The Swedish Model: How to build a jet fighter.
Old May 10th 08, 01:08 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Douglas Eagleson
Default The Swedish Model: How to build a jet fighter.
On May 9, 4:57*pm, Dan wrote:
Douglas Eagleson wrote:
snip
The russian mig-30 that literally stops in mid
flight and recovers, is another example. A forward canard allows this.
* * The "cobra" maneuver is not a very good combat move. Do a simple
free body diagram to see what happens to acceleration and velocity
vectors. The MiG is a sitting duck throughout the maneuver and takes a
long time to recover.
Dan, U.S. Air Force, retired
The maneuver is obviously only a technical ability. As dog fighting
goes a well planned first approach with missles always wins.
A dogfight as a rule can be forced with the lost aircraft. A sucker
aircraft and absorb/take the radar.
after this occur a true missilefree dogfight happens.
All free battle has an AMERICAN superior first strike built in. If
this is lost, then what happens is a secondary senario occurs. An
litteral aircraft to aircraft and attritionloss war. When attrition
dictates a winner what happens?
So large air battle planning fails when aircraft performance only
dictates.
Old May 10th 08, 01:48 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Dan[_2_]
snip
It's only good for air shows.
As dog fighting
Not always. What happens if the missile fails to perform or the
target outmaneuvers it?
Please translate.
All wars are a function of attrition.
dictates.
Not to put to fine a point on things, but ALL battle planning is
limited to by the assets on hand to include available technology.
Old May 10th 08, 07:26 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Roger Conroy[_2_]
"Dan" wrote in message
snip
As dog fighting
Not always. What happens if the missile fails to perform or the target
outmaneuvers it?
Please translate.
It might not always be readily apparent but not all wars involve Americans
either.
But why are we arguing with a bot anyway?
dictates.
Not to put to fine a point on things, but ALL battle planning is limited
Old May 10th 08, 01:03 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
St. John Smythe
Got to admit I too suspected a bot.
Bot or not, the engagement doesn't seem worth the fuel.
sjs
Old May 10th 08, 01:59 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
snip
And impressing the Chicks.
As dog fighting
A well planned anything usually wins over an ad-hoc response.
Plan B. There always needs to be a Plan B.
Please translate.
That would be nice.
Even if it is simply an attrition of will. A Semi-decent example
would be the Iraqi Air force in both conflicts. They didn't even try.
dictates.
Which would of course include Intel, such as the enemies weapon
platforms capabilities. There is a reason the "Top-Speed" of US Naval
Vessels is never mentioned, or talked about in only general terms. If
you know what the other guy is capable of, you've got one leg up in
the planning process. If you know where he is at & what he is going
to do (tactics) you've got another leg up. Some of the major naval
battles of WW II were won by pure dumb luck. Both sides planned, but
one found out the location of the other first.
"Before all else, be armed" -- Machiavelli
Old May 10th 08, 02:01 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
On Sat, 10 May 2008 08:26:43 +0200, "Roger Conroy"
snip
As dog fighting
outmaneuvers it?
Please translate.
either.
Perhaps not directly, but since the US is the number one Arms Dealer
in the world, perhaps we are if even just by proxy.
dictates.
Old May 10th 08, 11:27 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Douglas Eagleson
On May 10, 2:50*pm, (Richard Casady)
On Fri, 09 May 2008 23:21:39 -0700, Steve Hix
(Richard Casady) wrote:
On Fri, 09 May 2008 21:45:15 GMT, Ed Rasimus
And what will happen when someone invents a doppler radar that doesn't
see ground clutter?
I was under the impression that look down, shoot down had been around
for many years.
Ed was gigging Eagleson. Who isn't likely to notice, sadly.
While some think Eagleson is a 'bot, my theory is mental illness.
Casady
I talk funny it is mental illness. What a kick.
Old May 10th 08, 11:54 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
WaltBJ
On May 10, 3:27 pm, Douglas Eagleson
SNIP
SNIP:
That illness is truly unfortunate and you can't help it.
What you can do to help yourself is to educate yourself in
aerodynamics and later on, fighter capabilities and tactics. Your
conclusions are faulty because you do not truly understand these
subjects. I recommend, at the least, a visit to your local library and
spend a month or so studying these areas. At the present time you are
an amateur trying to argue with professionals who devoted a career to
the subject.
Walt BJ
LETS BUILD A MODEL PLANE adelsonsl Aviation Photos 1 May 16th 07 11:10 PM
Swedish! Owning 3 March 3rd 06 12:44 AM
The end of the Saab Viggen - The legendary Swedish jet fighter Iwan Bogels Simulators 0 April 19th 05 07:22 PM
The Very Last Operational New German Fighter Model Of WW2 Garrison Hilliard Military Aviation 13 January 13th 04 03:31 PM
RV Quick Build build times... [email protected] Home Built 2 December 17th 03 03:29 AM
