Double Release Failure
Old September 10th 09, 04:11 PM posted to rec.aviation.soaring
bildan
Default Double Release Failure
On Sep 10, 8:27*am, Frank Whiteley wrote:
On Sep 10, 2:37*am, (Alan) wrote:
In article Jim Beckman writes:
At 14:13 08 September 2009, FBCompton wrote:
Important Timing Aspect: *The glider (in low tow) must not touch down
much before the towplane -- this can be a hazardous aspect -- touching
down well before the towplane and stalling it. *The glider wings are
still carrying the weight of the glider while it is flying. *Once the
glider touches the wings stop lifting and the glider creates more
weight drag on the towplane, which if still well above the runway will
be slowed and may stall. *
This seems counterintuitive to me. *When the wings stop lifting, the
induced drag goes away, so the drag on the towplane should decrease. *The
only added drag is friction in the glider's main gear. *What am I missing
here?
Jim Beckman
* It seems backwards to me, too, but I have asked tow pilots about this,
and I was told that they feel the drag decrease when the glider comes off
the ground on the takeoff roll.
* I guess those wheels have a lot of drag.
* * * * Alan
Behind less powerful tow planes, I generally note a 3-5 knot jump in
airspeed immediately following glider lift off.
Frank Whiteley
Brake pucks and shoes are always in light contact with the disks or
drums to eliminate 'lost motion' so as to provide immediate braking
action. Although small, this friction is not negligible.
Aircraft tires are made from natural rubber which has very good wet
and dry traction but also has higher rolling resistance than synthetic
rubber. A single glider tire is also loaded heavily - sometimes
beyond the load rating limit which increases rolling resistance still
further.
It's reasonable to expect these taken together would result in
noticeable rolling resistance.
On a slightly different tack, I've had badly worn drum brakes lock up
on touchdown all on their own without input from me. Normally, this
is not a problem and serves as a reminder to service the brakes. If
the brake locked and/or a tire blew while landing on tow, the results
might be 'interesting'.
  #32
Old September 10th 09, 06:50 PM posted to rec.aviation.soaring
Bruce
bildan wrote:
Important Timing Aspect: The glider (in low tow) must not touch down
down well before the towplane and stalling it. The glider wings are
still carrying the weight of the glider while it is flying. Once the
This seems counterintuitive to me. When the wings stop lifting, the
induced drag goes away, so the drag on the towplane should decrease. The
only added drag is friction in the glider's main gear. What am I missing
here?
Jim Beckman
Alan
Frank Whiteley
further.
Very interesting - the white stripe on the runway costs about $100/m...
(Pictures available)
Tost Lilliput 4" rim failed radially around the pressed in liner as I
touched down in my Std Cirrus. Air pressure forced the two parts apart
against the frame. Instant locked wheel.
The tar ate a hole right through the Tost 4.00x4 that I could fit a
thumb through.
Certainly the only time the Lilliput ever stopped 66 fast though - can't
have gone much more than 50" ground roll.
Have adjusted the replacement rim to give the normal useless level of
braking force.
Bruce
  #33
Old September 10th 09, 08:58 PM posted to rec.aviation.soaring
Uncle Fuzzy
On Sep 9, 9:27*am, JS wrote:
Sounds like it's time for a Landings On Tow Soar-O-Rama on El Mirage
dry lake!
Yeehaa! Confidence building, fun and entertaining, useful for XC
tows. I'm up for the LOT Soar-O-Rama (followed of course by awesome
dry lake food, campfire, and telling of lies), but probably not at El
Mirage. Last time I was there, the lakebed was being patrolled by 6
Big Land Mothers in large SUV's. Not the same atmosphere as it was in
the 60's and 70's. How about Roach?
  #34
Old September 10th 09, 10:45 PM posted to rec.aviation.soaring
Jonathon May[_2_]
At 19:58 10 September 2009, Uncle Fuzzy wrote:
dry lake!
OK so what is a Big Land Mother?
Jon
  #35
Old September 10th 09, 11:05 PM posted to rec.aviation.soaring
Uncle Fuzzy
dry lake!
Yeehaa! *Confidence building, fun and entertaining, useful for XC
tows. *I'm up for the LOT Soar-O-Rama (followed of course by awesome
Mirage. *Last time I was there, the lakebed was being patrolled by 6
the 60's and 70's. *How about Roach?
OK *so what is a Big Land Mother?
Jon
BLM - Bureau of Land Management. It's not as bad as I had thought,
but it is a "Fee" area now, and I wouldn't go there to do the things I
did when I was a teenager (a very long time ago!)
http://www.blm.gov/ca/st/en/fo/barstow/mirage.html
  #36
Old September 11th 09, 03:29 AM posted to rec.aviation.soaring
Bob Gibbons[_2_]
On Mon, 7 Sep 2009 20:46:08 -0700 (PDT), drbdanieli
... text deleted ...
Bottom line, it's not as scary as it sounds but I would suggest proper
training before trying this on your own. Is anyone teaching this
anymore?
Barry
I don't know about today, but AC Williams and his instructors at
Southwest Soaring outside Dallas, TX would frequently do the landing
behind the towplace with his Grob 103's during flight reviews. I did a
few during BFRs in the late 80's and 90's. Mostly a non-event. The
only difficult part I found was coordinating the ground deceleration
so as to avoid overrunning the towrope on the rollout.
Bob
You (Double-A) broke it, so you fix it. Michael Baldwin, Bruce Products 0 November 30th 06 05:01 AM
Double (or more) posting flying_monkey Soaring 1 September 1st 06 03:54 PM
Double tow [email protected] Soaring 2 October 25th 05 07:16 PM
Double Tow Doug LS4 Soaring 5 October 11th 05 02:37 AM
Rare V-2 Double Launch Pic, WW2 robert arndt Military Aviation 0 July 8th 03 05:02 PM
