#21
GPS interference and contests
Hi Martin!
Why do you think that GPS has a bad coverage at the poles? The inclination and orbital altitude of Galileo is a little bit higher than for GPS, so there is potential for a small performance increases. Reading the public ICD of Galileo available from http://www.galileoju.com/page2.cfm and comparing it with the public ICD of GPS available from http://www.navcen.uscg.gov/gps/moder...on/default.htm you may draw your own conclusion. I would expect that current GPS receivers have not implemented the Galileo ICD. But I seem to remember that some manufacturers claim to be Galileo ready, but I wounder how they are able to do this from a legal point of view. Best Regards Hans Martin Gregorie schrieb: Bruce wrote: ESA has not started "commercial" use of its satellites yet - most of it's stations are terrestrial at present - so I suppose for the very short term the view that "we own it we can do what we like with it is valid". By 2010 there will be two satellite systems. Then what? Technically, there are already two: GLONASS is the other, though I'll admit I've never seen a receiver for it. I read the other day that it had rather fallen on hard times, but that the Russians are about to bring the constellation back to full strength and possibly to open it up. I wonder if either Galileo or GLONASS will provide better polar coverage than GPS? There seems to be some confusion as whether current GPS receivers will work with Galileo. I understand that the frequencies are similar and the satellite IDs have been arranged to avoid clashes. I asked this question after an article on Galileo appeared in New Scientist: apparently the correct answer is "suck it and see" because nobody knows for sure. |
From the way they are describing it, it looks like they are sending a
signal from the ground. So there is an easy countermeasure, install a nullifying GPS-antenna and have the null pointing to the location of the signal source. In the beginning of GPS flight recording there where many interfering signal sources in Italy. The way to overcome the problem was to install the GPS antenna on a large grounding plane, which made the GPS antenna to ignore the interfering signal sources. Greg Arnold schrieb: 309 wrote: On Jan 21, 9:16 pm, Greg Arnold wrote: Does the military ever tell anyone what area is affected by the jamming? I don't see that in the NOTAM. It seems that would be useful information. See https://pilotweb.nas.faa.gov/distrib...nterQuery.html or: !GPS 01/021 ZLA GPS IS UNRELIABLE AND MAY BE UNAVAILABLE WITHIN A 324 NM RADIUS OF 372023.4N/1160158.4W (LOCATED WITHIN THE TONOPAH TEST RANGE) AT FL400, DECREASING IN AREA WITH DECREASE IN ALTITUDE TO 277 NM RADIUS AT FL250, 198 NM RADIUS AT 10,000 FT MSL AND 197 NM RADIUS AT 4,000 FT AGL. THE IMPACT AREA ALSO EXTENDS INTO THE MEXICAN FIR. 1900Z-0845Z DLY WEF 0801211900-0801260845 They're describing a VOLUME about the jamming point: the higher you are (diamond altitude, a little under FL400), the farther you need to get away to be "unimpacted." Notice they admit the jamming area includes Mexican airspace. Do you think Europe might be next? Plot the lat-lon given in SeeYou, draw your circle at FL250 (yeah, it would be nice if they gave you 17,999) and if your path flies through that line, your record might be toast. The 277 nm radius at FL250 roughly covers San Francisco to the west, San Diego to the south, and Salt Lake City to the east. I am not sure that this information is terribly helpful for pilots (power as well as soaring) who would like to know if they can believe what their GPS is telling them. They've got reasons for doing this, and in the really long view, I believe that at least SOME of what they do actually protects my ability (privilege) to fly and soar. I am skeptical. -Pete |
hans wrote:
Why do you think that GPS has a bad coverage at the poles? The inclination and orbital altitude of Galileo is a little bit higher than for GPS, so there is potential for a small performance increases. For some reason I thought the constellation was in low orbits and so had limited polar visibility. I was wrong there. It turns out GPS uses a 25,000 km orbit, inclined at 55 degrees to the equator. The orbits reach 55 degrees north and south, which gives plenty of polar visibility. There will still be at least 4 satellites visible at any time. The satellites are closer to the horizon in polar regions so positional accuracy isn't affected, though I suppose shielding by surface features could be more of a problem than it is at lower latitudes. However, height accuracy must deteriorate close to the pole because the satellites are never overhead: you get max vertical accuracy with 3 or more satellites near the horizon and one overhead. I would expect that current GPS receivers have not implemented the Galileo ICD. I'm certain you're right, especially about the units with the original Garmin 12 channel receivers (12XL, II+, III+, GPS35 etc), because apart from anything else its hard to imagine that these could cope with the different time codes used by GPS and Galileo. The time conversion algorithms must have been published long after these receivers were designed. Thanks for prodding me into doing a quick search for the stuff I didn't know. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#24
On Jan 22, 3:55 am, 309 wrote:
Or should I take up bowling, instead? -Pete Don't do it ! But if you do take up bowling we'll want to see it on You tube ;-) See ya, Dave |
#25
On Jan 22, 5:31 pm, wrote:
On Jan 22, 3:55 am, 309 wrote: Or should I take up bowling, instead? -Pete Don't do it ! But if you do take up bowling we'll want to see it on You tube ;-) See ya, Dave I haven't been bowling lately...have they transitioned to GPS loggers for scoring? ;-) -Pete |
#26
On Jan 22, 10:37*am, Greg Arnold wrote:
309 wrote: [...] The 277 nm radius at FL250 roughly covers San Francisco to the west, San Diego to the south, and Salt Lake City to the east. *I am not sure that this information is terribly helpful for pilots (power as well as soaring) who would like to know if they can believe what their GPS is telling them. I am skeptical. But pilots should always be skeptical about black box navigation. The GNSS (Global Navigation Satellite System, a name that encompasses all satellite navigation systems) community is well aware that jamming has an effect on civil air traffic, powered and glider. That's why the AIM outlines a procedure for medical flights to request that the tests be stopped. I have done a lot of medical flying, and a lot of those small mountain airports have GPS approaches. If I had needed the approach I could have asked ATC to ask the controlling agency to stop the test. I'm sure this would have been an expensive proposition for them, but there is also a strong life preservation ethic among GNSS engineers and operators. They go to work with the motto that "Someone, somewhere is depending on my work to save his life." The latest word is that enhanced LORAN will be preserved as a backup to GPS. I have never heard of a glider with a LORAN receiver, nor have I heard of a handheld LORAN receiver, but it might be something to consider. Many aircraft have inertial reference units to supplement GPS; these are light but drift, so usually there is some kind of Kalman filter blending the solutions. One can also use DME/DME updating if there are enough DME stations in sight, but DME uses a ton of power and is unsuitable for gliders. |
Similar Threads | ||||
sectionals for contests | BB | Soaring | 17 | January 23rd 07 06:54 PM |
CONTESTS UPDATE USA # 711 reporting | [email protected] | Soaring | 2 | January 14th 06 09:19 PM |
SSA Web Page - Contests | Bob | Soaring | 8 | August 23rd 04 02:31 AM |
ideas for fun contests at fly-ins | Hoot | Piloting | 9 | April 30th 04 10:58 AM |
Motorglider participation in USA contests | Eric Greenwell | Soaring | 0 | October 11th 03 02:17 AM |
