#21
"Ron Natalie" wrote in message m... Newps wrote: I have had two brake failures in my 182. I was flying the backcountry in Idaho once when I lost my left brake, being at a dirt strip without a way to fix it. So we took off and flew to Cascade where there was a mechanic. It's not that big a deal. My biggest concern about doing brake checks in the air, is that I've had more times where cessna brakes have failed to RELEASE than I've had them fail to engage. I'd rather land with them failed than land with them locked. Now you have to ask your self: how likely is the brakes likely to have failed after the pretaxi brake check, how likely is pumping them in the air likely to make things WORSE, and how useful is the information that they aren't working on landing? Also true in winter if there is any chance water or slush might have splashed up on the brakes. The water and slush can freeze at altitude and the ice can lock the brakes if they are applied at altitude. |
On Sun, 02 Oct 2005 00:49:21 -0700, Ray wrote:
I'm reading a book about general aviation safety that I picked up from the library: "Flight Safety in General Aviation" by R.D. Campbell, 1987. The book suggests that for planes with hydraulic brake systems you should always check the brake pressure (by checking the pedal resistance) as part of the pre-landing checklist. This is not included in the POH checklist for any of the planes I fly and none of the instructors I have flown with have every suggested this. But it sounds like a good idea to me. Does anyone here have a brake check in their pre-landing checklist? Even on a retract and a 3000 foot strip I don't need brakes to land. OTOH I have had the parking brake freeze and had to land (arrive) hard enough to get them turning. Do I check them? Yes, then I put my feet down where I'm not likely to accidentally touch them accidentally. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com - Ray |
On Wed, 05 Oct 2005 19:47:59 -0400, Roger
wrote: Even on a retract and a 3000 foot strip I don't need brakes to land. Glad somebody wrote what I was thinking. Took primary lessons in a conventional gear plane with mucked-up mechanical brakes-any questions? OTOH I have had the parking brake freeze and had to land (arrive) hard enough to get them turning. BTDT, have had to dolly a couple onto the ramp where the arrival wasn't sufficient "to get them turning". Do I check them? Yes, then I put my feet down where I'm not likely to accidentally touch them accidentally. Have always checked 'em on roll-out prior to getting near somewhere (like a turn-off or a ramp) where I might get stupid and need them. TC |
wrote BTDT, have had to dolly a couple onto the ramp where the arrival wasn't sufficient "to get them turning". Umm, brings a new meaning to "flat spotted" doesn't it? -- Jim in NC |
I always checked the brakes on short final, saw my boss run off the runway
with an arc burn through one brake line, he didn't check the brakes. "Roger" wrote in message ... On Sun, 02 Oct 2005 00:49:21 -0700, Ray wrote: I'm reading a book about general aviation safety that I picked up from the library: "Flight Safety in General Aviation" by R.D. Campbell, 1987. The book suggests that for planes with hydraulic brake systems you should always check the brake pressure (by checking the pedal resistance) as part of the pre-landing checklist. This is not included in the POH checklist for any of the planes I fly and none of the instructors I have flown with have every suggested this. But it sounds like a good idea to me. Does anyone here have a brake check in their pre-landing checklist? Even on a retract and a 3000 foot strip I don't need brakes to land. OTOH I have had the parking brake freeze and had to land (arrive) hard enough to get them turning. Do I check them? Yes, then I put my feet down where I'm not likely to accidentally touch them accidentally. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com - Ray |
Similar Threads | ||||
Skycraft Landing Light Question | Jay Honeck | Owning | 15 | February 3rd 05 06:49 PM |
Landing and T/O distances (Was Cold War ALternate Basing) | Guy Alcala | Military Aviation | 3 | August 13th 04 12:18 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
Full before landing checklist in the pattern? | Tony Roberts | Piloting | 70 | November 15th 03 04:50 AM |
