A few questions for a new (hopefully) ower
I have a 1965 Cherokee Six that had the original gyros and scatter shot layout
as well as fuses when I bought it. I used the existing holes but rearranged the instruments into a T panel when I replaced the gyros with modern units. The additional cost for moving the other instruments was small compared to the the price of the gyros, I think it was on the order of $200-300. If the original holes are not good enough for you, then expect to pay a lot more, as that is no longer a minor modification. I replaced the fuses with Klixon circuit breakers under the supervision of my A&P, which was done with a 337 that also covered adding the wing mounted landing lights, tip strobes, and a few other things. You'll probably get a better install on the circuit breakers out of an avionics shop unless you have an A&P who is really good with the electrical (most don't seem to be). Tom Nery wrote: Hi all, I just signed a P & S on a 1966 Cherokee 180C. Initially I thought it was tight in the cockpit (I'm about 6'2" and 240lbs) but when I flew it, I fell in love. Anyway, I'm assuming the prepurchase inspection will go good and in a couple of weeks be the proud owner on it. But now on to my questions: 1. Can electric trim be retrofitted (and do I really need it)? 2. Part of the dash (under the front window) is ripped, are there any suppliers of fitted dash covers? 3. I plan on upgrading the avionics (I think they are circa 1966) and wonder if I should also replace the panel to a T style (although I had no problem with the original panel)? If so what is the approx cost? 4. Lastly, can the fuses be replaced by circuit breakers and does this need to be done by an A&P or avionics shop? That's it for now, but I'm sure in the future there will be many more. Tom -- --Ray Andraka, P.E. President, the Andraka Consulting Group, Inc. 401/884-7930 Fax 401/884-7950 http://www.andraka.com "They that give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." -Benjamin Franklin, 1759 |
Hi Tom, welcome to the Cherokee club.
1. I don't think you need electric trim, I've certainly never missed it on my 140. It's also yet another thing to break, freeze, etc. I assume you have the overhead handle. You'll get used to it. 2. By dash I assume you mean the bit above the instrument panel. You can find plastic replacement parts at www.planeplastics.com. If you mean one of the side panels, you can find those at places like www.airtexinteriors.com. 3. & 4. These go together in my mind. Don't know what the cost is to go to T-style, but most avionics shops will be able to give you an estimate. It's usually just a matter of cutting a new template. You can go to places like www.avionicswest.com to look at some custom jobs as well as get a quote. Your avionics shop can replace the fuses with breakers. While you're at it, and depending on what you're upgrading to, you'll probably want to get an avionics master installed, if you don't already have one. If you don't have an avionics master, then you most likely have all your fuses on a single bus, while you're getting the fuses converted, you might as well get the bus split to make adding the avionics master easier. cheers, mark "Tom Nery" wrote in message news:KBS1b.237076$o%2.108564@sccrnsc02... Hi all, I just signed a P & S on a 1966 Cherokee 180C. Initially I thought it was tight in the cockpit (I'm about 6'2" and 240lbs) but when I flew it, I fell in love. Anyway, I'm assuming the prepurchase inspection will go good and in a couple of weeks be the proud owner on it. But now on to my questions: 1. Can electric trim be retrofitted (and do I really need it)? 2. Part of the dash (under the front window) is ripped, are there any suppliers of fitted dash covers? 3. I plan on upgrading the avionics (I think they are circa 1966) and wonder if I should also replace the panel to a T style (although I had no problem with the original panel)? If so what is the approx cost? 4. Lastly, can the fuses be replaced by circuit breakers and does this need to be done by an A&P or avionics shop? That's it for now, but I'm sure in the future there will be many more. Tom |
On Sat, 23 Aug 2003 23:16:58 GMT, "Tom Nery"
