Pirep on replacing interior plastic parts
A recent post bemoaned the high cost of replacement interior plastic parts
from the original manufacturer (in this case, Cessna). I suggested that parts of this type are available, often at lower cost, from PMA sources. This led to a discussion of relative merits of original vs. PMA, etc. Yesterday, my partners and I installed a number of interior plastic parts on our 1979 Piper Arrow IV. The biggest and most involved part was the overhead console/vents We also installed new floor vent cups and a front rib cover. (You PA-28 and PA-32 owners know what that is.) We got the parts from Planeparts (www.planeparts.com), which specializes in Piper interior plastic parts. There were one or two other sources that offered these parts, but based on the images on the websites, it appeared to us that the Planeparts products seemed better finished and would require less work to install. Here are the parts we ordered and the prices we paid: Overhead console, $215.00 2 louvered vents for overhead console, $16.95 each 4 vent cups, $11.95 each rib cover, $35.95 The order arrived by USPS Priority Mail about 10 days after we placed the order. Postage added about $12.00 to our total cost. While the overhead console was "sort of" the same color as the part it was to replace, it was obvious that it would have to be painted to achieve a pleasing finish. And because it was not possible to get a perfect match with the SEM paint we used (upon recommendation from others in this newsgroup) we also had to remove and paint the rear air duct. The vent cups and rib cover were way off in color, so we had to paint those as well. The new overhead console required a bit of work with a drill and Dremel tool in order to mount the overhead dome light, instrument light, and speaker. The big holes were pre-cut, but not the screw holes. We used the old part as a template, and this work was not particularly difficult. The holes for the screws that hold the console to the overhead also had to be drilled out, but that was very easy because the part had molded-in guides where the holes needed to be drilled. The rib cover also had to be cut to fit. We measured carefully and made the cuts using the Dremel tool, then trimmed as needed for a good fit. Surprisingly, the vent cups also had to be trimmed. The barrels stuck in too far when mounted, so that the cups would not rotate freely. We cut off about 1/4 inch from the barrels, again using the Dremel tool, and that worked out fine. We painted all of the parts using the method recommended on the SEM can. At about $12/can, the stuff is expensive, but produces excellent results with little effort. It's not generally available at hardware stores, but I found it at a store that sells supplies to auto body shops. For color matching, be sure to ask to see the SEM color chart, as the colors on the can tops are not very accurate. Installation of the vent cups, vent louvers, and rib cover, once properly trimmed, was easy. Installation of the overhead console took some effort, and would have been virtually impossible with less than two people. Most importantly, in consideration of our biggest worry, the console fit perfectly. How do we feel about the parts we got from Planeparts? The console appears to be well made, probably a bit sturdier than the original, and fit perfectly. The rib cover is okay, but seems kind of pricey for a very simple part. The vent cups actually seem a bit less robust than the original parts, but we'll have to see how they hold up with everyday use. All in all, we think the money and effort were well worth it. -- -Elliott Drucker |
Thanks for the PIREP. Your experience matches mine, except when I replaced the overhead piece in our Cherokee it came in two parts, which had to be trimmed and glued together before final installation. This was not made clear in the sales brochure, and I would not have bought that piece from that manufacturer had I known this up front. I bitched like hell when I met the manufacturer at one of the big airshows (actually, I think at the Cherokee Pilots Association fly-in), and he admitted that they were now selling the unit fully assembled, due to so many complaints. It was really difficult to get the pieces to fit properly although, in the end, it came out okay. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Similar Threads | ||||
"certified' parts | Jimmy B. | Owning | 51 | March 18th 05 06:04 PM |
molding plexiglas websites? | [email protected] | Owning | 44 | February 17th 05 09:33 PM |
Grumman E2C Parts Numbers needed | CaptAro | Restoration | 0 | July 9th 04 12:50 AM |
Navion Parts Availability | Margy Natalie | Owning | 12 | August 15th 03 03:47 AM |
Navion Parts Availability | Margy Natalie | Restoration | 10 | August 15th 03 03:47 AM |
