#31
Percent power altitude
"Allen" wrote in message .. .
..... I was just commenting to John that I have never seen RAM recommend any particular EGT, only the 1650 degree max. I agree with the rest of your post. Allen I don't have RAM's newest engines, but their power charts for the RAM Series II and RAM Series IV TSIO-520NBs had columns showing EGT's. Typical row entries are "Takeoff (full rich) - 1450F to 1550F", "Cruise Climb (85%) - 1450F Calibration Setting", three different types of "Cruise - 1550F" entries, "Normal Descent - 1300F min, 1400F ideal", and "Approach and Landing - 1200F min, 1300 ideal". |
#32
"John R. Copeland" wrote in message ... "Allen" wrote in message .. . ..... I was just commenting to John that I have never seen RAM recommend any particular EGT, only the 1650 degree max. I agree with the rest of your post. Allen I don't have RAM's newest engines, but their power charts for the RAM Series II and RAM Series IV TSIO-520NBs had columns showing EGT's. Typical row entries are "Takeoff (full rich) - 1450F to 1550F", "Cruise Climb (85%) - 1450F Calibration Setting", three different types of "Cruise - 1550F" entries, "Normal Descent - 1300F min, 1400F ideal", and "Approach and Landing - 1200F min, 1300 ideal". You may want to call their customer service and get an updated power card. The one I have justs shows "1650 degrees maximum" for the cruise entries. They are letting you determine what you want to run at. I think you are operating them in the proper way limiting the EGT to 1525 or lower. Allen |
#33
The airframe maker often modifies the engine and
accessories, thus the POH is the authority. STC'd systems modify that. So, if you and I keep posting sound advice, perhaps the rest of the group will develop a higher level of learning. "Allen" wrote in message .. . | | "Jim Macklin" wrote in message | ... | Not exactly. It depends on whether the gauge is calibrated | to an exact temperature or whether the gauge is used only to | find relative peak and degrees above and below. It also | depends on where the probe(s) are installed. EGT has the | probes about 4 inches past the exhaust valves, | | On single-probe EGT systems such as on John's Cessna 340 the probe is | located toward the tail end of the exhaust riser, well ahead of the turbo | but past the 4" point. This was determined (by Cessna) to be the point | where the exhaust gas is hottest. Cessna POH for the 340 recommends running | at peak for many power settings below about 62%. Cessna designed their own | exhaust systems on their twins, Beechcraft had TCM design their exhaust as a | unit with the engine. | | Allen | | |
#34
Bob Moore wrote:
Bob Noel wrote Bob Moore wrote: Works out to 76% at 7,500' and 64% at 12,500', or thereabouts. OK, I'm confused. Full throttle, 64%, is 12,500' for any engine? How come my cherokee 140 couldn't even get to 12,500'? What am I overlooking? :-) The wing, of course. :-) Bob Moore Perhaps you need to pedal faster? (*chortle*) |
Similar Threads | ||||
Backup Flight Data Recorder? | Fox Two | Soaring | 14 | August 27th 06 09:42 AM |
The Deaf vs. The Colorblind | Bret Ludwig | Piloting | 17 | August 21st 06 02:08 AM |
Catastrophic Decompression; Small Place Solo | Aviation | Piloting | 193 | January 13th 04 08:52 PM |
Change in TAS with constant Power and increasing altitude. | Big John | Home Built | 6 | July 13th 03 03:29 PM |
