#41
Mandatory Radios
On 2/8/2010 4:28 AM, Bruce wrote:
Until you use something like FLARM - you may preludedly think you have good situational awareness. Personal experience and that of many other, much more experienced than I. Initially I thought it was just evidence of my poor scan - but national and world champions alike have made the same comment - your mind filters things out to keep complexity down to something it can handle. Problem is some of those things move and can very quickly be somewhere other than where you fondly imagined them to be. From a safety perspective I cannot see how anyone can justify flying without at least a decent radio. A decent panel mount radio is 800-1300USD. Monitoring the local general flying channel , it is remarkable how much traffic you hear, but never see. 5km/3NM too far away to see but is only maybe a minute for a fast turboprop. I know multiple anecdotes do not make data but: Having had the experience of being low, and a little marginal getting into an airfield I did not know on an early XC. I made a reasonable circuit and a nice safe landing. It was a completely unremarkable "landout". Of course, I called joining overhead on the TIBA frequency (I was disorganised enough to have failed to note the frequency for the field before I took off.)The B200 I had not seen in the haze on its huge downwind acknowledged, did an orbit and landed 2 minutes behind me. If I had not made the call I would have been turning final in front of him, in the ground clutter, with the sun behind him. That could have been seriously interesting. Until I called, the 2 crew Comm pilots had not seen me, despite me crossing in front of them within 200 feet of their height. My 2c - nothing substitutes for pilot attention - scan and situational awareness cannot be replaced by technology. that said you should do whatever you can to help the old brain. The minimum technology in our current skies has to include a radio. Adding FLARM to the gliding aircraft - tugs included is well worth it. Adding PCAS / Mode-C would be perfect - but would exceed the value of my glider - but maybe not the value of my life. (That depends on when you ask the wife ;-) ) Cheers Bruce Eric Greenwell wrote: jcarlyle wrote: A PCAS might help. And of course there's no replacement for a good visual scan - the radio and the PCAS are crutches, nothing more. The implication of the word "crutch" is a pilot with a good visual scan can get along just fine without a radio. I think that is misleading, because very few pilots can scan at such a high level they always see all the traffic. Even the best scanners can miss a fast airplane coming up behind them, not see one below them in the ground clutter, or get tunnel vision when distracted by a situation. And, I believe both the towplane and the glider should have a radio, even if they are the only two aircraft within 20 miles of the field. They are cheap to buy (cheaper now than ever before) and install, last a long time, and are easy to use. It's hard to believe we're still having this conversation. --- news://freenews.netfront.net/ - complaints: --- FLARM is NOT the answer in the US. What we need is low cost ADS-B transceivers in the same price range as FLARM. That way we can see and be seen by other aircraft in the US airspace system. Low cost ADS-B technology exists TODAY and prototypes are flying. The only thing missing is the political will in the FAA to prioritize the establishment of certification standards so this equipment can be commercialized for VFR applications. Mike Schumann -- Mike Schumann |
#42
Mandatory Radios
The use and development of position awareness (collision avoidance)
technology is a very beneficial adjunct to the eyeball. I have a PCAS in my airplane and glider and I definitely see more traffic than I would otherwise. But in the near-airport environment, where most collisions occur, the effectiveness of detection devices diminishes and the radio is still the most valuable SA device in the ship. Additionally, a radio is much more effective than the traditional soaring signals. You still need to use the appropriate soaring signals – However, consider things like the controversial rudder waggle (something is wrong with your glider), how much easier and more accurate is it for the tow pilot to hit the PTT and say, “your spoilers are open”. Or for the glider pilot to ask the tow pilot to turn right 20 degrees and head for the big cloud, rather than trying to drag the tow plane tail around using an old school maneuver. As stated earlier, it’s 2010… hard to believe radios in gliders are even a discussion topic. Bob |
#43
Mandatory Radios
