Wing De-Icing Question
Old February 13th 09, 09:44 PM posted to rec.aviation.piloting
Robert11[_2_]
Default Wing De-Icing Question
Hello,
I guess de-icing is going to be a popular subject.
Question, please: On commercial jet airliners like, e.g., a 767 or 757, is
there any in-flight deicing system for the wing and tail surfaces, other
than a leading edge pneumatic boot ?
What about the "main," large upper surfaces ?
How in general is wing de-icing accomplished on these new, modern jets ?
Thanks,
Bob
Old February 13th 09, 10:13 PM posted to rec.aviation.piloting
Morgans[_2_]
"Robert11" wrote in message
Hello,
is there any in-flight deicing system for the wing and tail surfaces,
other than a leading edge pneumatic boot ?
Hot bypass air from the engines is what they use, in general. I have to
admit I do not know it the 787 is going to go truly all electric, or still
use hot engine air to heat the wings.
Once you get up to airliners of a larger size, the use of boots is not
common. In smaller turbine commuters, and in piston planes, (especially
pistons) there is not enough heat produced to heat wings.
Jim in NC
Old February 13th 09, 10:36 PM posted to rec.aviation.piloting
Robert M. Gary
On Feb 13, 1:44*pm, "Robert11" wrote:
Hello,
Question, please: *On commercial jet airliners like, e.g., a 767 or 757, is
Thanks,
Bob
Jets don't typically have boots. Most use hot air stollen from the
engines to heat the leading edges. Some use a "leak" system to drip
anti-freeze like solution on the tail surfaces to avoid having to
plumb the hot air to the rear, although this is less common. I'm not
sure that I woudl call the type of plane that crashed less modern than
a 767 considering by-pass jet engines (the type in a 767) have been
around longer than turbo prop engines that were involed in this recent
crash.
-Robert
Old February 14th 09, 05:05 PM posted to rec.aviation.piloting
K l e i n[_2_]
Hello,
Thanks,
Bob
crash.
-Robert
The more I hear about this, the more it sounds like tailplane icing.
Take a look at http://video.google.com/videoplay?do...23060735779946
for a NASA produced video on the subject.
Note that this flight started its plunge right at or after the outer
marker. The outer marker is where you normally lower gear and flaps.
Lowering flaps is the thing that causes the tailplane stall if the
tailplane is iced up.
K l e i n
Old February 15th 09, 02:11 AM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
"Robert11" wrote in
Hello,
757, is there any in-flight deicing system for the wing and tail
surfaces, other than a leading edge pneumatic boot ?
on flight, generally, not at all. On most jets, only the wings and engines
have anti or de-icing and it's accomplished by bleeding hot air out of the
compressor section of the engines. The engine anti ice is used frequently,
but wing de icing is seldom used simply because ice seldom forms on the
wings in flight. There is no deicing for the tops of the wings in jets.
Bertie
Old February 15th 09, 02:11 AM posted to rec.aviation.piloting,alt.disasters.aviation,alt.usenet.kooks
Bertie the Bunyip[_28_]
"Morgans" wrote in
Hello,
jets ?
to admit I do not know it the 787 is going to go truly all electric,
or still use hot engine air to heat the wings.
(especially pistons) there is not enough heat produced to heat wings.
yes, there is. there have been many pistons with hot wings, fjukkwit.
Bertie
Old February 15th 09, 02:12 AM posted to rec.aviation.piloting
K l e i n wrote in
Hello,
7
57, is
othe
r
jets
Thanks,
Bob
than a 767 considering by-pass jet engines (the type in a 767) have
been around longer than turbo prop engines that were involed in this
recent crash.
-Robert
Take a look at
http://video.google.com/videoplay?do...23060735779946 for a NASA
Rubbish.
Bertie
Old February 15th 09, 02:00 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
On Feb 13, 4:44*pm, "Robert11" wrote:
Hello,
Thanks,
Bob
There's a very good chance the Boston crash might have been tailplane
icing.
DH
Old February 15th 09, 02:03 PM posted to rec.aviation.piloting
cavedweller
Hello,
7
57, is
othe
r
jets
Thanks,
Bob
recent crash.
-Robert
Take a look at
http://video.google.com/videoplay?do...60735779946for a NASA
marker. *The outer marker is where you normally lower gear and flaps.
Rubbish.
Bertie- Hide quoted text -
- Show quoted text -
The NASA study on tail stall notwithstanding?
Old February 15th 09, 04:59 PM posted to rec.aviation.piloting
Gezellig
Hello,
Thanks,
Bob
icing.
DH
To explain the erratic flight behavior?
Wing walk ply question. Mustardbuilder Home Built 20 January 28th 07 10:16 AM
Rotor-wing question D. Andrews Rotorcraft 8 October 2nd 05 11:43 AM
Folded wing tip question a425couple Naval Aviation 35 May 12th 05 11:40 PM
Spitfire Mk XIV Wing Question [email protected] Military Aviation 3 September 19th 03 09:54 AM
Discus Wing question John Galloway Soaring 6 August 23rd 03 07:52 AM
