ELT Mounting for an ASW20-C
I think SWR is the least of one's problems after a crash....
In my ship the ground plane is a metal tab a bit smaller than a matchbook and the antenna curls around the inside of the baggage compartment. In either case, I'm just hoping things don't get torn up too much and the thing works after a crash. So, I'm not really worried about how well it works, as long as it stays reasonably intact. -Tom |
"5Z" wrote in message oups.com... I think SWR is the least of one's problems after a crash.... In my ship the ground plane is a metal tab a bit smaller than a matchbook and the antenna curls around the inside of the baggage compartment. In either case, I'm just hoping things don't get torn up too much and the thing works after a crash. So, I'm not really worried about how well it works, as long as it stays reasonably intact. -Tom 121.5 MHz ELTs don't have so great a track record when it comes to working properly after a crash. Assuming the thing survives, gets triggered by the crash G-forces (or manually, pre-impact) and remains attached to its antenna, the signal still needs to reach an overhead satellite. It's reasonable to assume that the antenna may not be oriented optimally post crash, nor may it be ideally situated at least a wavelength away from conductive material, nor will it always have a nice clear view of the sky. Getting that signal through won't always be easy. Since reflected RF energy is wasted, I'd think minimizing SWR is important. To help insure the signal gets through, why not go for best installation practicable, given the constraints imposed by the typical modern glider? An adequate ground plane isn't usually too difficult and may make the difference. bumper |
Similar Threads | ||||
C150 Wheel Fairing mounting plates | Robert Zrim | Owning | 17 | June 16th 05 07:37 AM |
ASW20 liftup panel mod ,do you want one | goneill | Soaring | 2 | September 8th 04 09:05 PM |
Skymap IIIC Mounting Options | NW_PILOT | Owning | 15 | July 8th 04 01:41 PM |
ASW20 owners | Andrew Henderson | Soaring | 0 | April 10th 04 12:28 PM |
ASW20 tail tank mod | goneill | Soaring | 4 | February 21st 04 06:16 PM |