Mike Schumann wrote: FLARM is NOT the answer in the US. What we need is low cost ADS-B transceivers in the same price range as FLARM. That way we can see and be seen by other aircraft in the US airspace system. Low cost ADS-B technology exists TODAY and prototypes are flying. The only thing missing is the political will in the FAA to prioritize the establishment of certification standards so this equipment can be commercialized for VFR applications. Has anybody mentioned PowerFLARM yet? Does FLARM, Mode-C/S, and ADS-B. Supposedly available in the US in a couple of months. More info at powerflarm.com. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
#44
Mandatory Radios
But sometimes it's all not enough... Unfortunately true. Us pilots need all the help we can get. Vaughn Even if you do everything right, you can still be surprised. A power pilot could easily be monitoring the local CTAF frequencies on a cross country only to unexpectedly encounter a glider who is talking on 123.3 (what power pilot would think of monitoring that???). The only real solution is universal deployment of ADS-B on every aircraft, including gliders, balloons, UAVs, military aircraft, etc. With that, if you attach your ADS-B transceiver to a GPS, you will see everybody. No surprises. The technology exists for ADS-B transceivers to be available for ~$1K. The only thing missing is the political will in the FAA to permit this class of avionics to be certified for VFR use. We need to make our voices heard that we need this NOW. I can't find good graphics showing current ADS-B coverage, or scheduled coverage. Can someone point out a source? A talk at the convention said the FAA is holding well to it's installation schedule, which was good to hear. The July 2009 graphic I found didn't show much coverage out West, and surprisingly, none in Colorado, so I don't trust it much. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#45
Mandatory Radios
On Feb 8, 11:30*pm, Eric Greenwell wrote:
Mike Schumann wrote: But sometimes it's all not enough... Unfortunately true. *Us pilots need all the help we can get. Vaughn Even if you do everything right, you can still be surprised. *A power pilot could easily be monitoring the local CTAF frequencies on a cross country only to unexpectedly encounter a glider who is talking on 123.3 (what power pilot would think of monitoring that???). The only real solution is universal deployment of ADS-B on every aircraft, including gliders, balloons, UAVs, military aircraft, etc. With that, if you attach your ADS-B transceiver to a GPS, you will see everybody. *No surprises. *The technology exists for ADS-B transceivers to be available for ~$1K. *The only thing missing is the political will in the FAA to permit this class of avionics to be certified for VFR use. *We need to make our voices heard that we need this NOW. I can't find good graphics showing current ADS-B coverage, or scheduled coverage. Can someone point out a source? A talk at the convention said the FAA is holding well to it's installation schedule, which was good to hear. The July 2009 graphic I found didn't show much coverage out West, and surprisingly, none in Colorado, so I don't trust it much. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org- Hide quoted text - - Show quoted text - What so you mean by "coverage" I thought the beauty of ADS-B is that it is an "aircraft to aircraft" based system, no ground "coverage" necessary. The other beauty is that ADS-B is NOT radar based, it is GPS based, so it works in remote areas, like ALASKA where it is considered very successful in reducing mid air collisions. Another feature is ADS-B is the "extended squitter" which basically broadcasts your GPS loacation every second, whether you transponder gets "interrogated" or not. We recently installed a Garmin GDL 90 for a customer......... The unit itself is huge, like two shoe boxes in size, and heavy........costs around $8K......This is a "blind box".. It requires additional hardware to display info, it also requires THREE antennas..........then there is the installation cost,...it is not so simple to install.......etc. Cookie |
#46
Mandatory Radios
On Feb 9, 4:10*am, "
wrote: On Feb 8, 11:30*pm, Eric Greenwell wrote: Mike Schumann wrote: But sometimes it's all not enough... Unfortunately true. *Us pilots need all the help we can get. Vaughn Even if you do everything right, you can still be surprised. *A power pilot could easily be monitoring the local CTAF frequencies on a cross country only to unexpectedly encounter a glider who is talking on 123.3 (what power pilot would think of monitoring that???). The only real solution is universal deployment of ADS-B on every aircraft, including gliders, balloons, UAVs, military aircraft, etc. With that, if you attach your ADS-B transceiver to a GPS, you will see everybody. *No surprises. *The technology exists for ADS-B transceivers to be available for ~$1K. *The only thing missing is the political will in the FAA to permit this class of avionics to be certified for VFR use. *We need to make our voices heard that we need this NOW. I can't find good graphics showing current ADS-B coverage, or scheduled coverage. Can someone point out a source? A talk at the convention said the FAA is holding well to it's installation schedule, which was good to hear. The July 2009 graphic I found didn't show much coverage out West, and surprisingly, none in Colorado, so I don't trust it much. