Typical glider & trailer total weight?
What would you say is a typical or average glider trailer weight? I
know, "it depends"... but what is typical? I'm shopping for a new vehicle and will buy one that I could use if I crew for someone or to move our club gliders around. Gliders that I have moved around range from 450 to 850 pounds. I don't own a glider myself so I've don't know what the trailers weigh. What's the weight range for typical fiberglass or metal-frame-aluminum-skin glider trailer? (I've seen lots of discussion on RAS about towing in general... not asking for vehicle or towing advice.) Thanks in advance. |
On Feb 5, 8:59*pm, Roger Worden wrote:
What would you say is a typical or average glider trailer weight? I know, "it depends"... but what is typical? I'm shopping for a new vehicle and will buy one that I could use if I crew for someone or to move our club gliders around. Gliders that I have moved around range from 450 to 850 pounds. I don't own a glider myself so I've don't know what the trailers weigh. What's the weight range for typical fiberglass or metal-frame-aluminum-skin glider trailer? (I've seen lots of discussion on RAS about towing in general... not asking for vehicle or towing advice.) Thanks in advance. I don't know if it's typical, but my Komet Trailer with my Speed Astir in it weighs 1,876 pounds. The Speed Astir is 630 pounds. |
Roger,
You saw my LS1-d and Swan trailer at Cordele last year. I took it to a truck stop that had truck scales and weighed the loaded trailer. I had just about all the stuff in the trailer that I would have for a contest: glider, wing stand, tow-out equipment, tail dolly, small tool box with a few tools, bucket, wheel chocks, folding chair, spare tire for trailer, tie-down stakes, a couple gallons of water, etc, etc. At the truck stop, I pulled the trailer up onto the scales, disconnected and drove the car off of the scales. The truck scales have four or five separate concrete pads where you can place different axles, such as the tractor's front axles on one pad, rear double axles on another pad, trailer double axle on yet another pad, etc, etc. I placed the trailer axle (tires) on one pad and the front jack on another pad and set the trailer level to approximate the level when in tow. Results: Total weight 2,040 lbs. Tongue Weight 180 lbs. To say the least, I was flabbergasted. I had thought it might be around 1,500 lbs. Oh, yea. Cost of using the scales: US$8.00 Ray Lovinggood Carrboro, North Carolina, USA |
On Feb 5, 11:59*pm, Roger Worden wrote:
What would you say is a typical or average glider trailer weight? I know, "it depends"... but what is typical? I'm shopping for a new vehicle and will buy one that I could use if I crew for someone or to move our club gliders around. Gliders that I have moved around range from 450 to 850 pounds. I don't own a glider myself so I've don't know what the trailers weigh. What's the weight range for typical fiberglass or metal-frame-aluminum-skin glider trailer? (I've seen lots of discussion on RAS about towing in general... not asking for vehicle or towing advice.) Thanks in advance. 1900 with glass 15meter, avionic trailer, extra gear. Tim |
Roger,
Lightest enclosed trailer would probably be a Schreder tube trailer. Empty, they can be as light as about 700 lbs for a 15 meter ship. Fixtures, stands, etc will add to this. Next up the line would be a Minden Fab or SST tube. These are a bit heavier because of the wooden floor (Schreder trailer has an aluminum floor). Probably 800-850 at the very least. Then, you get into the glass trailers that have steel frames, add in a lift tops, etc, and the weight goes up from there. As Ray said, with his relatively light glider, the trailer and all his goodies came in at over 1400 lbs. I have used a local Co-Op to weigh a couple of trailers. Thier scales are on 24-7, and there is no charge to use them. At least the one near me. Hope this helps, Steve Leonard |
SGS 1-35 (all aluminum) with Gehrlien trailer (originally open) with
aluminum sheet cover is 1325 lbs with only the plane. The plane is 486 lbs. There must be 150 lbs of other "stuff" in there now. Tongue Weight 85 lbs. It's hardly noticable behind my Subaru Legacy (Class II 2500 lb rated) and ok with a Toyota Corolla except on big hills. (Class I rated 1500 lbs.) agl |
What would you say is a typical or average glider trailer weight? I know, "it depends"... but what is typical? I'm shopping for a new vehicle and will buy one that I could use if I crew for someone or to move our club gliders around. Gliders that I have moved around range from 450 to 850 pounds. I don't own a glider myself so I've don't know what the trailers weigh. What's the weight range for typical fiberglass or metal-frame-aluminum-skin glider trailer? (I've seen lots of discussion on RAS about towing in general... not asking for vehicle or towing advice.) Thanks in advance. I have an ASW 19 with a Minden Trailer (wooden floor) and the scales come in at just shy of 1800lbs and a 180lb tongue weight. The empty weight of the 19 is 575lbs. I too was suprised at the weight of the trailer, I expected the total to be around 1100- 1400lbs. Randy |
My Hp16T and Schreder trailer come in at about 1800 lbs, with most
everything I need to fly in the trailer. Brian |
What would you say is a typical or average glider trailer weight? I know, "it depends"... but what is typical? I'm shopping for a new vehicle and will buy one that I could use if I crew for someone or to move our club gliders around. Gliders that I have moved around range from 450 to 850 pounds. I don't own a glider myself so I've don't know what the trailers weigh. What's the weight range for typical fiberglass or metal-frame-aluminum-skin glider trailer? (I've seen lots of discussion on RAS about towing in general... not asking for vehicle or towing advice.) Thanks in advance. My SZD55 and Avionic AVG15 trailer weigh 1800 lbs; add 100 for assorted tools etc. I drive a diesel Jetta which does a great job. |
On Fri, 5 Feb 2010 20:59:53 -0800 (PST), Roger Worden
wrote: What would you say is a typical or average glider trailer weight? I know, "it depends"... but what is typical? Approximately 750-850 kg for a modern single seater +wing extensions and accessories. 900kg for selflaunchers. 1300 kg for a DuoDiscus XT. 1500kg and more for Open Class. All based on Cobra single axle trailers. Aldo |
Similar Threads | ||||
Trailer Weight | rlovinggood | Soaring | 8 | November 1st 07 12:22 AM |
shipping glider to NZ-advice on securing glider in trailer | November Bravo | Soaring | 6 | November 1st 06 02:05 PM |
Glider Weight/Wing Loading and determing speed for best L/D for a given weight | 65E | Soaring | 3 | January 26th 06 09:26 PM |
typical total time and PIC time question | AJW | Piloting | 12 | October 15th 04 03:52 AM |
Glider weight | Miguel Lavalle | Soaring | 8 | December 17th 03 03:00 PM |
