Excessive valve clearance cause low power?
Dave wrote:
: Exhaust restriction? Bad mufflers can rob lots of power and be : intermittent. : I'm not saying valve clearance isn't the problem, but your clearances : don't seem extreme. : Also, plugs can test well but the internal resistance can bugger things : up. I've read that 5k ohms or over may be excessive. The spark will find : easier places to go than across the electrodes. : good luck As I said in my initial message, muffler baffles checked and fine. I have overhauled the mufflers this year due to cracks in the end plates, but the baffles were fine when they were removed. As far as the plugs, we replaced them about a year ago. Had the intermittent failures with the old plugs, new plugs, and mag drops were fine in all cases. Doesn't seem to be ignition-related. -Cory ************************************************** *********************** * Cory Papenfuss, Ph.D., PPSEL-IA * * Electrical Engineering * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Similar Threads | ||||
Ball Valve,Needle Valve,Snubber,Gauge Cock Sale on good price | valvetom | Piloting | 0 | November 28th 06 02:32 AM |
Brass Ball Valve,Gas Valve,Needle Valve,Angle Valve,Hose Bibcock Sale on good price | valvetom | Piloting | 0 | November 28th 06 02:25 AM |
Power setting table and best economy/best power... | xerj | Piloting | 29 | October 20th 05 02:44 AM |
sticky valve or | Dick | Home Built | 18 | May 25th 05 07:50 PM |
sticky valve or | Dick | Owning | 18 | May 25th 05 07:50 PM |
