#31
engine pre-oiler
On Sat, 29 Dec 2007 12:18:02 -0800, "Stuart & Kathryn Fields"
wrote: Maxwell: Do you know of a tiny gear pump or where to look that might be used by hand or cordless drill? Is there a problem with gear pumps requiring priming? Yep in some ways the accumulator looks good except it does take up a bit of space. "Maxwell" wrote in message ... "Stuart & Kathryn Fields" wrote in message .. . I've got to admit that idea has never been put forth, but I'm playing with a helicopter and increasing weight is looked at very closely. My accumulator that I built weighs 2.9# but the electric fuel pumps that I have been reviewing weigh less than 2#. I think that the smog pump is much heavier. BTW I fly in the desert and corrosion is pretty much a non-issue. I had a raw 4130 helicopter frame setting outside for about 10yrs and you could wipe off the rust with a paper towel. I would really like to have a system mounted on the helicopter that would pre-oil just before start up. I some time have periods on the airshow circuit where the engine does not get started for several weeks and I would like to pre-oil prior to starting and be able to do that from the cockpit or possibly from a manual pump providing that I can keep the weight down. Just some random thoughts... - Three pounds for an accumulator seems like a good reliable and reasonable weight solution to me, if you just don't forget to charge it before each engine shut down. - I don't think a fuel pump will reliably pump cold aviation motor oil. Have you experimented with one? - Have you considered a tiny gear pump you could spin with a hand crank or cordless drill during preflight? Grab the oil pump out of a Honda Goldwing -- Posted via a free Usenet account from http://www.teranews.com |
#32
engine pre-oiler
Morgans: This time I'm way ahead. I had both cam and piston skirt spray
nozzles installed during the engine overhaul. It is definitely a non-certified application. My 0320 was modified by me to run vertical. Stu "Morgans" wrote in message ... wrote A quart of prime would be six or eight times as much as is needed to preoil the engine. My little hand-pump on my A-65 does it with ten . 75 cubic-inch strokes, for 7.5 cu. in. total. A larger engine might take 10 or 12 cubic inches. Someone on the RV forum mentioned making an accumulator out of a air-conditioning freon can. That, plus a couple valves and plumbing would be pretty darn light. One thing to keep in mind, is that the pre oiler will not do anything to lubricate the camshaft, one of the parts that takes the most wear on dry start-up. If this is a non certified application, you could split the cases and add a spray bar to help the cam. -- Jim in NC |
#33
engine pre-oiler
So far the winner appears to be a little(less than 3#) 12V pump delrin gear
pump capable of 1.5 -3 gpm of oil. This unit with a check valve and a pickup from the sump, and of course some $200+ dollars and I'm in business. The Infinity solution is just a bit more expensive but also looks feasible. Stu "cavelamb himself" wrote in message ... Maxwell wrote: "Stuart & Kathryn Fields" wrote in message .. . Maxwell: Do you know of a tiny gear pump or where to look that might be used by hand or cordless drill? Is there a problem with gear pumps requiring priming? How about something like this, or perhaps something like it in aluminum. http://www.clarksol.com/html/prodspe...l_00RGPump.htm Just mount it below the sump so it's always primed. Just include a good check valve so you couldn't loose oil presure back through it. This particular size would probably be best driven by a cordless drill, but a higher displacement unit might be turned with a had crank. Yep in some ways the accumulator looks good except it does take up a bit of space. Yeah, and useless if you forget to reset it during shutdown, and limited to about a quart of prime. Don't you think thi sis getting a little over the top now? It's an O-320. Not an R9800. |
#34
engine pre-oiler
Stuart & Kathryn Fields wrote:
So far the winner appears to be a little(less than 3#) 12V pump delrin gear pump capable of 1.5 -3 gpm of oil. This unit with a check valve and a pickup from the sump, and of course some $200+ dollars and I'm in business. The Infinity solution is just a bit more expensive but also looks feasible. Stu "cavelamb himself" wrote in message ... I know what kind of machines you fly, Stuart. That's why I didn't suggest "Flip the prop". Three pounds isn't that bad - once. But don't make a habit of it... Richard |
#35
engine pre-oiler
wrote in message ... On Dec 30, 2:04 pm, "Maxwell" wrote: Yep in some ways the accumulator looks good except it does take up a bit of space. Yeah, and useless if you forget to reset it during shutdown, and limited to about a quart of prime. A quart of prime would be six or eight times as much as is needed to preoil the engine. My little hand-pump on my A-65 does it with ten . 75 cubic-inch strokes, for 7.5 cu. in. total. A larger engine might take 10 or 12 cubic inches. An engine tighter than mine (61 years old now) would take much less. A quart has just under 58 cubic inches. You got any photos of that rig? |
