#21
Flaps VS Airbrakes/Spoilers
On 18/08/2011 00:44, Eric Greenwell wrote:
Not only do they look like it, they are, in fact, bent down a bit. I saw that on my ASW 20 C, and I see it on my ASH 26 E. But that's not really due to the flaps. The clever Schleicher mixer design raises the ailerons as the flaps move to landing. ASH-25s show it best of all. That's why longer span Schleicher gliders are significantly easier to manoeuvre on final than some other contemporary designs. GC |
Here is a video example of flaps...(on powered planes)
http://freedom4um.com/cgi-bin/readart.cgi?ArtNum=133255 Scott |
On 8/17/2011 2:50 PM, GC wrote:
On 18/08/2011 00:44, Eric Greenwell wrote: Not only do they look like it, they are, in fact, bent down a bit. I saw that on my ASW 20 C, and I see it on my ASH 26 E. But that's not really due to the flaps. The clever Schleicher mixer design raises the ailerons as the flaps move to landing. ASH-25s show it best of all. My inner engineer must quibble with this, though I agree it is a clever mixer system. On my 26 E, it even puts a little washout (ailerons up slightly) in the thermalling flap position to improve control at low circling speeds. For the landing, it's the difference in control surface deflection that does it: the high lift coefficient flap section requires a very low angle of attack to produce the proper lift, so low that the low lift coefficient aileron section is producing negative lift. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
#24
On Aug 18, 7:39*am, Jonathon May wrote:
The duo discus has always been a great glider but it was not easy to land.The latest version XL has flaps connected to the air brakes,and it has transformed it's approach control to the point it is just as easy to land as a K21.When the total mass is750Kg you need to let the designer do the designing I'm experienced in the Janus (original model: flying tail, belly hook only) and in the DG1000 but I've only had one flight in a Duo. The Guy In Back got a bit preoccupied in the circuit trying to get a balky radio to work, so I set up a reasonably tight final the same as I would for a half brake approach in the DG1000 or Janus (with landing flap). Oops!! Captain she's not coming down!! It seems that they put pretty much the same wimpy brakes in the Duo as in the Janus, but without the benefit of the flaps. Full brake did end up bringing us down to the threshold (which turned out to be unnecessary as I was then told to land long) but it did require everything, not the half I'd planned for. |
#25
On 18/08/2011 08:40, Eric Greenwell wrote:
On 8/17/2011 2:50 PM, GC wrote: On 18/08/2011 00:44, Eric Greenwell wrote: Not only do they look like it, they are, in fact, bent down a bit. I saw that on my ASW 20 C, and I see it on my ASH 26 E. But that's not really due to the flaps. The clever Schleicher mixer design raises the ailerons as the flaps move to landing. ASH-25s show it best of all. My inner engineer must quibble with this, though I agree it is a clever mixer system. On my 26 E, it even puts a little washout (ailerons up slightly) in the thermalling flap position to improve control at low circling speeds. For the landing, it's the difference in control surface deflection that does it: the high lift coefficient flap section requires a very low angle of attack to produce the proper lift, so low that the low lift coefficient aileron section is producing negative lift. My inner engineer will pay that. GC |
Similar Threads | ||||
Typical glide angles with airbrakes deployed | Ronald Locke | Soaring | 8 | February 15th 11 08:31 PM |
Full-span flaperons as airbrakes? | Bret | Soaring | 21 | March 20th 10 10:39 PM |
Spoilers or Airbrakes - Whats in a name? | ContestID67 | Soaring | 29 | May 20th 08 05:21 PM |
Flaps/spoilers on which sailplanes? | [email protected] | Soaring | 11 | December 31st 06 01:12 AM |
Airbrakes Pop Out at 115 kts | ContestID67 | Soaring | 13 | May 10th 05 01:50 PM |