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org-Hide quoted text - - Show quoted text - What so you mean by "coverage" I thought the beauty of ADS-B is that it is an "aircraft to aircraft" based system, no ground "coverage" necessary. The other beauty is that ADS-B is NOT radar based, it is GPS based, so it works in remote areas, like ALASKA where it is considered very successful in reducing mid air collisions. Another feature is ADS-B is the "extended squitter" which basically broadcasts your GPS loacation every second, whether you transponder gets "interrogated" or not. We recently installed a Garmin GDL 90 for a customer......... The unit itself is huge, like two shoe boxes in size, and heavy........costs around $8K......This is a "blind box".. *It requires additional hardware to display info, it also requires THREE antennas..........then there is the installation cost,...it is not so simple to install.......etc. Cookie You need an ADS-B ground station for TIS-B (not to be confused with Mode S TIS - completely different): so an ADS-B (either UAT or 1090ES) receiver equipped aircraft can receive position reports based on current SSR/transponder location of aircraft that are not equipped with an ADS-B transmitter. Once you/the threat aircraft is outside SSR coverage you will not "see" the threat via TIS-B. If a threat aircraft is not equipped with a transponder you will not see it via TIS-B. You need TIS-B during any transition to ADS-B adoption, or you will just see other early adopters. You also need ADS-B ground station coverage for ADS-R: the relay between 1090ES and UAT link layers so aircraft equipped with one type of ADS-B receiver will see the signals from an aircraft equipped with the other transmitter type. That is a USA only peculiarity. In Europe for example it is 1090ES only. One confusing point as well is some ADS-B *receiver* manufactures and less than clear that their devices are not transmitters so while you might see other ADS-B boxes (or transponders via TIS-B) they can't see you. Sometimes there is an implied belief that the aircraft with the receiver has a transponder. The Alaska trials were UAT only AFAIK and compared to large areas of no SSR coverage and subsidized installation of UAT devices it is not surprising it had good results. The GDL 90 was basically developed for those trials and is showing its age. Garmin has a much more interesting traffic solution now in the 800 series which include active transponder interrogation (i.e. a TAS/TCAD) system combined with ADS-B via 1090ES over Mode S (and you can pull up Mode S TIS on the same hardware if you want need to, not sure why you would). In Europe there are interesting combined Flarm and ADS-B 1090ES receivers like the Garrecht 1090-TRX and PowerFlarm (not yet shipping). The glider and GA avionics manufacturers in Europe are focusing on 1090ES for ADS-B since Europe has mandated Mode S transponders. I expect to see a wide variety of 1090ES and UAT devices in gliders and GA aircraft and ADS-R relay is goign to be an important issue. i.e. think about ground station coverage in mountainous terrain and along ridges etc. where you can't just assume the other guy has an "ADS-B" and you will see him. I believe that some vendors are working on dual-band (UAT +1090ES) receivers and that may be a good thing. Extended squitter is really a term that applies only to Mode S transponders and in that case is the message type that carries the ADS- B transmission. Darryl |
#47
Mandatory Radios
On Feb 9, 2:07*pm, Darryl Ramm wrote:
On Feb 9, 4:10*am, " wrote: On Feb 8, 11:30*pm, Eric Greenwell wrote: Mike Schumann wrote: But sometimes it's all not enough... Unfortunately true. *Us pilots need all the help we can get. Vaughn Even if you do everything right, you can still be surprised. *A power pilot could easily be monitoring the local CTAF frequencies on a cross country only to unexpectedly encounter a glider who is talking on 123.3 (what power pilot would think of monitoring that???). The only real solution is universal deployment of ADS-B on every aircraft, including gliders, balloons, UAVs, military aircraft, etc.. With that, if you attach your ADS-B transceiver to a GPS, you will see everybody. *No surprises. *The technology exists for ADS-B transceivers to be available for ~$1K. *The only thing missing is the political will in the FAA to permit this class of avionics to be certified for VFR use. *We need to make our voices heard that we need this NOW. I can't find good graphics showing current ADS-B coverage, or scheduled coverage. Can someone point out a source? A talk at the convention said the FAA is holding well to it's installation schedule, which was good to hear. The July 2009 graphic I found didn't show much coverage out West, and surprisingly, none in Colorado, so I don't trust it much. