Jay,
A good method is to first dab some solvent on a clean rag and wipe off the rivet heads and the 1/2 inch around them to clean off oil and grease. Get a fiberglass brush. These are used to clean up printed circuit boards. I believe you can get them at Rat Shack. Expose only about 1/16 of an inch. Then carefully "sand" the head in a circular motion. Try not to scratch the surrounding area. Wipe again with the solvent. You can mix up some etching primer and put it on, then sand it down again with the brush and paint. I would just paint the things and forget primer. If it peels off in time, you can repeat the process using primer. To apply primer and paint, I use a matchstick from a book of matches. Works as well as anything else. Much more controllable than a touch up brush. Cheap and disposable. In all the years I painted, I never found a good substitute. Don't glob on a huge drop. Take a little from the mixing can and wipe off the excess on the can lid. Mix only about 1 ounce. You won't even need that much. The airbrush method is O.K., but catalyzed enamels are too thick to shoot well from them. Masking is a hassle. If you do use an airbrush, you might want to get a paper punch of the right size and punch the hole in a piece of wide masking tape. Tape over all the holes so the punched out circle is over the rivet and mask the remaining area. Be sure to MASK 4 FEET around the rivets. I would personally go one better and cover the rest of the wing and the top of the fuselage if you airbrush. If you think it is overkill, it ain't. Cleaning over spray is one of the worst jobs a painter can have and these paints do get EVERYWHERE, even with an airbrush. Normally, an airbrush uses little pressure, however, the pressure needed to shoot thick enamel from an airbrush will cause the paint to carry a long way. Again, I prefer the brush method for such a small defined area. Good Luck, Mike Jay Honeck wrote: We just installed the Skycraft landing lights, which meant drilling a few dozen holes into my beautiful paint job. Is there ANY way to touch those rivets up with paint that will yield satisfactory results? I've tried using automotive touch-up paint in the past, with limited success. I'd like to find something that actually looks half-way decent. Thanks! -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" __________________________________________________ _____________________________ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com The Worlds Uncensored News Source |
Similar Threads | ||||
B-17G Original aviation heritage painting | [email protected] | Aviation Marketplace | 1 | December 21st 04 12:27 PM |
B-17G Original aviation heritage painting | jfkuna | Owning | 0 | December 21st 04 06:33 AM |
Blasting and painting | [email protected] | Home Built | 7 | June 3rd 04 03:14 PM |
painting Vicky | Stephen N Mills | Owning | 2 | February 3rd 04 12:51 AM |
aircraft painting southeast US | Dave Butler | Owning | 7 | October 8th 03 04:50 PM |