wrote: Hi all, I just signed a P & S on a 1966 Cherokee 180C. Initially I thought it was tight in the cockpit (I'm about 6'2" and 240lbs) but when I flew it, I fell in love. Anyway, I'm assuming the prepurchase inspection will go good and in a couple of weeks be the proud owner on it. But now on to my questions: 1. Can electric trim be retrofitted (and do I really need it)? Yes. All it takes is money 2. Part of the dash (under the front window) is ripped, are there any suppliers of fitted dash covers? Yes. All it takes is money 3. I plan on upgrading the avionics (I think they are circa 1966) and wonder if I should also replace the panel to a T style (although I had no problem with the original panel)? If so what is the approx cost? For the move or for the avionics? 4. Lastly, can the fuses be replaced by circuit breakers and does this need to be done by an A&P or avionics shop? If you can find an A&P to do it, go that route. Avionics shops think they're major metropolitan hospitals and charge about the same rates for the monkey work. That's it for now, but I'm sure in the future there will be many more. Tom If there will be something in the future, you may want to consider an aircraft a bit more modern. |
In article KBS1b.237076$o%2.108564@sccrnsc02,
Tom Nery wrote: I just signed a P & S on a 1966 Cherokee 180C. Initially I thought it was tight in the cockpit (I'm about 6'2" and 240lbs) but when I flew it, I fell in love. Two things which won't matter to you because you're in love and already signed: 1) A Comanche 180 would be roomier, and 2) It's always cheaper to buy an airplane equipped how you want than to equip it yourself. 1. Can electric trim be retrofitted (and do I really need it)? I don't think I would pay to add it, but it's nice. The overhead trim is nicer for tall people than the Cessna center console trim, but I never did quite memorize which way to crank. Electric trim does relieve you of that burden. 3. I plan on upgrading the avionics (I think they are circa 1966) and wonder if I should also replace the panel to a T style (although I had no problem with the original panel)? If so what is the approx cost? A new panel will cost around $1000/side. If you're doing enough other work at the same time it may not affect the labor that much. Be aware that putting semi-modern instruments and radios in this plane will cost far more than it will increase the future resale value of the plane. -- Ben Jackson http://www.ben.com/ |
All I can say is that once you have and airplane, it always costs more $$$
than you think to get all the nice gadgets installed. So, be sure you buy something you are happy with as it is, or else you might be disappointed in the end. "Tom Nery" wrote in message news:KBS1b.237076$o%2.108564@sccrnsc02... Hi all, I just signed a P & S on a 1966 Cherokee 180C. Initially I thought it was tight in the cockpit (I'm about 6'2" and 240lbs) but when I flew it, I fell in love. Anyway, I'm assuming the prepurchase inspection will go good and in a couple of weeks be the proud owner on it. But now on to my questions: 1. Can electric trim be retrofitted (and do I really need it)? 2. Part of the dash (under the front window) is ripped, are there any suppliers of fitted dash covers? 3. I plan on upgrading the avionics (I think they are circa 1966) and wonder if I should also replace the panel to a T style (although I had no problem with the original panel)? If so what is the approx cost? 4. Lastly, can the fuses be replaced by circuit breakers and does this need to be done by an A&P or avionics shop? That's it for now, but I'm sure in the future there will be many more. Tom |
my 180 sold 4 days after I listed it. I got back all the money I had put in for
avionics, didnt get back the money for the speed mods, so wasnt out that much. Jim Vadek wrote: All I can say is that once you have and airplane, it always costs more $$$ than you think to get all the nice gadgets installed. So, be sure you buy something you are happy with as it is, or else you might be disappointed in the end. "Tom Nery" wrote in message news:KBS1b.237076$o%2.108564@sccrnsc02... Hi all, I just signed a P & S on a 1966 Cherokee 180C. Initially I thought it was tight in the cockpit (I'm about 6'2" and 240lbs) but when I flew it, I fell in love. Anyway, I'm assuming the prepurchase inspection will go good and in a couple of weeks be the proud owner on it. But now on to my questions: 1. Can electric trim be retrofitted (and do I really need it)? 2. Part of the dash (under the front window) is ripped, are there any suppliers of fitted dash covers? 3. I plan on upgrading the avionics (I think they are circa 1966) and wonder if I should also replace the panel to a T style (although I had no problem with the original panel)? If so what is the approx cost? 4. Lastly, can the fuses be replaced by circuit breakers and does this need to be done by an A&P or avionics shop? That's it for now, but I'm sure in the future there will be many more. Tom |