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org-Hidequoted text - - Show quoted text - What so you mean by "coverage" I thought the beauty of ADS-B is that it is an "aircraft to aircraft" based system, no ground "coverage" necessary. The other beauty is that ADS-B is NOT radar based, it is GPS based, so it works in remote areas, like ALASKA where it is considered very successful in reducing mid air collisions. Another feature is ADS-B is the "extended squitter" which basically broadcasts your GPS loacation every second, whether you transponder gets "interrogated" or not. We recently installed a Garmin GDL 90 for a customer......... The unit itself is huge, like two shoe boxes in size, and heavy........costs around $8K......This is a "blind box".. *It requires additional hardware to display info, it also requires THREE antennas..........then there is the installation cost,...it is not so simple to install.......etc. Cookie You need an ADS-B ground station for TIS-B (not to be confused with Mode S TIS - completely different): so an ADS-B (either UAT or 1090ES) receiver equipped aircraft can receive position reports based on current SSR/transponder location of aircraft that are not equipped with an ADS-B transmitter. Once you/the threat aircraft is outside SSR coverage you will not "see" the threat via TIS-B. If a threat aircraft is not equipped with a transponder you will not see it via TIS-B. You need TIS-B during any transition to ADS-B adoption, or you will just see other early adopters. You also need ADS-B ground station coverage for ADS-R: the relay between 1090ES and UAT link layers so aircraft equipped with one type of ADS-B receiver will see the signals from an aircraft equipped with the other transmitter type. That is a USA only peculiarity. In Europe for example it is 1090ES only. One confusing point as well is some ADS-B *receiver* manufactures and less than clear that their devices are not transmitters so while you might see other ADS-B boxes (or transponders via TIS-B) they can't see you. Sometimes there is an implied belief that the aircraft with the receiver has a transponder. The Alaska trials were UAT only AFAIK and compared to large areas of no SSR coverage and subsidized installation of UAT devices it is not surprising it had good results. The GDL 90 was basically developed for those trials and is showing its age. Garmin has a much more interesting traffic solution now in the 800 series which include active transponder interrogation (i.e. a TAS/TCAD) system combined with ADS-B via 1090ES over Mode S (and you can pull up Mode S TIS on the same hardware if you want need to, not sure why you would). In Europe there are interesting combined Flarm and ADS-B 1090ES receivers like the Garrecht 1090-TRX and PowerFlarm (not yet shipping). The glider and GA avionics manufacturers in Europe are focusing on 1090ES for ADS-B since Europe has mandated Mode S transponders. I expect to see a wide variety of 1090ES and UAT devices in gliders and GA aircraft and ADS-R relay is goign to be an important issue. i.e. think about ground station coverage in mountainous terrain and along ridges etc. where you can't just assume the other guy has an "ADS-B" and you will see him. I believe that some vendors are working on dual-band (UAT +1090ES) receivers and that may be a good thing. Extended squitter is really a term that applies only to Mode S transponders and in that case is the message type that carries the ADS- B transmission. Darryl- Hide quoted text - - Show quoted text - Darryl, Thanks for the information. So what's the answer? They came out with mode A, Then they needed mode C, then mode S and then ADS-B... It seems like every system has at least some sort of loophole it it. By the time anything is in widespread use it seems to be obsolete already. Cookie |
#48
Mandatory Radios
On Feb 9, 4:14*pm, "
wrote: On Feb 9, 2:07*pm, Darryl Ramm wrote: On Feb 9, 4:10*am, " wrote: On Feb 8, 11:30*pm, Eric Greenwell wrote: Mike Schumann wrote: But sometimes it's all not enough... Unfortunately true. *Us pilots need all the help we can get. Vaughn Even if you do everything right, you can still be surprised. *A power pilot could easily be monitoring the local CTAF frequencies on a cross country only to unexpectedly encounter a glider who is talking on 123.3 (what power pilot would think of monitoring that???). The only real solution is universal deployment of ADS-B on every aircraft, including gliders, balloons, UAVs, military aircraft, etc. With that, if you attach your ADS-B transceiver to a GPS, you will see everybody. *No surprises. *The technology exists for ADS-B transceivers to be available for ~$1K. *The only thing missing is the political will in the FAA to permit this class of avionics to be certified for VFR use. *We need to make our voices heard that we need this NOW. I can't find good graphics showing current ADS-B coverage, or scheduled coverage. Can someone point out a source? A talk at the convention said the FAA is holding well to it's installation schedule, which was good to hear. The July 2009 graphic I found didn't show much coverage out West, and surprisingly, none in Colorado, so I don't trust it much. