what is that noise?
Hello, I fly a 1979 Nimbus 2 carbon, and since a few years I hear a cracking noise behind me. That noise occurs more often after a few hours of flight, maybe related to temperature change with altitude. You can hear the cracking noise in this video:
https://www.youtube.com/watch?v=pke-...ature=youtu.be Did you already hear that noise? how do you think I can fix this ? do you think it is dangerous? Thank you for help and advice |
what is that noise?
It may be as simple as your fiberglass seat back rubbing against some part of the fuselage interior. Can you duplicate the sound while sitting in the cockpit on the ground?
what is that noise?
Le lundi 22 juillet 2019 13:22:57 UTC+2, a écritÂ*:
It may be as simple as your fiberglass seat back rubbing against some part of the fuselage interior. Can you duplicate the sound while sitting in the cockpit on the ground? I don't think it is the seat back, no sound while sittin in the cockpit on the ground. Maybe I will try with somebody else moving /shaking the wingtip while sitting on the ground to check if I can hear that noise... |
what is that noise?
Another possible source of the noise might be the wing spars rubbing against each other. My Pegase made that sound, and then just to try to isolate it, I put a very light coat of cooking oil on any part of the spar that looked like it had been rubbed. Creaking noise was gone immediately, so I quit worrying about it.
what is that noise?
Sounds like the wings are about to come off.
Kidding, I would be looking for signs of rubbing anywhere. Canopy is always a good place to start as they expand and contract the most. Spars are a possibility. Seat back. After that the options become less. Good luck hunting |
what is that noise?
At 10:39 22 July 2019, gregv wrote:
Hello, I fly a 1979 Nimbus 2 carbon, and since a few years I hear a cracking noise behind me. That noise occurs more often after a few hours of flight, maybe related to temperature change with altitude. You can hear the cracking noise in this video: https://www.youtube.com/watch?v=pke-...ature=youtu.be Did you already hear that noise? how do you think I can fix this ? do you think it is dangerous? Thank you for help and advice Possible rubbing of the canopy frame? The plastic canopy will shrink when the temperature falls after flying for a while, especially at higher altitudes in the mountains. You may only be able to replicate the noise on the ground in cooler temperatures. RO |
what is that noise?
Likely the canopy or spar. Clean the canopy rail and the area where it touches on the fuselage. A light coat of wax or a very thin open cell foam seal may help on the canopy. Check the spar for rubbing and wax any possibility areas.
what is that noise?
On Monday, July 22, 2019 at 6:39:11 AM UTC-4, gregv wrote:
Hello, I fly a 1979 Nimbus 2 carbon, and since a few years I hear a cracking noise behind me. Count your blessings. I have a howling banshee in my tail boom. |
what is that noise?
Le lundi 22 juillet 2019 16:07:24 UTC+2, Tim Taylor a écritÂ*:
Likely the canopy or spar. Clean the canopy rail and the area where it touches on the fuselage. A light coat of wax or a very thin open cell foam seal may help on the canopy. Check the spar for rubbing and wax any possibility areas. ok thanks, I think it is spar related, I will wax and check for rubbing |
what is that noise?
On Monday, July 22, 2019 at 4:01:58 PM UTC+1, gregv wrote:
Le lundi 22 juillet 2019 16:07:24 UTC+2, Tim Taylor a écritÂ*: Likely the canopy or spar. Clean the canopy rail and the area where it touches on the fuselage. A light coat of wax or a very thin open cell foam seal may help on the canopy. Check the spar for rubbing and wax any possibility areas. ok thanks, I think it is spar related, I will wax and check for rubbing I used to have a Nimbus 2c. It was a long time ago but I still remember what I think is the same cracking sound you are describing. Quite loud and sharp. It never bothered me. Like you I thought it came from the spar stub area when there was a bit of turbulence. |
Similar Threads | ||||
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets | Jim Macklin | Piloting | 26 | January 13th 07 12:06 AM |
FAA paper Noise Attenuation Properties of Noise-Canceling Headsets | Jim Macklin | Instrument Flight Rules | 15 | January 13th 07 12:06 AM |
Prop noise vs. engine noise | Morgans | Piloting | 8 | December 24th 03 03:24 AM |
noise | G.A. Seguin | Soaring | 2 | August 27th 03 01:57 AM |
Com noise | Hankal | Piloting | 0 | July 21st 03 12:54 AM |
