Westach 720-4a sensor
Old June 20th 04, 07:37 PM
Ira Rampil
Default Westach 720-4a sensor
Greetings,
Has anyone seen or developed a characterization of this tach sensor?
It is a combined magnet/coil combo used to generate a pulse when a
bit of iron speeds past(Ampere's law). In my case, I have 6 steel AN5
bolt heads/revolution roughly 3/32" from the sensor head at roughly 1000
inches/sec max.
I'd like to know the expected output voltage and impedance so I can
compute the input resistor for a 4n25. I need to divide the output
pulse rate by 4 with a little TTL to get it into the frequency range for
my tachometer system.
Any advice?
Ira N224XS flying, but due for a little panel rework
Old June 21st 04, 03:41 AM
sidk
Ira,
The diode on the 2N25 will drop about 1.6V at about 10mA. I am not
smart enough to calculate output characteristics of your generator but
my intuitive feel is that you may not have enough output (especially
at cranking speeds) to drive the diode. If it was mine, I would
connect 100 Ohms in series with the 2N25 diode and try it. Use a
scope and you can see what the real-world signal is.
Regards,
Sid Knox
Ira Rampil wrote in message ...
Greetings,
inches/sec max.
Any advice?
V-8 powered Seabee Corky Scott Home Built 212 October 2nd 04 11:45 PM
temperature sensor Philippe Vessaire Home Built 2 March 3rd 04 03:37 AM
Chevy 4.3 L V-6 and Misbehaving Engine Control Unit Bushy Home Built 6 August 18th 03 09:33 AM
