Re-Engine B-52 proposal. (I love this debate)
Old July 11th 03, 10:33 AM
David McArthur
Dean,
http://www.acq.osd.mil/dsb/b52.pdf
Page 31 (of the actual document, not the .pdf page numbering!) Not a
great pic, but was the only I've seen
David
(SSNBuff) wrote in message
I would love to see a schematic or drawing of a B-52 with four engines. Do any
exist?
Dean
Old July 11th 03, 12:43 PM
Frank May
If you do a search for Dale Brown or Megafortress, there are several
drawings & photos (retouched, of course) of Dale Brown's "Old Dog" with
4 engines. It has the other Old Dog mods, but it has the 4 engines.
There's a book by Walter J Boyne about the B-52 that has some drawings
of 4 engine B-52s. One with 1 on each pylon, & another with 2 huge 'fans
paired on the inboard pylons. These are probably '70s, maybe '80s
"proposals".
Old July 11th 03, 02:51 PM
BUFDRVR
Okay - how about a twin-engined B52 using two of GE's 115000 pound
thrust engines? If that's not enough push, put ABs on them. (G).
Walt BJ
I think with all our engine driven accessories (hydraulic pumps and generators)
the min we could get down to is 4.
BUFDRVR
"Stay on the bomb run boys, I'm gonna get those bomb doors open if it harelips
everyone on Bear Creek"
Old July 11th 03, 06:18 PM
Tarver Engineering
"BUFDRVR" wrote in message
Walt BJ
generators)
Picture in your mind the "oh no" bird, known for his odd warbling sounding
much like "oh no, oh no" on each landing approach; with his 2 inch legs and
three inch balls ...
Old July 11th 03, 07:20 PM
Peter Twydell
In article , Tarver Engineering
writes
Walt BJ
generators)
On this side of the pond it's called the Oomigoolie Bird.
Distantly related to the Keereye Bird, the Ooh-ah Bird and the fabled
Oozlum Bird.
Peter
Ying tong iddle-i po!
Old July 13th 03, 07:13 AM
Bert Fiore
Has anyone done a study about the usability of such a beast? Could be useful
against hardened targets if you could overcome problems like:
1: Size- you'd need a lotta motor to get a projectile to Mach 5 or higher
in the lower atmosphere.
2: Heating-keeping it from melting.
3: Guidance
4: Range
Maybe some of the technology from the old Sprint ABM missle could be
used. ISTR a proposal for AXE - a plan to use a MX/Peacekeeper
first stage as a booster for an area denial weapon (large quantity of
submunitions instead of upper stage(s)/warhead bus/RVs on top).
I would think that the ability to _accurately_ hit a hardened target
with a LARGE DU/tungsten/titanium penetrator would be very
handy indeed, even if you had to launch it by first dropping it
from a large transport craft, a la the C-141/Minuteman tests
of 25+ years ago!
Comments?
Bert
Old July 13th 03, 12:15 PM
Keith Willshaw
"Bert Fiore" wrote in message
useful
3: Guidance
4: Range
of 25+ years ago!
Comments?
Bring back the Grand Slam, 22,000 lb of hardened steel at Mach 2
should do the job nicely with a guidance package attached. It should
be possible for a B-52 to carry one under each wing where the
Hounddog's used to go
Keith
Old July 13th 03, 08:53 PM
Kevin Brooks
"Bert Fiore" wrote in message ...
3: Guidance
4: Range
of 25+ years ago!
Comments?
Bert
Various studies and experaments have already been conducted, or are
underway, of the viability of using long range ballistic missiles,
ranging from the Army's short range ATACMS all the way up to and
including use of conventionaly armed Minuteman ICBM's as deep
penetration weapons. In addition, there is a current R&D effort afoot
to develop a hypersonic strike system to strike time critical targets;
one owuld imagine that it could also serve as a means of striking very
deep/very hard targets.
I'd suspect that unless range is a non-issue, the ballistic missile
approach might be better than an air launched hypersonic vehicle as a
near-term deep penetrator. The technology is already there and proven,
meaning lower development risk.
Brooks
Car engine FAA certified for airplane use Cy Galley Home Built 10 February 6th 04 03:03 PM
Objective Engine Discussion Rick Maddy Home Built 26 October 14th 03 04:46 AM
1710 allison v-12 engine WWII p 38 engine Holger Stephan Home Built 9 August 21st 03 08:53 AM
Gasflow of VW engine Veeduber Home Built 4 July 14th 03 08:06 AM
