#21
Garmin G1000 gets airways
On Sat, 04 Aug 2007 14:13:55 -0400, Ron Rosenfeld
wrote: On the flightplan I entered this morning. It listed KBFM LOXLY V198.QUINCY KTLH The fixes between LOXLY and QUINCY were not shown. What is QUINCY? I can't locate it, and I thought all intersections were five characters. I can only presume it's QUNCY but QUNCY doesn't exist on V198. Perhaps he meant QUILL but I would have suspected the routing would have been KBFM LOXLY V198 SZW KTLH. The system should have entered waypoints for BRATT PENSI INBRD BAKOS CEW CORKY DEFUN CHEWS MAI SNEAD QUILL and SZW if that's what was entered with the "LD ARWY" function. Course, he was doing it from the PFD instead of the MFD, so it would be interesting to know what was depected on the map and in the MFD's FPL screen. I've only just installed these on my G1000s and haven't had any chance to play with them myself. I do know from doing that though, when entered via MFD it shows a leg of the flight plan as "AIRWAY entry exit" and depicts the various waypoints on the map. |
On Sat, 04 Aug 2007 15:40:46 -0400, Peter Clark
wrote: On Sat, 04 Aug 2007 14:13:55 -0400, Ron Rosenfeld wrote: On the flightplan I entered this morning. It listed KBFM LOXLY V198.QUINCY KTLH The fixes between LOXLY and QUINCY were not shown. What is QUINCY? I can't locate it, and I thought all intersections were five characters. I can only presume it's QUNCY but QUNCY doesn't exist on V198. Perhaps he meant QUILL but I would have suspected the routing would have been KBFM LOXLY V198 SZW KTLH. The system should have entered waypoints for BRATT PENSI INBRD BAKOS CEW CORKY DEFUN CHEWS MAI SNEAD QUILL and SZW if that's what was entered with the "LD ARWY" function. Course, he was doing it from the PFD instead of the MFD, so it would be interesting to know what was depected on the map and in the MFD's FPL screen. I've only just installed these on my G1000s and haven't had any chance to play with them myself. I do know from doing that though, when entered via MFD it shows a leg of the flight plan as "AIRWAY entry exit" and depicts the various waypoints on the map. I see I posted to the wrong person. Hopefully Dan will see this and clarify. The CNX80 also populates all the fixes, as was pointed out by someone else. Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
"Ron Rosenfeld" wrote: "AIRWAY entry exit" and depicts the various waypoints on the map. I see I posted to the wrong person. Hopefully Dan will see this and clarify. QUILL, not QUINCY -- Dan T-182T at BFM |
#24
"Ron Rosenfeld" wrote: The CNX80 also populates all the fixes, The G1000 shows all the ones that mark course changes on the active flightplan. -- Dan T-182T at BFM |
#25
On Sat, 4 Aug 2007 16:03:33 -0500, "Dan Luke"
wrote: "Ron Rosenfeld" wrote: The CNX80 also populates all the fixes, The G1000 shows all the ones that mark course changes on the active flightplan. Strange. Does it let you direct-to an intermediate fix? I've really gotta go fly. |
#26
"Peter Clark" wrote: The G1000 shows all the ones that mark course changes on the active flightplan. Strange. Does it let you direct-to an intermediate fix? I've really gotta go fly. So do I. I haven't actually flown a trip on a flightplan with an airway in it yet. I'm sure you can "direct-to" any waypoint in the flightplan. -- Dan T-182T at BFM |
#27
On Sat, 4 Aug 2007 17:59:32 -0500, "Dan Luke"
wrote: "Peter Clark" wrote: The G1000 shows all the ones that mark course changes on the active flightplan. Strange. Does it let you direct-to an intermediate fix? I've really gotta go fly. So do I. I haven't actually flown a trip on a flightplan with an airway in it yet. I'm sure you can "direct-to" any waypoint in the flightplan. Yea, I'm surprised it's not depicting the waypoints. Since this is all derived from the Mustang updates, and when flying in the flight levels "cross random fix somewhere on your flight plan at one zero thousand" is pretty common, not having random fix available for the VNAV page would be quite a nuisance. I wouldn't think they'd mess around with the code that much to make the Mustang and single-engine versions act differently in that respect. |
#28
wrote: "Ron Rosenfeld" wrote: The CNX80 also populates all the fixes, The G1000 shows all the ones that mark course changes on the active flightplan. OK, on the simulator for the CNX80/GNS480, I enter Origin KBFM Dest KTLH Waypt LOXLY Airway V198 -- QUILL Since there is no airway from QUILL direct to KTLH, I then delete the "discontinuity" In the regular display, I see: KBFM LOXLY V198 QUILL KTLH In the EXPANDED mode, I see: KBFM LOXLY V198--QUILL BRATT PENSI INBRD BAKOS CEW CORKY DEFUN CHEWS MAI SNEAD QUILL KTLH Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
#29
"Ron Rosenfeld" wrote: In the EXPANDED mode, I see: I remember seeing something about "expand" something down in the menus somewhere. If I get a chance tomorrow, I'll check it out. -- Dan T-182T at BFM |
#30
Peter Clark wrote:
On Sat, 4 Aug 2007 17:59:32 -0500, "Dan Luke" wrote: "Peter Clark" wrote: The G1000 shows all the ones that mark course changes on the active flightplan. Strange. Does it let you direct-to an intermediate fix? I've really gotta go fly. So do I. I haven't actually flown a trip on a flightplan with an airway in it yet. I'm sure you can "direct-to" any waypoint in the flightplan. Yea, I'm surprised it's not depicting the waypoints. Since this is all derived from the Mustang updates, and when flying in the flight levels "cross random fix somewhere on your flight plan at one zero thousand" is pretty common, not having random fix available for the VNAV page would be quite a nuisance. I wouldn't think they'd mess around with the code that much to make the Mustang and single-engine versions act differently in that respect. If there is no STAR they will often give you a crossing fix on a Victor airway, which isn't loaded in the Jet Route flight plan in any case. So, the fix has to be entered manually at that point. |
Similar Threads | ||||
Garmin G1000 ASA/King? | Mitty | Instrument Flight Rules | 2 | November 3rd 06 03:47 PM |
Victor Airways in Cessna G1000 T182T | [email protected] | Instrument Flight Rules | 17 | May 2nd 06 02:56 AM |
Mooney goes with Garmin G1000 | Mike Rapoport | Owning | 4 | February 15th 04 01:03 AM |
Garmin G1000 | Corky Scott | Home Built | 4 | January 9th 04 06:57 AM |
Garmin G1000 | Foster | Owning | 2 | July 20th 03 06:45 PM |
