#11
Like heat shrink tubing but not a tube.
Gene Seibel wrote:
On Mar 28, 8:20 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: I need to do what heat shrink tubing would be perfect for but I can't use the HST because the end of what I need to cover is too large. Is there an equivalent that will allow me to wrap the item and then heat shrink it? 20 years ago I worked at a TV station where we had a heat shrink tape that we used to repair camera cables and such. It was like a thick electrical tape that you'd wrap and then heat to shrink. However I can't seem to find anything on the internet today. ???? I may have found it. http://www.dxengineering.com/Parts.a...=DXE%2D891010# |
Gene Seibel wrote:
On Mar 28, 12:08 pm, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: Gene Seibelwrote: On Mar 28, 8:20 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: I need to do what heat shrink tubing would be perfect for but I can't use the HST because the end of what I need to cover is too large. Is there an equivalent that will allow me to wrap the item and then heat shrink it? 20 years ago I worked at a TV station where we had a heat shrink tape that we used to repair camera cables and such. It was like a thick electrical tape that you'd wrap and then heat to shrink. However I can't seem to find anything on the internet today. ???? Something like that is exactly what I'm looking for. Here's one that doesn't use heat http://dkc3.digikey.com/PDF/T071/1793.pdf -- Gene Seibel Hangar 131 - http://pad39a.com/gene/plane.html Because I fly, I envy no one. Aha, F-4 tape Check e-bay before you buy from anyone. The stuff isn't cheap. I gave made some good deals on e-bay. The tape I get from e-bay is past shelf life but is usually perfectly good. If you are in a rush try Radio Shaft, it's stocked in most stores. $10 for 3 feet if I recall correctly. The other drawback to F-4 tape is it only adheres to itself. Having said that I use the stuff for many things like between wire bundles and cannon plug clamps. Dan, U.S. Air Force, retired |
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message ... Gene Seibel wrote: On Mar 28, 8:20 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: I need to do what heat shrink tubing would be perfect for but I can't use the HST because the end of what I need to cover is too large. Is there an equivalent that will allow me to wrap the item and then heat shrink it? 20 years ago I worked at a TV station where we had a heat shrink tape that we used to repair camera cables and such. It was like a thick electrical tape that you'd wrap and then heat to shrink. However I can't seem to find anything on the internet today. ???? I may have found it. http://www.dxengineering.com/Parts.a...=DXE%2D891010# I think you can get the same stuff at Lowe's, Home Depot and alike. Years ago when I was working as an electrician, everyone referred to it as *Bishop*, but I don't know why. I have never used it with heat, but it would proabably enhance it greatly. It's a thick, rubbery, double stick tape - that over time and summer heat, simply fuses it self together. I have cut in to old splices and it appears to be almost solid rubber. It's very workable, and extremely strechy. It usually, but not always has the thin PVC film on one side to keep it from sticking to it's self, but not always. I bought some not more than a couple of months ago at Home Depot myself. 3M brand I think. |
Maxwell wrote:
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message I may have found it. http://www.dxengineering.com/Parts.a...=DXE%2D891010# I think you can get the same stuff at Lowe's, Home Depot and alike. Years ago when I was working as an electrician, everyone referred to it as *Bishop*, but I don't know why. I have never used it with heat, but it would proabably enhance it greatly. It's a thick, rubbery, double stick tape - that over time and summer heat, simply fuses it self together. I have cut in to old splices and it appears to be almost solid rubber. It's very workable, and extremely strechy. It usually, but not always has the thin PVC film on one side to keep it from sticking to it's self, but not always. I bought some not more than a couple of months ago at Home Depot myself. 3M brand I think. I'll try HD this afternoon. What I'm using in for is to cover the "tail" of the swaged control wires going to the rudder and elevator. I planned to use heat shrink tubeing but was thinking so much about putting on the Nico collars that I forgot about it. It was the first time I'd ever done it. |
Ah... now I understand. What I did for that "tail" was to put a second
