Long Tow Rope Pros & Cons
Janusz Kesik )wrote of using 30m [98ft]
tow ropes as standard and 20m[65ft] for experienced pilots in Poland. In the US I'm accustomed to being aerotowed behind a 150 to 200 foot tow rope[45-61m]. However my club has been experimenting with using a longer rope: 275ft[84m]. This struck me as non-standard and made me wonder where the standard of 200ft came from and the possible advantages/disadvantages of the longer 275ft rope. 275ft vs 200 Advantages 1. longer time to react to tow plane positional changes - easier for beginners. 2. can be easily shortened as the ends fray/wear. 3. more room to turn away from towplane for an on-the-ground aborted takeoff. 4. ? Disadvantages 1. uses 75' more runway length - less room to land ahead or land back incase of a rope break. 2. possibly lull pilots into complacency - will later be confronted with 150'. 3. longer tow rope hanging behind towplane during its landing. 4. more rope to handle and untangle - I've had to clear it off the runway in a hurry to allow a power plane to taxi onto the runway. 5. glider is smaller in towplane's mirror. 6. I've noticed the middle of the towrope continue to drag on the runway at the beginning of the tow while waiting for the towplane to takeoff. This is additional wear on the rope in the middle where it gets inspected less. 7. ? Can it make a glider that zooms too high easier or harder to recover from - for either the towpilot or gliderpilot? chris |
Long tow ropes lessen the effect of tow plane prop blast on the glider.
Less chance of the glider dropping a wing on takeoff. This is a very noticeable effect with my Libelle. Tow ropes less than 200 feet long are just too short. 275-300' seems about right to me. Got towed with a 60' rope once (really short field). No problems but it required much more precise flying. |
For the U.K. the B.G.A. give advice to be found in "Laws and Rules for
Glider Pilots" 14th edition June 2003. Under "Recommended Practices": RP12. The minimum length of aerowtow rope recommended is 150ft. However, under special circumstances a short rope may be used. The operators' attention is drawn to the following factors which may cumulatively contribute to a hazardous situation: (a) Low experience of glider and/or tug pilot (b) Gliders fitted with C of G hook only (c) Glider's C of G towards the aft limit (d) Turbulent air in the take-off area (e) Rough ground in the take-off area (f) Significant cross-wind component. RP13. After releasing the cable, the glider should turn away so that the tug aircraft pilot can see clearly that the glider is free. Under "Operational Regulations": 4.16 The sum of tows made by the tug pilot and the glider pilot, in their respective capacities, shall not be less than six. W.J. (Bill) Dean (U.K.). Remove "ic" to reply. "Wallace Berry" wrote in message ... Long tow ropes lessen the effect of tow plane prop blast on the glider. Less chance of the glider dropping a wing on takeoff. This is a very noticeable effect with my Libelle. Tow ropes less than 200 feet long are just too short. 275-300' seems about right to me. Got towed with a 60' rope once (really short field). No problems but it required much more precise flying. |
Actually the length of the rope does not effect the amount or runway
available to the glider. Think about it. so true... BT |
(chris) wrote: (Liam Finley) wrote in message . com... Disadvantages 1. uses 75' more runway length - less room to land ahead or land back incase of a rope break. Actually the length of the rope does not effect the amount or runway available to the glider. Think about it. OK, I thought about it. [ouch that thinkin' kinda hurt] And yes there is still the full length of the runway available to the _glider_. But that is only half the story. The glider+towplane combination does not gain altitude until the towplane takes off. In the case of our "cezzna" 175 the towplane does not take off until signficantly after the glider. [I like to at least pretend that I care about the safety of the towpilot also. The shorter the rope the more engine out options he has.] As an extreem example to illustrate the point: If you used a 1000' tow rope on a 2000' runway the towplane would not have climbed very much by the end of the runway. Chris 50 to 100 feet of extra runway is probably not significant unless the runway is really short. Having towed on ropes from 60 feet to 300 feet, I'll vote for the longer rope everytime. By the way Chris, Tim brought the Pawnee in on Sunday afternoon. |
Similar Threads | ||||
Ultralight Club Bylaws - Warning Long Post | MrHabilis | Home Built | 0 | June 11th 04 05:07 PM |
Flight test update - long | nauga | Home Built | 1 | June 5th 04 03:09 AM |
SWRFI Pirep.. (long) | Dave S | Home Built | 20 | May 21st 04 03:02 PM |
Simpy One of Many Stories of a Time Not So Long Ago | Badwater Bill | Home Built | 40 | March 16th 04 06:35 PM |
IFR Long X/C and the Specter of Expectations | David B. Cole | Instrument Flight Rules | 0 | February 24th 04 07:51 PM |
