Q: Engine Breakin
When breaking in a new or rebuilt engine, does it matter if you run high
MP/low RPM or high RPM/low MP at 70-75% power? |
john smith wrote: When breaking in a new or rebuilt engine, does it matter if you run high MP/low RPM or high RPM/low MP at 70-75% power? Yes -- you want to exert enough pressure on the ring/cylinder interface to achieve a lapping effect between the two. Actually, you could maintain 75% power for breakin. Normally, you want to be 25"/2500 for a normally-aspirated engine. |
john smith wrote in message .. .
When breaking in a new or rebuilt engine, does it matter if you run high MP/low RPM or high RPM/low MP at 70-75% power? *************************** I've broken in several new engines by following the recommendation of using full power for takeoff and climb. Then varying my RPM's by at least 100 every :10 minutes or so in cruise. This for the first 10-15 hours of flight. Using break-in oil for the first 25 hours, then switching to the appropriate weight of oil for your conditions. I've done that with radial engines, normal aspirated and turbo charged engines with all of them going to at least TBO without excessive oil consumption or loss of compression. |
Similar Threads | ||||
ROP masking of engine problems | Roger Long | Owning | 4 | September 27th 04 07:36 PM |
ROP masking of engine problems | Roger Long | Piloting | 1 | September 25th 04 07:13 PM |
Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 06:42 PM |
Corvair Engine Conversion Breakin Success | Dick | Home Built | 1 | January 11th 04 02:06 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
