0-300D cylinder and oil sump torque settings
Old January 12th 05, 06:45 AM
Darrel Toepfer
Default 0-300D cylinder and oil sump torque settings
Anyone have a downloadable service manual? Or an 0-200 would do nicely
too...
Old January 12th 05, 12:42 PM
jls
"Darrel Toepfer" wrote in message
too...
410-430 and 490-510 in. lbs. on the 3/8 and 7/16 cylinder base nuts,
respectively
My manual doesn't say what torque on the oil sump nuts -- Use AC 43-13-1B.
If I'm not mistaken those bolts are 1/4" in. diameter. It's been a while.
Torque on the 1/4-28 flange bolts is 100-125 in. lbs. What're you doin',
trine to stop oil drips? Damn O-300's act like screen doors on a
submarine.
Remember when you are torquing the cylinder base nuts, you should also
torque the nut on the other end of a thru-stud, i. e., on the cylinder base
on the crankcase on the opposite side of the cylinder you are working with.
Old January 12th 05, 02:57 PM
Darrel Toepfer
jls wrote:
too...
respectively
submarine.
Thanks... Also whats the torque on the valve covers?
We've got a seep on the sump, 2 cylinders, a leaky valve cover and the
quick drain is also leaking. Takes a real good cleaning to find just
exactly where this bit of oil was coming from...
Thanks again for the info...
Old January 12th 05, 03:39 PM
jls
too...
respectively
43-13-1B.
while.
doin',
submarine.
base
with.
20 in. lbs. but only with silicone gaskets, which you should be using
because the other kind don't work. If the non-silicone I use a gasket
sealer like silicone or Hylomar and tighten gingerly until leak stops. Go
too far and they will never stop leaking.
Looks like the engine has some hours on it. I usually find leaks around the
crush washers on the rear case. I know of ONE O-300, just ONE, that isn't
a big leaker. Somebody put it together fastidiously.
If your quick-drain valve is leaking around the threads, get a good supply
of crush washers. If around the valve itself, clean or replace. You may
be able to lap it in with some fine lapping compound, but nowadays those
quick-drains are a lot cheaper than they used to be.
Best. I love them damned old engines. They just keep right on going and
the bottom ends are wonderful. Watch out for them jugs, though.
Old January 12th 05, 04:28 PM
Darrel Toepfer
Ordered silicone, dunno whats there yet but its probably cork. Only
fixing whats messing it up, leaving whats fine alone...
Around 3500 on the airframe, one overhaul on the engine...
One bolt on each of 2 cylinders is sweating oil...
Its not an oil burner, just a seeper... G
Thanks again...
Old January 13th 05, 04:41 PM
Darrel Toepfer
Darrel Toepfer wrote:
around the
isn't
Replacing the 4 on the accessory case as well...
Would you happen to have the replacement part number for the oil filler
cap or its gasket? Found some leakage there too...
Found several loose cylinder bolts...
Have 6 chromed ones...
