XCSoar / TopHat maps airspace etc.
Old April 10th 18, 06:28 PM posted to rec.aviation.soaring
Default XCSoar / TopHat maps airspace etc.
Hi everyone,
I just installed TopHat Soaring on a Kobo e-reader yesterday and am seeking a source for the map, airspace,, and turnpoint files for the areas where I fly, which are BRSS in New Castle, VA and the Chilhowee Gliderport in Benton, TN.
I have tried using the XCSoar map generator (http://mapgen.xcsoar.org) several times to obtain the map file. It times out or returns an error each time.
I was hoping that a member of this group might be in possession of the necessary files and could send them to me.
I'm also interested in the same for the default scenery in Condor I or II. Playing with TopHat in simulation seems like a good way to learn it before trying to use it in real life.
Thanks-
Matt
Old April 10th 18, 06:44 PM posted to rec.aviation.soaring
On Tuesday, April 10, 2018 at 1:28:44 PM UTC-4, wrote:
Hi everyone,
Thanks-
Matt
Turn the wifi on and go to settings, cog looking tab, click on site files and Tophat should show a list to pick from.
Old April 10th 18, 07:40 PM posted to rec.aviation.soaring
Hi everyone,
Thanks-
Matt
Direct download may work in some devices, but not others. I download on PC and then load into my Nook.
I managed to generate the map file on the XCSoar map generator. Took a few tries but only had to do it once (for several years' use).
Note that for the recent versions of Tophat the map data must be in "compressed" format, otherwise the terrain features won't show up.
Keeping the waypoints database up to date is a never-ending chore, as some airstrips become unusable, etc.
Old April 10th 18, 07:53 PM posted to rec.aviation.soaring
Yep, but none of the places I fly are among them.
Old April 10th 18, 09:36 PM posted to rec.aviation.soaring
6PK
Actually, TopHat does not even recommend Wi-Fi connection to transfer files.
The easiest and slickest way to go about uploading files is using a "Y" cable, external 5 V battery and a memory stick. Just upload all to the memory stick and vola...see link below;
http://www.tophatsoaring.org/Kobo%20...%20cables.html
Old April 10th 18, 09:46 PM posted to rec.aviation.soaring
6PK
Just to clarify; this is Kobo specific, look at the video at the bottom of the page....
Old April 11th 18, 12:43 AM posted to rec.aviation.soaring
Tango Eight
Hi everyone,
Thanks-
Matt
PM sent with New Castle .xcm map.
best,
Evan Ludeman / T8
using airspace files on XCSOAR/ Kobo firsys Soaring 1 April 27th 16 06:00 PM
Downloading Xcsoar maps onto Dell Streak 5? pjschae Soaring 5 November 3rd 15 10:29 PM
Error trying to download xcsoar maps. Juliet11[_2_] Soaring 3 March 20th 13 12:57 AM
US Airspace maps for outdoor recreation GPS receivers 2KA Soaring 0 October 24th 10 02:45 AM
Georeferencing Maps [was GPS and airspace] John Clonts General Aviation 10 July 5th 04 04:59 PM
