FS: Aerox Regulator, Cannula and Mask
Old April 4th 16, 11:58 PM posted to rec.aviation.soaring
George Haeh
Default FS: Aerox Regulator, Cannula and Mask
Moving from an ASW-20 to a 27 with
automatic hookups left me with a smaller
oxygen cylinder and last year I ran out on a
couple flights. Then a couple weeks ago I
knocked my cylinder over breaking the
flowmeter - $62 at W&W; so decided to
bite the bullet and switch to Mountain
High.
The single outlet regulator with pressure
gauge + mask(unused) + Oxysaver
cannula add up a bit over $250.
$150 obo takes it.
Old April 5th 16, 03:06 AM posted to rec.aviation.soaring
Dale Watkins
Can you email me at Zen1960 at live bot com. I will spring for it. Looking to put on in my KA6CR.
Dale
Old April 5th 16, 11:50 AM posted to rec.aviation.soaring
Tango Eight
Dale
public service announcement... this:
http://www.chiefaircraft.com/ao-4110-621.html
so far, appears less likely to fall apart in normal use vs the right angle flow controls
http://wingsandwheels.com/oxygen-equ...flowmeter.html
still being sold at popular soaring supply houses. The right angle jobs seem to last about three wave camps. Mine broke on the ground, others have been less fortunate. The plastic flowmeter housing generally breaks just above the needle valve.
best,
Evan Ludeman / T8
Old April 5th 16, 01:29 PM posted to rec.aviation.soaring
Surge
People still fly with manually adjusted oxygen systems? :-o
That's like flying with a mechanical vario (no audio).
It can be done but is it really in one's best interest to be constantly fiddling with things inside the cockpit?
Old April 5th 16, 02:38 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Well, he'll if we are selling used oxygen equipment, I have two older Aerox flow meters, $35 takes both, I could probably throw in one or more of the "oxsaver" cannula. Moved to Moutain high years ago. Contact me privately.
Old April 5th 16, 03:43 PM posted to rec.aviation.soaring
Tango Eight
Sure. I fly about ten flights a year with ox... and most of those to altitude where the MH system isn't really the preferred tool.
btw... "constantly fiddling" (in general) means "you're doing it wrong". :-o
T8
Old April 5th 16, 03:52 PM posted to rec.aviation.soaring
Dan Marotta
Those cheaply made flow meters are for the birds. I bought medical
grade panel-mount flow meters for my Sinus (experimental) at 2/3 the
cost and they're far superior in materials and quality. If you don't
have panel space to mount one, you could lay it in your lap just like
the other one, though it's a bit more substantial. Here's a link to an
example: https://www.dwyer-inst.com/Product/F...Area/SeriesOMA
Dale
best,
Evan Ludeman / T8
Dan, 5J
Old April 5th 16, 04:10 PM posted to rec.aviation.soaring
Jonathan St. Cloud
The listed site says you can use the flow meter with any O2 system. That is wrong and could be dangerous. Do not use with a Mountain High system.
Dale
best,
Evan Ludeman / T8
Old April 5th 16, 08:04 PM posted to rec.aviation.soaring
PGS
On Tuesday, April 5, 2016 at 10:52:19 AM UTC-4, Dan Marotta wrote:
Those cheaply made flow meters are for the birds.* I bought medical
cost and they're far superior in materials and quality.* If you
don't have panel space to mount one, you could lay it in your lap
just like the other one, though it's a bit more substantial.* Here's
a link to an example:* https://www.dwyer-inst.com/Product/F...Area/SeriesOMA
Dan, what flow rate is used for what altitude?
Old April 6th 16, 12:20 AM posted to rec.aviation.soaring
Dan Marotta
I don't recall exactly. I carried a pulse oximeter to keep tabs on O2
saturation. Take a look at this link:
http://www.c-f-c.com/gaslink/docs/abo4.htm
http://www.c-f-c.com/gaslink/docs/abo4.htm . Using that it appears
that 1 lpm/10,000' is the FAA recommended flow rate. Therefore, 1.8 lpm
at 18,000', but I'm certainly no expert and you'll have to make your own
choices.
Dan
just like the other one, though it's a bit more substantial. Here's
a link to an example: https://www.dwyer-inst.com/Product/F...Area/SeriesOMA
Dan, 5J
Aerox DD02-01 Oxygen System and Regulator for Sale. Brian[_1_] Soaring 2 April 1st 15 05:32 AM
Aerox O2 regulator for sale Kurt[_3_] Soaring 0 August 8th 09 04:04 PM
Aerox O2 regulator for sale [email protected] Soaring 0 December 27th 08 06:51 PM
Cannula vs Mask (FAR) Stefan Piloting 9 October 31st 07 11:06 AM
Oxygen mask and regulator sale - update nzuri Soaring 0 October 1st 03 09:31 AM