#36
engine pre-oiler
"cavelamb himself" wrote in message ... Maxwell wrote: "Stuart & Kathryn Fields" wrote in message .. . Maxwell: Do you know of a tiny gear pump or where to look that might be used by hand or cordless drill? Is there a problem with gear pumps requiring priming? How about something like this, or perhaps something like it in aluminum. http://www.clarksol.com/html/prodspe...l_00RGPump.htm Just mount it below the sump so it's always primed. Just include a good check valve so you couldn't loose oil presure back through it. This particular size would probably be best driven by a cordless drill, but a higher displacement unit might be turned with a had crank. Yep in some ways the accumulator looks good except it does take up a bit of space. Yeah, and useless if you forget to reset it during shutdown, and limited to about a quart of prime. Don't you think thi sis getting a little over the top now? It's an O-320. Not an R9800. What would you suggest? |
#37
engine pre-oiler
Maxwell wrote:
"cavelamb himself" wrote in message ... Maxwell wrote: "Stuart & Kathryn Fields" wrote in message m... Maxwell: Do you know of a tiny gear pump or where to look that might be used by hand or cordless drill? Is there a problem with gear pumps requiring priming? How about something like this, or perhaps something like it in aluminum. http://www.clarksol.com/html/prodspe...l_00RGPump.htm Just mount it below the sump so it's always primed. Just include a good check valve so you couldn't loose oil presure back through it. This particular size would probably be best driven by a cordless drill, but a higher displacement unit might be turned with a had crank. Yep in some ways the accumulator looks good except it does take up a bit of space. Yeah, and useless if you forget to reset it during shutdown, and limited to about a quart of prime. Don't you think thi sis getting a little over the top now? It's an O-320. Not an R9800. What would you suggest? KISS! Keep it Simple stupid. AND Lighter is better. |
#38
engine pre-oiler
Maxwell: The engine is installed in my Baby Belle helicopter. It has a dry
sump located just below the accesory case and a flat plate replaces the normal cast sump which contained the intake manifold. A new intake manifold was constructed, drain tubes made for the valve covers and an oil return was fashioned connected to the accesory case. Works like gangbusters so far (230hrs). If you want I could snap a shot and send them to you via e-mail? Stu "Maxwell" wrote in message ... wrote in message ... On Dec 30, 2:04 pm, "Maxwell" wrote: Yep in some ways the accumulator looks good except it does take up a bit of space. Yeah, and useless if you forget to reset it during shutdown, and limited to about a quart of prime. A quart of prime would be six or eight times as much as is needed to preoil the engine. My little hand-pump on my A-65 does it with ten . 75 cubic-inch strokes, for 7.5 cu. in. total. A larger engine might take 10 or 12 cubic inches. An engine tighter than mine (61 years old now) would take much less. A quart has just under 58 cubic inches. You got any photos of that rig? |
#39
engine pre-oiler
"cavelamb himself" wrote in message ... KISS! Keep it Simple stupid. AND Lighter is better. Agreed. But what do you suggest would be lighter and simpler? |
#40
engine pre-oiler
"Stuart & Kathryn Fields" wrote in message .. . Maxwell: The engine is installed in my Baby Belle helicopter. It has a dry sump located just below the accesory case and a flat plate replaces the normal cast sump which contained the intake manifold. A new intake manifold was constructed, drain tubes made for the valve covers and an oil return was fashioned connected to the accesory case. Works like gangbusters so far (230hrs). If you want I could snap a shot and send them to you via e-mail? That's ok Stu, I have a pretty good idea what your installation looks like. I was trying to picture the installation Dan keeps referring to. |
Similar Threads | ||||
Engine-out procedures and eccentric forces on engine pylons | Mxsmanic | Piloting | 18 | May 26th 07 01:03 AM |
Saturn V F-1 Engine Testing at F-1 Engine Test Stand 6866986.jpg | [email protected] | Aviation Photos | 1 | April 11th 07 04:48 PM |
F-1 Engine for the Saturn V S-IC (first) stage depicts the complexity of the engine 6413912.jpg | [email protected] | Aviation Photos | 0 | April 9th 07 01:38 PM |
Preheat / Pre-Oiler | Fastglasair | Home Built | 6 | November 13th 04 05:40 AM |
Preheat / Pre-Oiler | Fastglasair | Owning | 1 | November 11th 04 05:11 PM |
