Alternator swap, Pitts S-1
Old October 10th 04, 10:36 AM
SHAWN DOYLE
Default Alternator swap, Pitts S-1
Hello!
I've got an expensive opportunity on the go. My electrical generation
system failed in the Pitts a couple of weeks ago. Had to get jump started
at Le Touquet to come back across the Channel, then again at Lydd to get
home. Not fun, I can tell you, but folks were immensely helpful at both
locations.
Having no luck troubleshooting the problem myself, I took off the
alternator, voltage regulator, and overvoltage controller and sent them for
testing. After putting out the fire my overvoltage sensor started on his
test rig, he was able to confirm that all three components either were junk
or nearly so. So, here's my opportunity. I can replace the existing
components like-for-like for around £560. OR I can install the simpler,
engine-gear-driven BNC lightweight alternator.
My question is, does anyone out there have experience with the BNC
alternator and also if anyone has any experience doing the conversion and
installation. I don't have much in the way of mechanical skills other than
being able to bolt stuff on and take stuff off.
Comments?
Cheers,
Shawn
Pitts S-1D, G-BKVP
Old October 11th 04, 08:25 PM
John Bishop
"SHAWN DOYLE" wrote in message
k...
Hello!
locations.
for
junk
than
Comments?
Cheers,
Shawn
Pitts S-1D, G-BKVP
Know how you feel, my Warrior's alternator failed mid channel on the way to
Le Touquet a few years ago. Easter Friday and no mechanics! They very
helpfully got a battery and jump leads, got me started, and I nursed it back
home on minimal electrical power.
John
Old October 11th 04, 10:47 PM
ShawnD2112
Yep, it's a bit disconcerting flying across the channel knowing your
battery's only putting out enough juice to transmit about 14 feet.
Actually, I didn't actually know that as my radio's always been crap, but it
wasn't too much of a threat as I was in formation with three other Pitts' at
the time. Flying home to Redhilll sans radio was a little trickier, though,
as I was on my own. Plane's been on the ground since and looks to be for a
little while longer while I get my electrical act together.
Glad to hear you got through it OK.
Cheers,
Shawn
"John Bishop" wrote in message
k...
Hello!
started
locations.
for
junk
than
Comments?
Cheers,
Shawn
Pitts S-1D, G-BKVP
to
back
John
Old October 13th 04, 04:10 AM
Dave Pilkington
yes, the B&C SD-8 alternator works well.
http://www.bandcspecialty.com/cgi-bi....cgi?17X358218
We fitted it to our Laser many years ago.
than
Comments?
Cheers,
Shawn
Pitts S-1D, G-BKVP
Old October 13th 04, 06:45 AM
ShawnD2112
Dave,
Thanks for that and for the link. Next thing is to find out if I have the
drive gear installed or not!
Cheers,
Shawn
"Dave Pilkington" wrote in message
om...
and
than
Comments?
Cheers,
Shawn
Pitts S-1D, G-BKVP
ELT antenna -- Pitts Al MacDonald Home Built 0 July 15th 04 03:27 PM
ELT antenna-- Pitts Al MacDonald Aerobatics 0 July 15th 04 03:27 PM
Advice on flying Pitts with Haigh Locking Tailwheel Ditch Home Built 19 January 4th 04 10:18 PM
Pitts Fly-In aerogirl Aerobatics 0 October 27th 03 11:45 PM
Pitts, Acro Sport, other to buy? Dave Swartz Aerobatics 0 September 3rd 03 03:18 PM
