#11
XCSoar wind calculation
On Thu, 01 Oct 2009 14:20:57 +0000, PCool wrote:
The fact that wind is not calculated means that either you are not thermalling with a constant bank angle, or that there is a very strong wind, or - most probably - that your gps is not passing correct positions to the software due to an antenna problem (weak signal reception, sufficient with no banking, but not sufficient while thermalling with high bank angles). Hp310-314 has this problem for instance. Not quite! The help screen (once I read it) says in no uncertain terms that zigzag wind calculation doesn't work if the only input is GPS. My PNA was certainly not producing sensible cruise calculated wind and, as it has a GPS as its only sensor, 'Both' must be incorrect since it uses 'Circle' while climbing and 'zigzag' in cruise. So, I've set the wind calculation to 'Circle' like the help page suggested. I'll report back once I've flown in 'Circle' mode. Should have been today, but a balky online bank and a misread forecast put paid to that. Rats! -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Oct 1, 7:38*pm, Martin Gregorie
wrote: On Thu, 01 Oct 2009 14:20:57 +0000, PCool wrote: The fact that wind is not calculated means that either you are not thermalling with a constant bank angle, or that there is a very strong wind, or - most probably - that your gps is not passing correct positions to the software due to an antenna problem (weak signal reception, sufficient with no banking, but not sufficient while thermalling with high bank angles). Hp310-314 has this problem for instance. Not quite! The help screen (once I read it) says in no uncertain terms that zigzag wind calculation doesn't work if the only input is GPS. My PNA was certainly not producing sensible cruise calculated wind and, as it has a GPS as its only sensor, 'Both' must be incorrect since it uses 'Circle' while climbing and 'zigzag' in cruise. So, I've set the wind calculation to 'Circle' like the help page suggested. I'll report back once I've flown in 'Circle' mode. Should have been today, but a balky online bank and a misread forecast put paid to that. Rats! -- martin@ * | Martin Gregorie gregorie. | Essex, UK org * * * | Mine is and has always been set to "circling". In the same plane it all worked great on another PDA with the same settings. I will try to reposition the GPS dongle next time out but note that when I examine my flights in See You, the GPS appears to work fine with no brownouts/ missing data points. FWIW, the logger time steps are set to 5 seconds cruise, 1 second thermalling. /Adam |
Similar Threads | ||||
SeeYou Wind Calculation | Ken Kochanski (KK) | Soaring | 3 | June 3rd 09 06:47 AM |
Vector Wind, Relative Wind calculation C 302/303 | [email protected] | Soaring | 2 | December 9th 08 07:23 PM |
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (1/1) | JR[_2_] | Aviation Photos | 0 | August 13th 08 09:36 PM |
Wind tunnel, Germany WWII (or close) - wind-tunnel-test.jpg (0/1) | JR[_2_] | Aviation Photos | 0 | August 13th 08 09:35 PM |
LX4000 wind calculation | AttentionLEcureuil | Soaring | 2 | June 23rd 04 04:33 AM |