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "A Guide to Self-launching Sailplane Operation" atwww.motorglider..org-Hidequotedtext - - Show quoted text - What so you mean by "coverage" I thought the beauty of ADS-B is that it is an "aircraft to aircraft" based system, no ground "coverage" necessary. The other beauty is that ADS-B is NOT radar based, it is GPS based, so it works in remote areas, like ALASKA where it is considered very successful in reducing mid air collisions. Another feature is ADS-B is the "extended squitter" which basically broadcasts your GPS loacation every second, whether you transponder gets "interrogated" or not. We recently installed a Garmin GDL 90 for a customer......... The unit itself is huge, like two shoe boxes in size, and heavy........costs around $8K......This is a "blind box".. *It requires additional hardware to display info, it also requires THREE antennas..........then there is the installation cost,...it is not so simple to install.......etc. Cookie You need an ADS-B ground station for TIS-B (not to be confused with Mode S TIS - completely different): so an ADS-B (either UAT or 1090ES) receiver equipped aircraft can receive position reports based on current SSR/transponder location of aircraft that are not equipped with an ADS-B transmitter. Once you/the threat aircraft is outside SSR coverage you will not "see" the threat via TIS-B. If a threat aircraft is not equipped with a transponder you will not see it via TIS-B. You need TIS-B during any transition to ADS-B adoption, or you will just see other early adopters. You also need ADS-B ground station coverage for ADS-R: the relay between 1090ES and UAT link layers so aircraft equipped with one type of ADS-B receiver will see the signals from an aircraft equipped with the other transmitter type. That is a USA only peculiarity. In Europe for example it is 1090ES only. One confusing point as well is some ADS-B *receiver* manufactures and less than clear that their devices are not transmitters so while you might see other ADS-B boxes (or transponders via TIS-B) they can't see you. Sometimes there is an implied belief that the aircraft with the receiver has a transponder. The Alaska trials were UAT only AFAIK and compared to large areas of no SSR coverage and subsidized installation of UAT devices it is not surprising it had good results. The GDL 90 was basically developed for those trials and is showing its age. Garmin has a much more interesting traffic solution now in the 800 series which include active transponder interrogation (i.e. a TAS/TCAD) system combined with ADS-B via 1090ES over Mode S (and you can pull up Mode S TIS on the same hardware if you want need to, not sure why you would). In Europe there are interesting combined Flarm and ADS-B 1090ES receivers like the Garrecht 1090-TRX and PowerFlarm (not yet shipping). The glider and GA avionics manufacturers in Europe are focusing on 1090ES for ADS-B since Europe has mandated Mode S transponders. I expect to see a wide variety of 1090ES and UAT devices in gliders and GA aircraft and ADS-R relay is goign to be an important issue. i.e. think about ground station coverage in mountainous terrain and along ridges etc. where you can't just assume the other guy has an "ADS-B" and you will see him. I believe that some vendors are working on dual-band (UAT +1090ES) receivers and that may be a good thing. Extended squitter is really a term that applies only to Mode S transponders and in that case is the message type that carries the ADS- B transmission. Darryl- Hide quoted text - - Show quoted text - Darryl, Thanks for the information. So what's the answer? *They came out with mode A, *Then they needed mode C, then *mode S and then ADS-B... It seems like every system has at least some sort of loophole it it. By the time anything is in widespread use it seems to be obsolete already. Cookie Technology is often obsolete before being deployed. And the question is often not "what is the answer?". The question is "what is the question?". (and maybe with both Mode S and ADS-B technologies that actually applies) Sigh, I'm such a cynic. Darryl |
Similar Threads | ||||
Mandatory ADS B | Richard[_1_] | Soaring | 2 | October 2nd 08 12:43 AM |
Mandatory ELT | [email protected] | Soaring | 9 | March 8th 05 03:01 PM |
Region 4 S: ELT Mandatory | Chris OCallaghan | Soaring | 14 | June 29th 04 07:38 PM |
ELT Mandatory ? | Jim Culp | Soaring | 20 | June 19th 04 06:40 PM |
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* | JStONGE123 | Military Aviation | 1 | May 11th 04 06:22 AM |
