Icing conditions
Maybe he can rig a 200 pound CO2 bottle that can blast him,
simulating flight into a CB at the freezing level. "Steve Foley" wrote in message news:BRlbh.12790$d42.8443@trndny07... | "B A R R Y" wrote in message | et... | Mxsmanic wrote: | From what I understand, icing protection should be turned on if the | outside temperature is 5° C or less. However, what is the reason for | not having it on all the time? | | Some ice protection equipment uses a fluid that is of limited quantity | on-board, not to mention that it costs money. | | He can always pause and go to the fridge for more fluids. | | Other ice protection devices can put a drain on a smaller aircraft's | power. | | He's running on 220VAC. Sholdn't be an issue. | | |
Icing conditions
Jim Macklin wrote:
Maybe he can rig a 200 pound CO2 bottle that can blast him, simulating flight into a CB at the freezing level. And end up looking like Dr. Evil's cat? G |
Icing conditions
"Mxsmanic" wrote in message ... From what I understand, icing protection should be turned on if the outside temperature is 5° C or less. However, what is the reason for not having it on all the time? Does it overheat in normal weather, or what? I read that turning on icing protection before "sufficient ice has accumulated" may prevent the protection from working to remove the ice. Why? Also, what types of anti-icing stuff should I turn on? Just everything that deals with ice (wing, prop, pitot, fuel vent, etc.), or is there an accepted order or hierarchy for these things? Once again, you are revealing your stupidity to us by the inane questions you ask. You are such an idiot. Since you said in another post (quoting exactly) about the sources of your information: "I also get a lot from textbooks, manuals, standard reference materials, and reliable online resources. In some cases I get it directly from people I believe to be qualified to provide it (which is not the same as people who _claim_ to be qualified--there isn't always a lot of overlap)." I suggest you go to those sources for this information. Few of us are quailified to answer your questions since most of us possess airmen's certificates and fly airplanes, not MSFS and the ilk. |
Icing conditions
"N2310D" wrote in
news:mImbh.15988$Uz.3908@trnddc05: I suggest you go to those sources for this information. Few of us are quailified to answer your questions since most of us possess airmen's certificates and fly airplanes, not MSFS and the ilk. FINALLY a reply that makes sense..... Unfortunately, it will fall on the deaf ears of Mx..... Soooo, the best reply to Mx would be no reply..... Allen |
Icing conditions
I am not sure why you guys are beating up the guy. He may not be a real
pilot, but I have not found his questions to be offensive, off-topic or even ignorant. To the contrary, he has posed several questions in the past that many of us were unable to answer, or revealed lack of knowledge on our part. In those cases, it is the real pilots who I have seen to misbehave. I can't recall Mxsmanic to have lost his cool despite all the things that poeple call him. A Lieberma wrote: "Jim Macklin" wrote in : Too many systems to explain here, read the POH or a good training manual. Talk about wasted advise..... Mx doesn't even read the replies, much less anything he's been shown to read like references or POHs. Allen |
Icing conditions
"A Lieberma" wrote in message . 18... "N2310D" wrote in news:mImbh.15988$Uz.3908@trnddc05: I suggest you go to those sources for this information. Few of us are quailified to answer your questions since most of us possess airmen's certificates and fly airplanes, not MSFS and the ilk. FINALLY a reply that makes sense..... Unfortunately, it will fall on the deaf ears of Mx..... Soooo, the best reply to Mx would be no reply..... Allen Hi Allen. Well, I sat back in the shadows and ignored Mx's stupidity for a long time. In this case, I wasn't really replying to his post, only pointing out to him what a dullard he is. |
Icing conditions
"Jim Macklin" writes:
Exactly what is turned ON depends on the airplane and the type of ice protection installed. In the Baron (simulated), I have Pitot Heat, Fuel Vent Heat, Stall Warn Heat, Prop, Windshield, and Surface. I can figure out what they all do except "Surface" (leading edge heat or something?), but I'm not sure which ones can be left on under what conditions. The manual only mentions "Ice Protection Systems - as required" in a checklist, but does not explain what they are for (the sim manual is presumably more limited than the real one, although some portions are taken directly out of the real one). I've only experienced icing once in the sim, when the pitot tube froze up. I haven't really figured out how to configure the sim to guarantee that I have ice. It's on my list of things to practice. Pitot and windshield heat, are OK to run all the time in flight, but if pitot heat is used on the ground for a long period, the chrome will turn a pretty purple, so test it on the ground [don't burn your hand] and then turn it on before take-off. Is there a thermostat or something in ice protection hardware to keep it from overheating if it isn't really that cold outside? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Icing conditions
"Andrew Sarangan" wrote in message oups.com... I am not sure why you guys are beating up the guy. He may not be a real pilot, but I have not found his questions to be offensive, off-topic or even ignorant. To the contrary, he has posed several questions in the past that many of us were unable to answer, or revealed lack of knowledge on our part. In those cases, it is the real pilots who I have seen to misbehave. I can't recall Mxsmanic to have lost his cool despite all the things that poeple call him. It's not his questions that we have a problem with. It his responses to the answers he receives. |
Icing conditions
Ron Garret writes:
Except for boots, the safest policy is to just turn it all on if there's any possibility of ice. And how do I recognize a possibility of ice? Should I assume that any time I enter a cloud? Is there a safe external temperature above which ice is never an issue? Logically I'd assume that ice would form at zero degrees Celsius, but I don't know what margin above that to provide. At the same time, I don't want to wear things out (even though they never wear out in the sim) by running them when there's no real chance of ice. If ice starts to collect on places like the wings, what's the first thing I would notice in the way the aircraft behaves? I do have a light that shines on the wing so I can look at it, but I need to know what the symptoms are of ice build-up as well. -- Transpose mxsmanic and gmail to reach me by e-mail. |
Icing conditions
B A R R Y writes:
Ice protection isn't always needed when it's cold, you also need moisture to create ice. But without a measurement of humidity on board, how do you know if there's moisture out there (apart from the obvious case of visible clouds or fog)? -- Transpose mxsmanic and gmail to reach me by e-mail. |
Similar Threads | ||||
UAV's and TFR's along the Mexico boarder | John Doe | Piloting | 145 | March 31st 06 06:58 PM |
I want to build the most EVIL plane EVER !!! | Eliot Coweye | Home Built | 237 | February 13th 06 03:55 AM |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
FAR 91.157 Operating in icing conditions | O. Sami Saydjari | Instrument Flight Rules | 98 | December 11th 03 06:58 AM |
