King autopilot and GPS approaches
To wit: The LOC has false nulls. Note how it looks
as you fly around the place--swithing back and forth in a seemingly random way. A place where it really matters: Jackson Hole WY. There you need to position yourself on the loc using other navaids. Thanks. Good point. Jose -- Get high on gasoline: fly an airplane. for Email, make the obvious change in the address. |
On Apr 5, 8:51 pm, "Viperdoc" wrote:
My understanding is that at least the KAP 200 and 225 will not track a glideslope (either from an LNAV+V, an LPV, or an ILS) approach when intercepting from above, which is also my experience. I also observed that adjusting the altitude with the autopilot up/down switch will negate the glideslope intercept even from below while in approach mode. Have you seen this behavior as well? The 200 should intercept from above if in attitude mode. Does not know what glideslope is in use. You can demonstrate this: but it takes a whale of a descent to set it up. You need to pass thru the gs center to make it couple. It's a bad idea in any event. The 225 will do the same thing on ILS but not sure about GPS approaches. Bill Hale |
My experience is that the GS has to be intercepted from below in order to
couple (also true for the 225). Also, it seems like use of the pitch toggle while in approach mode will prevent the AP from capturing the GS. This has happened on multiple occasions when given a late vector to intercept, along with an altitude change, while already in NAV or HEADING mode, with the APP mode armed. In other words, using the toggle switch for pitch on the AP master panel while in APP mode seems to prevent the AP from sensing and capturing the GS. This has been true for ILS as well as GPS (LNAV/VNAV or LPV) approaches. My only thought was to not engage the APP mode until the final altitude is attained for GS intercept. So, the main question is: with a King 200 AP, does the use of the pitch toggle switch on the master panel while in APP mode negate GS tracking? How about the CWS? Does a switch from APP to NAV and back to APP then allow GS tracking? |
On Apr 8, 6:19 am, "Viperdoc" wrote:
My experience is that the GS has to be intercepted from below in order to couple (also true for the 225). Also, it seems like use of the pitch toggle while in approach mode will prevent the AP from capturing the GS. This has happened on multiple occasions when given a late vector to intercept, along with an altitude change, while already in NAV or HEADING mode, with the APP mode armed. In other words, using the toggle switch for pitch on the AP master panel while in APP mode seems to prevent the AP from sensing and capturing the GS. This has been true for ILS as well as GPS (LNAV/VNAV or LPV) approaches. My only thought was to not engage the APP mode until the final altitude is attained for GS intercept. So, the main question is: with a King 200 AP, does the use of the pitch toggle switch on the master panel while in APP mode negate GS tracking? How about the CWS? Does a switch from APP to NAV and back to APP then allow GS tracking? Use of the rocker does cancel GS tracking. I wonder if it also cancels GS intercept if operated before the GS intercepts? I'd hope not. For example: Say you are in the alt mode before GS intercept. You use the rocker to change altitude 100'. Shouldn't affect the intercept. Say you are in att mode, = not altitude. You haven't intercepted yet. Seems you could change the intercept attitude before the intercept. After it couples, seems you can't use the rocker (or cws) without decoupling the GS. The message then is that you want some other attitude than that selected by GS couple. I'll believe these statements are correct. I'll have to verify them next time I'm in a plane with a 200. The thing is full of combinational logic--you are on your own!! Bill Hale |
Similar Threads | ||||
Autopilot | [email protected] | Piloting | 40 | January 5th 06 09:12 PM |
King KLX 135 and TruTrak "Digitrak" autopilot... | [email protected] | Home Built | 3 | August 31st 05 05:28 AM |
IMC without an autopilot | Jon Kraus | Instrument Flight Rules | 101 | April 18th 04 07:17 PM |
King Videos: Jeppesen Chart Review (2 tapes on eBay) Approaches & Enroute, Departures, & Arrivals | Cecil E. Chapman | Products | 0 | November 11th 03 05:14 PM |
Autopilot | Hankal | Owning | 1 | November 10th 03 02:21 AM |
