Checklist for maintenance kit
On Jan 17, 8:52*pm, Tuno wrote:
I've seen some excellent lists on this forum for the pilot, glider, and landout/emergency kit. I'm wondering if anyone has developed a list for the tools, parts & materials to always have in the tow vehicle. I need to assemble a single toolbox that I can transfer between tow vehicles (I use a primary and two alternates). Easy to start with: Screwdriver(s) Electrical tape Wire, wire cutter/crimper, heat shrink tubing Pneumatic tubing and connectors Gaffer tape (awesome stuff) Scissors Multimeter Fuses Yaw string Extra catheters Lighter What am I missing? 2NO (yeah ... software guy) Stop screwing around. Just bring a spare glider. See ya, Dave |
On Jan 17, 9:18*pm, Bob Kuykendall wrote:
Also include: 1/4" drive socket set with metric sockets 5mm through 13mm and SAE sockets 1/4" through 1/2". Since you have a metric glider, I'd over-subscribe on the metric wrenches. If you want to change a tailwheel tire, for instance, you will need two sockets - one for the bolt end and one for the nut end. I have always been fortunate to find someone to borrow from, but am investing in a duplicate set. I also carry enough electrical stuff to remake most of the connectors in my panel. Spare seat pan screws and washers - I don't know how those guys crawl out of the cockpit, but they do Spare yaw string Rubbing and polishing compound and 400-1200 grit sandpaper Battery-powered electric drill/screwdriver Spare batteries for everything battery operated (EDS, Pulse/Ox, SPOT, PDA - and glider of course). Spare glider battery connectors. Keep a spare EDS battery in the cockpit too. Instead of a tarp I use a cheap yoga mat (camping bed pads work too) for taping under the wings in the dirt - it keeps the sharper stones from sticking to my back. 110V power inverter - how else are you going to run the soldering iron 300 yards from the closest outlet? Radio Shack makes decent, compact ones. Ted, you going to post a Word doc with your summary? Andy We've wandered into spares and support equipment and away from tools |
" wrote in message
: SNIP 110V power inverter - how else are you going to run the soldering iron 300 yards from the closest outlet? Radio Shack makes decent, compact ones. I like the small propane powered soldering pencils. Work great. Even with a extra small can of propane, it is much lighter, compact, and versatile than an electric soldering iron and inverter. Zero One |
I like the small propane powered soldering pencils. Work great. Even with a extra small can of propane, it is much lighter, compact, and versatile than an electric soldering iron and inverter. Butane but, yes, I agree. I like it so much that I use if for practically all of the light duty soldering that I do - partly because it heats up so much faster than a standard electric soldering iron. And, you can take it anywhere - it easily fits in your shirt pocket. See http://home.comcast.net/~verhulst/PICS/solder.jpg - the D cell battery is for a size comparison. Tony V. |
"TonyV" wrote in message : I like the small propane powered soldering pencils. Work great. Even with a extra small can of propane, it is much lighter, compact, and versatile than an electric soldering iron and inverter. Butane but, yes, I agree. I like it so much that I use if for practically all of the light duty soldering that I do - partly because it heats up so much faster than a standard electric soldering iron. And, you can take it anywhere - it easily fits in your shirt pocket. See http://home.comcast.net/~verhulst/PICS/solder.jpg - the D cell battery is for a size comparison. Tony V. Yep, Butane. Works like a champ. You have a nice new one. I have been using my old Radio Shack one for close to 20 years now. Like you, unless I am in my shop, I prefer to use it. Larry Zero One |
Somebody said "just leave it in the trailer."
I would agree, but I have a 1-26 with an OPEN trailer...those tools would litter the highway... Yes, I'd love an enclosed trailer. I'd love carbon wings, too. Eventually I'll weld a semi-water tight toolbox to the trailer, have it sandblasted and painted. -Pete #309 |
On Jan 23, 3:03*am, "Larry Goddard" wrote:
" wrote in message : SNIP 110V power inverter - how else are you going to run the soldering iron 300 yards from the closest outlet? Radio Shack makes decent, compact ones. I like the small propane powered soldering pencils. *Work great. *Even with a extra small can of propane, it is much lighter, compact, and versatile than an electric soldering iron and inverter. Zero One I use the inverter for more than the soldering iron (and it's smaller than two packs of cigarettes), but the propane iron is a cool alternative. |
I've seen some excellent lists on this forum for the pilot, glider, and landout/emergency kit. I'm wondering if anyone has developed a list for the tools, parts & materials to always have in the tow vehicle. I need to assemble a single toolbox that I can transfer between tow vehicles (I use a primary and two alternates). Easy to start with: Screwdriver(s) Electrical tape Wire, wire cutter/crimper, heat shrink tubing Pneumatic tubing and connectors Gaffer tape (awesome stuff) Scissors Multimeter Fuses Yaw string Extra catheters Lighter What am I missing? 2NO (yeah ... software guy) and..... 1- Dollars, a hundred or so, stashed in a safe place within the toolbox, 2- Rum, whisky, a small bottle, wrapped in a 3- hand towel. used in conjuction with other stuff mentioned, the above pretty much fixes everything bagger |
On Mon, 26 Jan 2009 04:50:06 +0000, bagmaker wrote:
- I've seen some excellent lists on this forum for the pilot, glider, and landout/emergency kit. I'm wondering if anyone has developed a list for the tools, parts & materials to always have in the tow vehicle. I need to assemble a single toolbox that I can transfer between tow vehicles (I use a primary and two alternates). Easy to start with: Screwdriver(s) Electrical tape Wire, wire cutter/crimper, heat shrink tubing Pneumatic tubing and connectors Gaffer tape (awesome stuff) Scissors Multimeter Fuses Yaw string Extra catheters Lighter What am I missing? Small socket set to suit your glider Vicegrips/Mole wrench Needlenose pliers Telescopic magnetic nut retriever LED flashlight -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Similar Threads | ||||
Checklist | Larry D. Cosby | Piloting | 148 | March 29th 08 04:10 AM |
Checklist use | Private | Piloting | 2 | February 12th 08 08:25 PM |
Landing Checklist | E. Douglas Whitehead | Soaring | 25 | January 7th 06 05:19 PM |
747-100 Checklist | Bartscher | General Aviation | 0 | December 18th 04 07:20 PM |
C-180 100 hr checklist | ConchyJoe | Owning | 1 | May 3rd 04 11:53 PM |
