#21
Gelcoat Sanding
A friend of mine in the auto body business turned me on to 3M Dry Guide Coat, and I'm a huge fan. Used to use leftover rattle can paint and/or pencil, but this stuff is much better. It goes on dry, gets down into the pinholes and crannies, and doesn't clog the paper when you sand (if anything, I think it's a lubricant). Plus, you can get it out with some mild solvent (like Prep Kleen). Note: That's for wet-sanding new paint to get rid of the orange peel or identify low spots etc. What Andy is talking about is different, since it's failed/failing gelcoat. FWIW.
Gelcoat Sanding
agreed! i love guide coat too. it shows EVERYTHING, even bad sanding technique, or a dinged up block. On Tuesday, March 29, 2016 at 4:50:16 PM UTC-4, Papa3 wrote: A friend of mine in the auto body business turned me on to 3M Dry Guide Coat, and I'm a huge fan. Used to use leftover rattle can paint and/or pencil, but this stuff is much better. It goes on dry, gets down into the pinholes and crannies, and doesn't clog the paper when you sand (if anything, I think it's a lubricant). Plus, you can get it out with some mild solvent (like Prep Kleen). Note: That's for wet-sanding new paint to get rid of the orange peel or identify low spots etc. What Andy is talking about is different, since it's failed/failing gelcoat. FWIW. |
Gelcoat Sanding
On Tuesday, March 29, 2016 at 2:07:12 PM UTC-7, ND wrote:
agreed! i love guide coat too. it shows EVERYTHING, even bad sanding technique, or a dinged up block. On Tuesday, March 29, 2016 at 4:50:16 PM UTC-4, Papa3 wrote: A friend of mine in the auto body business turned me on to 3M Dry Guide Coat, and I'm a huge fan. Used to use leftover rattle can paint and/or pencil, but this stuff is much better. It goes on dry, gets down into the pinholes and crannies, and doesn't clog the paper when you sand (if anything, I think it's a lubricant). Plus, you can get it out with some mild solvent (like Prep Kleen). Note: That's for wet-sanding new paint to get rid of the orange peel or identify low spots etc. What Andy is talking about is different, since it's failed/failing gelcoat. FWIW. Check this out (I also posted on the Trizact thread): https://www.youtube.com/watch?v=ke5kfYz9Ybw |
#24
Gelcoat Sanding
On Thursday, March 31, 2016 at 12:19:48 AM UTC-4, 2G wrote:
On Tuesday, March 29, 2016 at 2:07:12 PM UTC-7, ND wrote: agreed! i love guide coat too. it shows EVERYTHING, even bad sanding technique, or a dinged up block. On Tuesday, March 29, 2016 at 4:50:16 PM UTC-4, Papa3 wrote: A friend of mine in the auto body business turned me on to 3M Dry Guide Coat, and I'm a huge fan. Used to use leftover rattle can paint and/or pencil, but this stuff is much better. It goes on dry, gets down into the pinholes and crannies, and doesn't clog the paper when you sand (if anything, I think it's a lubricant). Plus, you can get it out with some mild solvent (like Prep Kleen). Note: That's for wet-sanding new paint to get rid of the orange peel or identify low spots etc. What Andy is talking about is different, since it's failed/failing gelcoat. FWIW. Check this out (I also posted on the Trizact thread): https://www.youtube.com/watch?v=ke5kfYz9Ybw Note the sanding pattern demonstrated which is like what I was trying to describe above. We use the 3M compounds and polishes for paint but use edge buffer applied hard wax/rouge for final buff and to impregnate/seal the gelcoat which has a lot of porosity. UH |
Similar Threads | ||||
Dry vs. wet sanding | [email protected] | Soaring | 16 | February 19th 16 11:28 AM |
Gel coat removal - water sanding vs. straight line sanding | LS3 Pilot | Soaring | 45 | February 15th 10 03:32 PM |
Advice on sanding fibreglass | [email protected] | Home Built | 12 | April 28th 05 10:39 PM |
Sanding composites | [email protected] | Home Built | 12 | January 31st 05 06:47 AM |
Fear of Sanding | Stuart Grant | Soaring | 7 | January 17th 05 05:28 PM |
