Engine stoppage during idle
Why was the pump on and why were you at full rich?
Peter wrote: IO-540-C4, Socata TB20 Just got this today. Landed, taxied off the runway, and before doing the post-landing procedure (ie, with the mixture on full rich and the fuel pump still running) noticed the revs to be very low, c. 500 and then unsuprisingly the engine stopped. Initially I suspected the idle setting had got moved. Did a start (hot start, the usual lots of cranking) and all was fine. Idle is perfect at 700rpm, just the way it was set up by a very good Socata engineer a couple of years ago. Mag checks fine, EDM700 fine. Nothing special about the conditions. OAT +19C, DP +15C, 1hr flight at 2000ft. Enquiries suggest this sort of thing happens every once in a while. I just haven't had it in 500+ landings in this aircraft, so it is suprising. Any views would be much appreciated. I am considering having the fuel system inspected for debris/blockages. |
You're running way too rich.
Peter wrote: Newps wrote Why was the pump on and why were you at full rich? Because that is how it is when one lands. I have done some test runs today and found that the problem can be repeated if one quite decisively pushes the throttle shut - that drops the RPM from 700 to about 500. It happens only when the engine is warm; say CHT of 330F or higher. The mixture doesn't really affect it. So it seems OK, but I might inspect the throttle linkage anyway. |
Well Peter, I don't know who is telling you to configure the engine
that way for landing but you may want to poll the big bore drivers on here... I can tell you from experience with injected 360-520-540-720, that many a hot engine will quit if used like that... Personally, I leave the engine partially leaned in the landing pattern... denny Peter wrote: Newps wrote Why was the pump on and why were you at full rich? Because that is how it is when one lands. |
Peter wrote:
"Denny" wrote Well Peter, I don't know who is telling you to configure the engine that way for landing but you may want to poll the big bore drivers on here... I can tell you from experience with injected 360-520-540-720, that many a hot engine will quit if used like that... Personally, I leave the engine partially leaned in the landing pattern... I can see it both ways. In the UK, the SOP is to go max-rpm and full-rich on short final, in anticipation of a go-around. That's SOP in the US, too. I've never heard of what Denny and Newps are suggesting, but then I don't fly a big-bore, and don't keep up with their SOPs. |
Yes, sometimes this is necessary. Especially at high density
altitude. --Dan Denny wrote: Well Peter, I don't know who is telling you to configure the engine that way for landing but you may want to poll the big bore drivers on here... I can tell you from experience with injected 360-520-540-720, that many a hot engine will quit if used like that... Personally, I leave the engine partially leaned in the landing pattern... denny Peter wrote: Newps wrote Why was the pump on and why were you at full rich? Because that is how it is when one lands. |
There's two reasons not to go to full rich for landing. For me the most
important is density altitude. I live at 3650 msl and see lots of flatlanders land full rich on a 90 degree day and have the engine quit on rollout. Running full rich in these situations is just ****ing power away when you need it. The second reason is fouling the plugs. Dave Butler wrote: Peter wrote: "Denny" wrote Well Peter, I don't know who is telling you to configure the engine that way for landing but you may want to poll the big bore drivers on here... I can tell you from experience with injected 360-520-540-720, that many a hot engine will quit if used like that... Personally, I leave the engine partially leaned in the landing pattern... I can see it both ways. In the UK, the SOP is to go max-rpm and full-rich on short final, in anticipation of a go-around. That's SOP in the US, too. I've never heard of what Denny and Newps are suggesting, but then I don't fly a big-bore, and don't keep up with their SOPs. |
"Dave Butler" wrote in message ... Peter wrote: In the UK, the SOP is to go max-rpm and full-rich on short final, in anticipation of a go-around. That's SOP in the US, too. I've never heard of what Denny and Newps are suggesting, but then I don't fly a big-bore, and don't keep up with their SOPs. In a piston popper, of any size, the engine responds quickly enough that full rich/RPM's is more damaging, unless you like lead fouling in your engine. -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO (MTJ) |
"Newps" wrote in message ... There's two reasons not to go to full rich for landing. For me the most important is density altitude. I live at 3650 msl and see lots of flatlanders land full rich on a 90 degree day and have the engine quit on rollout. Running full rich in these situations is just ****ing power away when you need it. The second reason is fouling the plugs. Quite! http://www.avweb.com/news/pelican/182085-1.html (last couple, three paragraphs) -- Matt --------------------- Matthew W. Barrow Site-Fill Homes, LLC. Montrose, CO (MTJ) |
On 19-Sep-2006, Peter wrote: I have done some test runs today and found that the problem can be repeated if one quite decisively pushes the throttle shut - that drops the RPM from 700 to about 500. It happens only when the engine is warm; say CHT of 330F or higher. The mixture doesn't really affect it. So it seems OK, but I might inspect the throttle linkage anyway. This sure suggests that the problem lies with the throttle idle stop, possibly a mechanical misalignment between the stop adjustment ant the cam on the throttle control that is supposed to hit it. The misalignment may be temperature related, i.e. the cam/stop orientation changes just a bit between cold and hot conditions. At any rate, if the engine otherwise runs fine this does not seem like a serious problem. -Elliott Drucker |
On Wed, 20 Sep 2006 10:20:17 -0700, "Matt Barrow"
wrote: "Newps" wrote in message ... There's two reasons not to go to full rich for landing. For me the most important is density altitude. I live at 3650 msl and see lots of flatlanders land full rich on a 90 degree day and have the engine quit on rollout. Running full rich in these situations is just ****ing power away when you need it. The second reason is fouling the plugs. Quite! http://www.avweb.com/news/pelican/182085-1.html (last couple, three paragraphs) I'm learning to hate sites like this. I'm logged in via another route, but it's not smart enough to know that when I follow this link. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com |
Similar Threads | ||||
Engine stoppage during idle | Peter R. | Owning | 2 | September 19th 06 03:57 PM |
Engine stoppage during idle | Denny | Owning | 0 | September 19th 06 01:28 PM |
Autorotation ? R22 for the Experts | Eric D | Rotorcraft | 22 | March 5th 04 06:11 AM |
What if the germans... | Charles Gray | Military Aviation | 119 | January 26th 04 11:20 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
