Re Canopy glue
Old May 20th 04, 11:27 AM
Gerry Brown
Default Re Canopy glue
snip
The big problem is your canopy wasn't sanded enough
before it was glued on last
snip
Before you attack the canopy with grit.. check this
DG link
http://212.8.200.175/~techdg/tn/serv.../2003-52-e.pdf
Old May 20th 04, 02:19 PM
JJ Sinclair
snip
DG link
snip
The info you provided gives instructions for the use of Teroson Macroplast.
When using Epoxy, both frame and canopy must be sanded or it wont stick.
JJ Sinclair
Old May 20th 04, 03:20 PM
Gerry Brown
Fair comment..
But the original request was for ideas… this is just a late entry :P)
snip
DG link
snip
JJ Sinclair
All,
Advice needed
My canopy frame and caopy are beginning to disbond.
Need to know what to use to glu them back together.
Current thoughts a epoxy and flox, poluerthane cement, acrylic cement
(for plexiglas crack repair), and adhesive sealant like 3M 5200.
Ideas please. Nolaminar?, JJ?
Thanks!!!
Making your own canopy c hinds Home Built 6 November 22nd 04 09:10 AM
Canopy causes cockpit fire Bob C Soaring 33 May 23rd 04 03:27 PM
Canopy crack repair Pete Brown Soaring 0 May 18th 04 03:09 AM
Redundant canopy latching John Soaring 5 March 16th 04 12:50 PM
DART Canopy needed Ernie Soaring 2 January 17th 04 03:26 PM
