Visulalizing the Finish Cylinder
Old March 24th 05, 11:48 AM
Andy,
You point out many of the unknowns that concern me, while advocates are
taking a "don't worry, be happy" approach to addressing them. I keep
looking for the "name" that characterizes what I think of the
cylinder... You've helped me find it.
"The three monkeys finish"
  #42
Old March 24th 05, 02:36 PM
John Sinclair
OC, Your pessimistic approach to the finish cylinder
makes me wonder just how many times you have flown
it? I have found no real promlems in its use at Reese,
Parowan, Minden, Montague & Ephrata. Where have you
flown it and exactly what problems did you encounter?
JJ
At 12:00 24 March 2005, wrote:
Andy,
while advocates are
taking a 'don't worry, be happy' approach to addressing
them. I keep
looking for the 'name' that characterizes what I think
of the
'The three monkeys finish'
  #43
Old March 24th 05, 05:18 PM
Andy Blackburn
I had two problems at Parowan that were manageable,
but gave me pause because they could have been worse.
- Six gliders entering the downwind at once. Because
the finish is totally unmanaged, gliders tend to finish
in one sequence, but enter the pattern in a different
sequence several minutes later. In my case it lead
to some maneuvering low on base leg.
- At the cylinder edge, doing 130-140kts I pick up
out of the corner of my eye another competitor on a
perpendicular course with divebrakes full open flying
right at me. I doubt he could see me because he was
nose-high and decending rapidly.
I don't want to be as wuss, because I don't feel particularly
at risk finishing under any system. I would observe
that the times I have been most concerned flying are
when I have encountered conflicting traffic that I
wasn't aware of - someone entering a thermal improperly,
reverse courselines on a flat triangle, etc. Under
any finish scheme, the airport is going to be a high-traffic
area. The real question is will I know where the traffic
is or not? I've done my share of wingtip-to-wingtip
finishes - hooking the gate and everything. But I always
knew where everyone was because our courses slowly
converged over 10, 15, 20 miles. Not so with the cylinder.
Some of the culprit here is the new tasking - this
can't happen in a MAT unless you put a steering turn
in, and TATs spread pilots out too, but some of the
problem is the nature of the cylinder where people
don't always behave in preditcable ways at the line,
probably because they don't have to.
On the energy question, I suspect this represents
100% of JJ's accidents (BTW JJ - you did a nice job
speculating what may have happened in one case. I
for one would like to hear the particulars on the other
4 when you get your energy back). The conventional
wisdom is that a higher finish line will be safer.
My speculation is that we are trading old problems
for new ones - only time will tell. The old problem
is someone, tired and dehydrated, who finishes at 50'
and 90 knots. The new problem is someone, tired and
dehydrated, who finishes at 500', 1 mile out and 50
knots then drifts towards the airport. Both end up
at some sort of confused 'pattern' entry with about
300'. Then we've added a new problem of people who
mijudge the glide and find they need to climb to get
to 500' - I can imagine all kinds of chaos coming out
of that - apparently some has already.
Of course there's no substitute for good judgement
and vigilence - I'm a little concerned that people
feel like the cylinder has absolved them of the need
to stay on the ball while finishing.
Hope that didn't cost me my hug.
9B
  #44
Old March 25th 05, 02:57 AM
Andy Blackburn
At 05:00 23 March 2005, John Sinclair wrote:
Andy,
FAR 91.119c states that we are not allowed to fly within
500 feet of people, places or things, Except as necessary
for takeoff and landing.
If I find myself at or below 500 feet at the 1 mile
cylinder, I am allowed to continue my descent to the
field and make any appropriate pattern, including no
pattern to complete my landing. I am not allowed to
dive to within 500 feet at the edge of the cylinder
if there is any people, places or things there.
I don't think I need to restate what the low pass involves,
but just how far is the gate crew from the finish line?
500 feet? In most cases that I have seen, the gate
crew is sitting at the start of the finish line.
Just one more reason to go exclusively with the finish
cylinder.
I think I've been pretty fair about recognizing some
good arguments
you've made. Honestly this one feels like splitting
hairs because it tries to
read the pilot's intent. Was he low for a 'fun' pass
or because, as you say,
'I found myself at or below 500' '. The dive for the
gate is no different than
the dive for the cylinder IMHO, except one involves
a straight line and one
involves a curved line.
If we're using GPS, why do we need a gate crew anyway?
I still want that hug - maybe at Parowan we can have
a ceremony.
9B
  #45
Old March 25th 05, 02:10 PM
John Sinclair
Morning Andy,
I remember a busy day at Parowan, several finishers
milling around. The guy I was most worried about was
slope soaring the near by mountains and just waiting
for things to clear out a bit. The problem comes from
people that finish with excess altitude and that happens
with either gate.
Been working on 'Finish Gate Accident no. 2', but right
now I got to go flying. Post frontal in the valley
and Q's are a popping.
Cheers,
JJ
9B
Seniors Contest Bob Fidler Soaring 68 March 17th 05 03:50 AM
Why does the Sporting code require "Goal" to be a finish point??? Mark Zivley Soaring 31 October 18th 04 10:31 PM
TAT scoring question Mark Zivley Soaring 34 September 6th 04 04:55 AM
Carbon Fiber - Achieving Glossy Finish w/o GelCoat RKT Home Built 7 March 8th 04 06:15 AM
Start Anywhere Cylinder (SSA rules proposal) Mark Navarre Soaring 15 September 25th 03 01:13 PM
Copyright 2004-2024 AviationBanter.
