#51
Glider down near Reno - pilot OK
"T o d d P a t t i s t" wrote in message ... "bumper" wrote: Since the GPS data displayed is base entirely on ground track, strong winds will skew those results. Consider crabbing into a 70+ knot wind. A change in wind speed, and thus ground track, will be displays as a roll on the Garmin panel page - - not so good if one is trying to survive some moments in IMC. It might make sense to head downwind before entering the cloud and hold that heading if you were using GPS to maintain level flight. It would produce less influence on the ground track and a less drastic roll rate indicated as compared to heading into the wind. -- T o d d P a t t i s t - "WH" Ventus C (Remove DONTSPAMME from address to email reply.) True, this might be the best option if GPS is your only tool to get down. However, in wave conditions in mountainous terrain, this might have our hapless pilot in IMC, and flying towards the next unseen downwind obstacle at blazingly high ground speeds (g). bumper |
#52
T o d d P a t t i s t wrote:
"bumper" wrote: Since the GPS data displayed is base entirely on ground track, strong winds will skew those results. Consider crabbing into a 70+ knot wind. A change in wind speed, and thus ground track, will be displays as a roll on the Garmin panel page - - not so good if one is trying to survive some moments in IMC. It might make sense to head downwind before entering the cloud and hold that heading if you were using GPS to maintain level flight. It would produce less influence on the ground track and a less drastic roll rate indicated as compared to heading into the wind. My experimenting showed going downwind made the heading very insensitive to turning (the opposite of going upwind, as you might guess). I suspect this would be just as much a problem as the very sensitive situation going upwind, but I haven't tried either in realistic situations. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#53
... My experimenting showed going downwind made the heading very insensitive to turning (the opposite of going upwind, as you might guess). I suspect this would be just as much a problem as the very sensitive situation going upwind, but I haven't tried either in realistic situations. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA Eric, I thought that too, but imagine downwind would still be a better than upwind - - if all you had was a GPS to stay upright. In strong wave conditions, as you know, the ship might be stationary over the ground or moving in any direction relative to its nose. I've watched my moving map go spastic trying to figure out which way to orient the display while nosed into 70 knots. Up like an elevator . . . I love Minden!! bumper |
#54
Glider down near Reno - GPS Errors
Just as an experiment, set your GPS to go to a local
feature, such as your clubhouse, and try walking backwards away from it while holding the GPS unit. You will then find that the 'compass' needle will tell you that the feature is behind you! No I didn't believe it either at first, but a friend of mine flying sufficiently slowly in wave near the Long Mynd site in Shropshire, England, as to back up slightly relative to the ground, reported this precise effect. He could clearly see the Mynd clubhouse in front of him, but the GPS needle was telling him it was in the opposite direction. Remember that a GPS is not a compass and it tells you what track you are making good, rather than which direction you are pointing. Not normally a problem I know, But it can become one when you are flying into a very strong wind, as in wave flying, and not moving over the ground, or even going backwards. Derek Copeland At 02:00 13 November 2005, Bumper wrote: 'Eric Greenwell' wrote in message ... My experimenting showed going downwind made the heading very insensitive to turning (the opposite of going upwind, as you might guess). I suspect this would be just as much a problem as the very sensitive situation going upwind, but I haven't tried either in realistic situations. -- Change 'netto' to 'net' to email me directly Eric Greenwell Washington State USA Eric, I thought that too, but imagine downwind would still be a better than upwind - - if all you had was a GPS to stay upright. In strong wave conditions, as you know, the ship might be stationary over the ground or moving in any direction relative to its nose. I've watched my moving map go spastic trying to figure out which way to orient the display while nosed into 70 knots. Up like an elevator . . . I love Minden!! bumper |
#55
'Eric Greenwell' wrote in message ... My experimenting showed going downwind made the heading very insensitive to turning (the opposite of going upwind, as you might guess). I suspect this would be just as much a problem as the very sensitive situation going upwind, but I haven't tried either in realistic situations. -- Change 'netto' to 'net' to email me directly Eric Greenwell Washington State USA Eric, I thought that too, but imagine downwind would still be a better than upwind - - if all you had was a GPS to stay upright. In strong wave conditions, as you know, the ship might be stationary over the ground or moving in any direction relative to its nose. I've watched my moving map go spastic trying to figure out which way to orient the display while nosed into 70 knots. Up like an elevator . . . I love Minden!! bumper I have tried flying straight using my moving map at maximum scale and consider it just one step more practical than screaming. |
#56
Remember that a GPS is not a compass and it tells you what track you are making good, rather than which direction you are pointing. I've seen my moving map (Glide Navigator II) flip on me in high wind (60+ kts) wave, showing the Gardner MA, USA, airport behind me when I could see it in front of me. It's probably a difficult software fix and not important enough to bother with. Tony V htth://home.comcasst.net/~verhulst/SOARING |
#57
Tony Verhulst wrote:
I've seen my moving map (Glide Navigator II) flip on me in high wind (60+ kts) wave, showing the Gardner MA, USA, airport behind me when I could see it in front of me. It's probably a difficult software fix and not important enough to bother with. At a guess changing the Glide Navigator map orientation setting from Heading Up to North Up would do the trick. Same would work for almost any PDA moving map system I should think. -- martin@ | Martin Gregorie gregorie. | org | Zappa fan & glider pilot |
#58
I've seen my moving map (Glide Navigator II) flip on me in high wind (60+ kts) wave, showing the Gardner MA, USA, airport behind me when I could see it in front of me. It's probably a difficult software fix and not important enough to bother with. I'd say an impossible software fix. All the GPS engine can do is detect where it is, and hence which way it's moving. Since it's not a compass it can't detect how it's oriented without additional hardware. As an obvious illustration, try holding it upside down. -- Real name is richard |
#59
Benign spirals, etc. [was Glider down near Reno - pilot OK]
The phugoid should have a stable amplitude (not diminishing) with stick
fixed, but not with stick free. |
#60
GPS heading is based on, obviously, your ground track (the GPS has no
knowledge of your airspeed or magnetic heading). If your ground speed is low, or zero, (as may well be the case in wave) the GPS heading is useless. The only way to get useful information is to speed up so that the ground speed is, at least, a healthy fraction of the airspeed (say 25-50%). This, of course, means you are no longer "parked" in the wave and are moving relative to the ground. In your crabbing scenario, a wind speed change will lead to a change in your heading over the ground. In IMC, the pilot will not know whether he rolled or whether the wind changed, at least not immediately. If he rolled, however, the heading will continue to change, while if the wind speed changed to, and remainded constant at, a new value the heading will initially change and then remain at the new heading. In both situations the pilot can react be rolling the opposite direction and either: 1. correct the roll or 2. commence a turn that returns the heading to the desired point. A better solution for strong wave conditions is an artificial horizon, which are now available in electronic form (although the power consumption is somewhat higher than I would like). But GPS can still be used for an emergency descent in IMC conditions, IF you keep your airspeed significantly above the wind speed. Tom |
Similar Threads | ||||
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Can a Private Pilot tow gliders and get paid? | BTIZ | Soaring | 1 | October 17th 04 01:35 AM |
Elder Statesman/Most Senior Glider Pilot? - Otto Zauner | Mike Fadden | Soaring | 15 | October 5th 04 04:25 PM |
Toronto Area Glider Pilot Ground School Starts Thu. March 25, 2004 | Ulf | Soaring | 0 | March 3rd 04 05:02 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