collar on it so the tail was under the collar. Gig 601XL Builder wrote: Maxwell wrote: "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message I may have found it. http://www.dxengineering.com/Parts.a...=DXE%2D891010# I think you can get the same stuff at Lowe's, Home Depot and alike. Years ago when I was working as an electrician, everyone referred to it as *Bishop*, but I don't know why. I have never used it with heat, but it would proabably enhance it greatly. It's a thick, rubbery, double stick tape - that over time and summer heat, simply fuses it self together. I have cut in to old splices and it appears to be almost solid rubber. It's very workable, and extremely strechy. It usually, but not always has the thin PVC film on one side to keep it from sticking to it's self, but not always. I bought some not more than a couple of months ago at Home Depot myself. 3M brand I think. I'll try HD this afternoon. What I'm using in for is to cover the "tail" of the swaged control wires going to the rudder and elevator. I planned to use heat shrink tubeing but was thinking so much about putting on the Nico collars that I forgot about it. It was the first time I'd ever done it. |
I may do that on the rest but I had a limited number of collars at the time. My kit came with exactly the number required. I, of course screwed up the first one. John Ammeter wrote: Ah... now I understand. What I did for that "tail" was to put a second collar on it so the tail was under the collar. |
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message ... I'll try HD this afternoon. What I'm using in for is to cover the "tail" of the swaged control wires going to the rudder and elevator. I planned to use heat shrink tubeing but was thinking so much about putting on the Nico collars that I forgot about it. It was the first time I'd ever done it. In that situation you might want to consider the black Plasti-Dip. You could brush on two or three coats depending on the desired thickness. |
On Mar 28, 5:14 pm, "Maxwell" wrote:
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in ... I'll try HD this afternoon. What I'm using in for is to cover the "tail" of the swaged control wires going to the rudder and elevator. I planned to use heat shrink tubeing but was thinking so much about putting on the Nico collars that I forgot about it. It was the first time I'd ever done it. In that situation you might want to consider the black Plasti-Dip. You could brush on two or three coats depending on the desired thickness. That is good stuff. I used it on the control yokes. Takes a little practice. Bud |
Maxwell wrote:
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message ... John Ammeter wrote: How big is what you have to cover? When I worked at the local electric utility we had heat shrink tubing that was 4 inches in diameter before being shrunk. I used some of it to cover wrench handles... Gig 601XL Builder wrote: I need to do what heat shrink tubing would be perfect for but I can't use the HST because the end of what I need to cover is too large. Is there an equivalent that will allow me to wrap the item and then heat shrink it? About the size of a pencil. Will the 4 inch stuff shrink down that much? I don't think anyone makes a heat shrink that with support that much variation. Have you considered a product like *Dip-It* (sp). It is made for coating tool handles, and is sold by a lot of hardware stores. I guess it depends on what you are doing with it. Or look around for a heat shrink Tape? There is such a critter... Richard |
cavelamb himself wrote:
Maxwell wrote: "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message ... John Ammeter wrote: How big is what you have to cover? When I worked at the local electric utility we had heat shrink tubing that was 4 inches in diameter before being shrunk. I used some of it to cover wrench handles... Gig 601XL Builder wrote: I need to do what heat shrink tubing would be perfect for but I can't use the HST because the end of what I need to cover is too large. Is there an equivalent that will allow me to wrap the item and then heat shrink it? About the size of a pencil. Will the 4 inch stuff shrink down that much? I don't think anyone makes a heat shrink that with support that much variation. Have you considered a product like *Dip-It* (sp). It is made for coating tool handles, and is sold by a lot of hardware stores. I guess it depends on what you are doing with it. Or look around for a heat shrink Tape? There is such a critter... That is what I was asking about in the original post. Got a name for it or who makes it? Richard |
Similar Threads | ||||
Relesable instrument tubing | [email protected] | Soaring | 6 | February 13th 07 05:38 AM |
pvc tubing/sleeve source? | Jim Burns | Owning | 4 | September 28th 06 03:36 AM |
pvc tubing/sleeve source? | Jim Burns | Home Built | 4 | September 28th 06 03:36 AM |
Gauge of tubing??? | Michael Horowitz | Home Built | 7 | June 6th 06 01:32 PM |
Tubing strength | Ernest Christley | Home Built | 0 | January 16th 04 11:43 PM |
