Remove layer of cloth/Gelcoat
I know it can be done.
On an ASW-15, the first layer of cloth was pulled off the wings and a fresh layer of cloth was applied. It worked out well. The naked surface is rough enough to allow good bond of new layer. GA |
On Feb 9, 1:34*pm, glider wrote:
I know it can be done. *On an ASW-15, the first layer of cloth was pulled off the wings and a fresh layer of cloth was applied. It worked out well. The naked surface is rough enough to allow good bond of new layer. *GA Schleicher manual mentions this in maintenance instructions- paint cracks associated with damage that goes thru gelcoat into top layer of glass. UH |
Similar Threads | ||||
Gelcoat sag? | [email protected] | Soaring | 10 | December 17th 07 08:07 PM |
composite using aluminum windowscreen layer | Allan Morrison | Home Built | 4 | January 27th 05 01:19 PM |
F104- Boundary Layer Control | Scet | Military Aviation | 7 | August 27th 04 09:48 AM |
Descending through a thin icing layer | Wyatt Emmerich | Instrument Flight Rules | 70 | December 31st 03 05:17 AM |
Ferro gelcoat | Basil Fairston | Soaring | 0 | December 16th 03 08:34 AM |