In article , jeff writes:
my 180 sold 4 days after I listed it. I got back all the money I had put in for avionics, didnt get back the money for the speed mods, so wasnt out that much. What avionics did you add? I've added a GNS430 and figure to get no more than half back. Chuck |
I added Garmin GNS 430 GPS/Com, Garmin GMA 340 audio panel, Garmin GTX 327
transponder, Garmin GI-106a CDI, PS systems CD player, replaced most fuses with circuit breakers, replaced plastic instrument panel. there are pictures of it here http://216.158.136.80/plane/index.html Everyone had told me I wouldnt get back what I put in it, they were surprised when it sold so fast for what I was asking. One thing about selling a plane is that it will sell, to the right person. Some people will spend more to get everything they want then buying a cheaper plane and putting it all in them selves. PaulaJay1 wrote: In article , jeff writes: my 180 sold 4 days after I listed it. I got back all the money I had put in for avionics, didnt get back the money for the speed mods, so wasnt out that much. What avionics did you add? I've added a GNS430 and figure to get no more than half back. Chuck |
Just browsing the For Sale ads tells me that I can get pretty much near or
even above what I had put into the plane. My 1978 Warrior II had a KX-170B and a KT-76A --that's it. I put in a Garmin 430, Garmin 340 audio panel, GI-106a CDI, avionics master, Davtron clock and had the KX-170 overhauled. it came out to $14,000. With a 2000 interior, 8 paintjob and 600-hour FRMN engine, I think $56,000 is about right and even on the low side given the ads I see every day. I could be dreaming but I'm just going by what I see. "jeff" wrote in message ... I added Garmin GNS 430 GPS/Com, Garmin GMA 340 audio panel, Garmin GTX 327 transponder, Garmin GI-106a CDI, PS systems CD player, replaced most fuses with circuit breakers, replaced plastic instrument panel. there are pictures of it here http://216.158.136.80/plane/index.html Everyone had told me I wouldnt get back what I put in it, they were surprised when it sold so fast for what I was asking. One thing about selling a plane is that it will sell, to the right person. Some people will spend more to get everything they want then buying a cheaper plane and putting it all in them selves. PaulaJay1 wrote: In article , jeff writes: my 180 sold 4 days after I listed it. I got back all the money I had put in for avionics, didnt get back the money for the speed mods, so wasnt out that much. What avionics did you add? I've added a GNS430 and figure to get no more than half back. Chuck Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
"Marco Leon" mleon(at)optonline.net writes:
Just browsing the For Sale ads tells me that I can get pretty much near or even above what I had put into the plane. My 1978 Warrior II had a KX-170B and a KT-76A --that's it. I put in a Garmin 430, Garmin 340 audio panel, GI-106a CDI, avionics master, Davtron clock and had the KX-170 overhauled. it came out to $14,000. With a 2000 interior, 8 paintjob and 600-hour FRMN engine, I think $56,000 is about right and even on the low side given the ads I see every day. I could be dreaming but I'm just going by what I see. Assuming that you can get $56K for your Warrior right now, what would the price would have been if you hadn't put in the new avionics? Given the low-time engine and new interior, I'm guessing that it wouldn't be $14K less. If I were buying, I'd probably be willing to add a 3-4K for the Garmin 430, if the installation is approach-certified (I'm guessing that it is with the CDI). Others might feel differently, of course. All the best, David |
Similar Threads | ||||
Homebuilt Aircraft Frequently Asked Questions List (FAQ) | Ron Wanttaja | Home Built | 40 | October 3rd 08 03:13 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 2 | February 2nd 04 11:41 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 4 | August 7th 03 05:12 AM |
