv2^fly99@cox.^net wrote in : "Bertie the Bunyip" wrote in message ... Good grief, fjukktard. would you please go and look up the proper definition of a troll as defined by the only people who count, the trollz themselves? Bertie No thanks. Just because you consider them to be the "gods" that define the Usenet, doesn't mean the rest of the world does. Nope, but they are the trollz who define trollz. But it clearly defines your "wannabe" attitude, lamer. Moi? I just poast. Tha's all. Bertie Three! Three "make believes" in row. This is real progress. OK **** chokula. Bertie |
#39
"Bertie the Bunyip" wrote in message ... "Maxwell" luv2^fly99@cox.^net wrote in : "Bertie the Bunyip" wrote in message ... "Maxwell" luv2^fly99@cox.^net wrote in news:j1L1k.2527$yi.1807 @newsfe13.lga: You post more unrelated **** than anyone I have ever seen. Just because you can't shut up. Bwawhahwhahwhahwhahwhahhwhahwh! God I love usenet. Bertie Bertie Aahhhh, back to unrelated. You have relapsed. |
#40
"Maxwell" luv2^fly99@cox.^net wrote in news:2LU1k.3436$QI2.284
@newsfe23.lga: "Bertie the Bunyip" wrote in message ... "Maxwell" luv2^fly99@cox.^net wrote in : "Bertie the Bunyip" wrote in message ... "Maxwell" luv2^fly99@cox.^net wrote in news:j1L1k.2527$yi.1807 @newsfe13.lga: You post more unrelated **** than anyone I have ever seen. Just because you can't shut up. Bwawhahwhahwhahwhahwhahhwhahwh! God I love usenet. Bertie Bertie Aahhhh, back to unrelated. You have relapsed. Nope. In any case, related, unrealted, it matters no one jot once I keep you poasting, fjukkwit... Bertie |
Similar Threads | ||||
outside loop | niceguy | Aviation Photos | 13 | August 9th 07 06:57 AM |
My Ground Loop | Reid & Julie Baldwin | Piloting | 53 | December 5th 05 11:29 PM |
More likely to ground loop? | [email protected] | Piloting | 16 | February 25th 05 03:21 PM |
AN-2 performing a loop | Maro_SK | Aerobatics | 1 | March 25th 04 08:18 PM |
What is a ground loop? | Mike | Piloting | 34 | July 30th 03 06:19 PM |
