Repainting Wingtip
Old November 18th 17, 05:33 PM posted to rec.aviation.soaring
JB Gunner
Default Repainting Wingtip
The wingtip skid on my glider had become worn down and I didn't catch in time. I landed on a concrete runway. The under surface of the wingtip scrapped on the runway wearing off the paint. There seems to be no damage to the fiberglass just scratched gelcoat. The scrape is about two inches wide and 4 inches long. The wing tip is painted red but white gel coat shows where the paint has been scraped off.
Does anyone have some suggestions on how to repair this? I was thinking of of applying a layer of white gelcoat to build it back up then repainting the over the gel coat as it seems this is how the wingtips have been done.
Old November 20th 17, 02:49 AM posted to rec.aviation.soaring
Bob Kuykendall
Sawzall.
Old November 20th 17, 04:34 AM posted to rec.aviation.soaring
[email protected][_1_]
Bondo, sandpaper to 600 grit and 1 each rattle can of lacquer primer and white paint. And fix the skid.
Old November 20th 17, 01:01 PM posted to rec.aviation.soaring
KEN
Does anyone have some suggestions on how to repair this? I was thinking of of applying a layer of white gelcoat to build it back up then repainting the over the gel coat as it seems this is how the wingtips have been done..
http://www.simteccoatings.com/index2.ivnu
Old November 20th 17, 10:02 PM posted to rec.aviation.soaring
JB Gunner
On Sunday, November 19, 2017 at 6:49:41 PM UTC-8, Bob Kuykendall wrote:
Sawzall.
and I happen to own one of those ! maybe start a clipped wing trend
Old November 20th 17, 10:03 PM posted to rec.aviation.soaring
JB Gunner
Thanks guys for the help
Old November 20th 17, 11:08 PM posted to rec.aviation.soaring
Michael Opitz
primer and
Finding lacquer in a rattle can is not that easy unless you go to an
auto parts store like Advanced Auto or Autozone. They sell the
Duplicolor automotive touch up rattle cans, and they are lacquer.
There are a number of different shades of white that you can try to
match. I have found that the Ford "Performance White" is a very
good color match for our 35-40 year old Twin Astir Schwabbelack
gel-coat. Wal-Mart sells sandpaper packs to 3000 grit. Fill, primer,
paint (probably 3-5 coats, waiting for each coat to become touch dry
before repeating), then sand out the orange peel starting with
~600 grit. Use successively finer sandpaper grits after that, and
then some white rubbing/polishing compound to finish it off. If you
take your time, and do it right, it will come out very nicely.
The Simtec/Prestec process is also good, but I think you'll have to
buy at least a quart which (with shipping) is not cheap. It's a 2 part
epoxy, so you'll have to deal with mixing it, and also having a spray
rig to apply it correctly. Then, you'll have to clean up the spray rig
afterwards. You could also brush it on, but the edges will be difficult
to feather in and you will probably see a shade difference. I would
use the Simtec if I were going to redo a larger area, but for the
superficial (non structural) underside of a wingtip, the rattle can
solution works best for me...
Good Luck..
RO
Old November 20th 17, 11:57 PM posted to rec.aviation.soaring
Keep in mind, you can spray enamel over lacquer, but you CAN'T spray lacquer over enamel.
When you sand, it is wet, not dry. Otherwise you clog/fill up the paper real fast. You "almost" can't use too much water.
The exception is when the floor is so wet, the "boss" starts soaking water up through holes in his work shoes so his feet get damp, then, well, it gets ugly......LOL.....
Sanding gelcoat is sorta like polishing granite with wet toilet paper, lots of work with minimal progress, trust me, I know. Yes, you can go coarse, but the coarser you go, the faster you can go too far and have to lay more gelcoat down.....sigh.
PS, IIRC, spray enamel using "titanium dioxide" (or was it trioxide?) was a close cheap rattlecan for some gelcoats. Also look up "automotive touchup" online, they can provides gallons down to rattle cans of car paint colors.
Old November 21st 17, 12:30 AM posted to rec.aviation.soaring
Put some tape on it until you have enough stuff to fix to justify doing in polyester topcoat- Simtek 2481. Amazon has vinyl tape as wide as 3 inches in width in many colors.
UH
Old November 23rd 17, 02:42 PM posted to rec.aviation.soaring
K m
Duplicolor ..................
epoxy.............
The Duplicolor is cheap, Low grade garbage made by Rustoleum. Much better to take an access panel in to a Auto Body supply shop and match some paint which can be put into a rattle can.
Also, Simtec is Polyester.
new wingtip design ND Soaring 16 March 1st 15 02:27 AM
A wingtip Glenn[_2_] Aviation Photos 5 September 3rd 10 03:33 PM
Yet another PA-28 wingtip query... Mike Spera Owning 2 August 4th 09 03:07 AM
Repainting in FSX gregg Simulators 0 January 30th 08 09:55 AM
Repainting a LARK Zoltan T Soaring 4 December 19th 07 09:51 PM
