Compass turning error
I got Pete's explanation, and it's close to my own mental way of remembering
this. The metaphor that helps me to visualize the N/S compass turning error in the northern hemisphere is a string with one end tied to the back side of the compass ring, behind where "S" (South) is painted, and the other tied to the north pole. When I'm near the world's equator, this string pulls the compass in the direction it's supposed to go (it always keeps the side with "S" painted on it as close to the north as possible since the string is parallel to the ground at that point), and there's no turning error. However, as I approach the north pole, the string begins to pull more and more downward, toward the ground (the pole itself). Using this metaphor, I can "see" the effect that the string has on the compass; as I bank, the string will pull the side of the compass on which "S" is written downward, toward the earth. The rotation of the compass on its axis (the turning error) then becomes apparent as I follow this metaphor through by visualization. "Casey Wilson" wrote in message ... Okay, I know the compass swings into a turning error when initiating a turn from any direction other than East or West and that the amount of turning error is greatest when starting from either North or South. I even know a couple of the cute acronyms like UNOS (Undershoot North - Overshoot South) to aid in rolling out on the correct heading. My questions a What is the mechanics for causing the turning error in the first place? Why doesn't the effect happen when starting from East or West, yet develops as the turn progresses to the North or South? |
Perhaps I should have mentioned my my post (above), that in the metaphor,
the "string" represents nothing more than the pull of the magnet (which is physically located in the same place as the "string" is tied; on the back of where "S" is painted) towards the north pole (the other side of the "string"). "Marty Ross" wrote in message et... I got Pete's explanation, and it's close to my own mental way of remembering this. The metaphor that helps me to visualize the N/S compass turning error in the northern hemisphere is a string with one end tied to the back side of the compass ring, behind where "S" (South) is painted, and the other tied to the north pole. When I'm near the world's equator, this string pulls the compass in the direction it's supposed to go (it always keeps the side with "S" painted on it as close to the north as possible since the string is parallel to the ground at that point), and there's no turning error. However, as I approach the north pole, the string begins to pull more and more downward, toward the ground (the pole itself). Using this metaphor, I can "see" the effect that the string has on the compass; as I bank, the string will pull the side of the compass on which "S" is written downward, toward the earth. The rotation of the compass on its axis (the turning error) then becomes apparent as I follow this metaphor through by visualization. "Casey Wilson" wrote in message ... Okay, I know the compass swings into a turning error when initiating a turn from any direction other than East or West and that the amount of turning error is greatest when starting from either North or South. I even know a couple of the cute acronyms like UNOS (Undershoot North - Overshoot South) to aid in rolling out on the correct heading. My questions a What is the mechanics for causing the turning error in the first place? Why doesn't the effect happen when starting from East or West, yet develops as the turn progresses to the North or South? |
Peter Duniho wrote: Of course, everything is reversed in the southern hemisphere. My understanding is that one end of the magnet inside the compass is attracted to the magnetic north pole, and that causes the dip. If this is the case, the effect would not be reversed in the southern hemisphere. George Patterson Brute force has an elegance all its own. |
Similar Threads | ||||
Vertical Card Compass Mystery | Rosspilot | Owning | 3 | November 3rd 04 06:01 PM |
help - whiskey compass has gone wild | Jim | Owning | 5 | July 12th 04 03:33 AM |
Pilot Error? Is it Mr. Damron? | Badwater Bill | Home Built | 3 | June 23rd 04 04:05 PM |
How can a compass suddenly go out by 20 degrees? | Bob Chilcoat | Owning | 25 | February 21st 04 10:58 PM |
Strange compass behavior | me | Owning | 10 | February 14th 04 04:24 AM |
